Question about Dell 1600n All-In-One Laser Printer
Curled corner causing a paper jam
Printer curls one corner of the paper as it prints. This usually will cause a paperjam. I open the rear cover and the paper will feed out the back, curled but will not jam the feed
    Scholar:
  • 105 Answers
Try replacing all paper. Sometimes paper that is overly humid or has gotten wet will curl. Replace with new paper and report results.
Posted on Mar 27, 2008
Paper printing hot and curling on kyocera taskalfa 300i.....how do i remedy that problem.
Paper curling is usually caused by one of two things:
1. old damp or moist paper that has too much humidity in it. Easy test for this is to open a brand new ream of paper and try fresh paper.
2. The fuser temperature is too hot for the paper you are printing on. If you can set paper type on your printer, make sure it matches the actual paper, for instance, plain paper, heavy paper.
Feb 19, 2015 | Kyocera Office Equipment & Supplies
Why do I keep getting paper jams
Hi I used to work for kodak and we had schools with this problem. Paper absorbs humidity and curls so if paper is left in the tray for too long it can curl at the corners. So over the weekend when the heat in schools is turned down it caused the paper to curl. So an easy fix is to keep your paper in an airtight container until needed. Then throw paper in, print and then put the rest back in your air tight container. You should have no more issues.
Oct 30, 2012 | Brother International Computers & Internet
Paper jams in the feeder on the left side , tried to opentop cover does not allow me to open back. how do I GET THE ROLLER from curling the paper?
One reason for paper jams is due to some obstructions in the paper path. Remove the sheets of paper from the feeder. Grab a flashlight and look into the paper feeder. Clear the feeder from any foreign objects or debris that could cause "curling" of the paper. If feeder is clear, open the printer cover and ensure the paper path is clear in the cartridge area.
Unplug and replug the printer into the power source to reset it. When the printer turns on, try to print again. If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Jul 28, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
Will not print - paper jams - when open the back cover paper comes out on its own
Remove the paper from behind the back cover, then remove the paper tray and check for any other jammed paper. Once you've removed it all, turn the printer off then back on. Before printing again, take the paper out of the tray, fan it out, and flip it over so it's upside-down. (Paper curl and static can cause jams, and turning the paper over can often correct those issues.)
Does it still jam?
Mar 12, 2011 | Brother MFC 240C All-In-One InkJet Printer
Paper jam
You are receiving this error message because there is a paper jam or the top (photo) tray is not securely in position and the printer cannot initialize. This error message can appear for an ESP 7, ESP 9, ESP 7250, or ESP 9250 all-in-one printer.
To resolve a paper jam, we have an easy Step-by-Step Solutions and Repair tool. Within the tool, select All-in-one printer, then Paper jam.
When you clear the paper jam:
  1. Make sure you open the paper output tray and inspect the top tray for photo paper that could be jammed inside or that remains in the nip at the entrance.
  2. Pull out the bottom paper tray and clear any paper jams.
  3. Remove the duplexer from the back of the printer and clear any paper jam.
NOTE: Curled photo paper could induce a paper jam. To prevent curling:
  • Store un-printed paper in a tightly closed plastic bag or in its original packaging.
  • Store sealed packages of paper flat, and not on
  • When you are ready to print, take only the paper intend to use immediately.
To remove curl in photo paper:
  1. Place the paper in a plastic bag or in its original packaging.
  2. Gently bend the paper in the opposite direction of the curl, then insert it into a tube-a paper towel tube works well.
    NOTE: The tube should be larger than 1.5 in. (4 cm) in diameter.
  3. After a few minutes, remove the paper from the tube.
  4. Remove the paper from the plastic bag or packaging.
  5. Verify that the curl has been removed from the paper. Repeat the steps above if necessary.
If the top paper tray is not securely in position and the printer cannot initialize (you may hear a grinding noise, and the top paper tray will not open), contact Kodak.
Nov 02, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
WILL FEED PLAIN WHITE PAPER BUT WILL NOT FEED PHOTO PAPER
Follow the steps:
•1
Turn on the printer and press the Paper Feed switch until the Auto Sheet Feeder indicator light turns on.
•2
Pull up on the paper sheet feeder on the top and back of the printer and slide out the paper support.
•3
Take a stack of no more than 10 pieces of photo paper and flatten the corners, if they are curled. Curled corners may cause jams within the printer.
•4
Place the paper in the paper sheet feeder with the printable side of the paper facing up. The printable side of photo paper is the shiny or whiter side of the paper.
•5
Print your documents as needed.
Paper Cassette :
•1
Switch on the printer and press the Paper Feed switch until the Cassette indicator light turns on.
•2
Pull on the cassette on the bottom of the printer to slide it out of the printer.
•3
Flatten the corners of a stack of no more than 10 sheets of photo paper if the corners are curled. The paper may become jammed in the printer if the corners are curled.
•4
Place the stack of paper in the cassette so the paper is touching the right side and the printing side of the paper is facing down. Adjust the plastic paper guides so they touch the paper. The paper stack guides help facilitate the paper moving into the printer.
•5
Slide the cassette back into the bottom of the printer. The printer is ready for printing.
Oct 20, 2010 | HP PSC 2355 All-In-One InkJet Printer
My Ip90 won't feed paper when I try to print a job.
If the paper does not feed properly it could be due to the follwong causes.
Cause 1 : Inappropriate paper type used
Action : * Check to see if the paper you are printing on is too thick or curled.
* Check if the paper exceeds the load limit mark, if it exceeds, load less paper.
Cause 2 : Paper Feed Roller is dirty.
Action : Follow the steps described below to clean the Paper Feed Rollers.
If envelopes or post cards do not feed properly, even after correctly any paper curl, clean the Paper Feed Roller.
1) Ensure that the printer is turned on and there is no paper loaded in the printer.
2) Hold the RESUME/CANCEL button down and release after the POWER lamp flashed there three times.
The paper roller rotates as it cleans.
3) Repeat this cleaning operation one more time.
4) Load a sheet of plain paper in the printer.
5) Hold the RESUME/CANCEL button down and release after the POWER lamp flashes three times, then feed a sheet of paper.
Cause 3 : Paper jams.
Action : Remove the paper according to the following procedure.
1) Slowly pull the paper out, either from the Auto Sheet Feeder or from the Output Slot Cover, whichever is easier.
* If the paper tears and a piece remains inside the printer, open the Print Head Cover and remove it.
Caution: Be careful not to touch any components inside the printer.
* If you cannot pull the paper out, turn the printer off and turn it on again.
The paper will be ejected automatically.
2) Reload the paper into the printer and press the RESUME/ CANCEL button.
If you cannot remove the paper or if the paper tears inside the printer or if the Paper Jam error continues after removing the paper, contact the Customer care center.
Hope this helps.
Please rate my response.
Thanks
Have a good day.
Dec 03, 2009 | Canon PIXMA iP90 Mobile Printer
Paper curl
When a paper jam occurs, the printer will stop printing and the Continue (1) and Paper Jam (2) lights on the operator panel will come on. See the illustration below.
pattlnk_1052005_1635-enus20238_oppaneljamlights_e230_en_us.gif When you experience a paper jam, it is recommended that you check and clear the entire paper path. To clear a paper jam, do the following:
  1. If you are feeding paper from a paper tray, first remove the tray. Look for and remove any jammed or damaged paper you find.
  2. Open the front cover and remove the print cartridge assembly.
    IMPORTANT!
    Do not leave the print cartridge assembly exposed to direct light, especially sunlight, for an extended period of time. Extended exposure to light will damage the green photoconductor roller and cause print quality problems.
  3. Remove any paper you find jammed in the area behind the print cartridge assembly.
  4. Also lift the flap at the front of the printer and remove any paper you find jammed beneath the flap.
  5. Open the rear exit door/cover of the printer and remove any jammed paper you find there.
  6. Once you have confirmed that the entire paper path is clear, reinstall the print cartridge assembly. Close all the printer covers/doors. Reinstall any paper trays you removed.
  7. Press the Continue button to resume printing. NOTE: The printer should reprint the page(s) that caused the paper jam.
  8. If the paper continues to jam, press the Continue button twice quickly while the Continue and Paper Jam lights are on. This will cause the operator panel to display the secondary error paper jam light sequence. The secondary error code will tell you where the printer thinks the problem has arisen. For more information, see the 'Secondary Error Codes' section on page 69 of the User's Guide.
Sep 04, 2008 | Lexmark E232 Laser Printer
Brother HL5250DN Printer duplex problem
I have never seen that happen on one of these.
check to be sure that they go backward at the end of printing, they may reverse on startup
I think maybe you are missing the door that sits inside the rear door (called outer shute assy). When you open rear door there should be another before fuser.
How old is this machine, because there is a fuser and outer shute and cover mod, that goes in to early product run of this model. Machines affected are from the Initial production up to and including Serial No.'s K6J702822 (last 9 digits of S/N), this mod is to help with paper curling at exit causing jams.
Nov 08, 2007 | Office Equipment & Supplies
Dell 1600n All-In-One Laser Printer Logo
290 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
