Question about Linksys RangePlus WRT100 Wireless Router
Have labtop computer but for somereason computer
Have labtop computer but for some reason computer cannot find network with router. My computer works fine with my cable wire connected staight into it but when i plug the cable in the ethernet spot on router the computer cannot find a network.
  • Mitesh Kr Anand May 11, 2010
    Did you configure the Router according to your ISP setting?
    New Friend:
  • 9 Answers
The owners manual should tell you how to do this but below is a summary.
Connect to your router via the cable connection by typing in the ip address of the router. Note the SSID, Password and security settings. Also make sure WLAN is transmitting via WiFi.
Disconnect pc/router cable.
Activate your WLAN at the pc
Make sure you can see your SSID from your Laptop.
Make the connection by clicking on your SSID and enter the required password and security settings.
Posted on Sep 27, 2009
I just got a Wireless Networking Adapter for my Xbox 360 and it recognizes the wireless connection and it recognizes the connection after I type in the passcode to the connection. The Adapter for...
XBOX
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then Open The Ports
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And Also Make sure that UPnP is Enabled
Dec 27, 2010 | Microsoft Wireless Network Adapter Xbox...
MY router not working to my labtop and I jad to
Is there any other computer online through the same router. If that computer is online then check the settings of the laptop. Check whether it is connected to the network or not ?
If there is no other computer, then connect your computer to the router and check whether it goes online with the cable connection. If the cable connection works then open the set up of the router and check the wireless settings of the router.
Click Here for more info about routers
Nov 19, 2009 | AT&T Computers & Internet
My laptop wont connect to my wireless router, but my desktop which is directly connect will?
You wirless switch has to be turned on for that to work. If that is not the issue then sometimes it it best to plug it in to the router and set it up that way. the computer already recognizes the computer and it finds it easier to set up the wirless.
If you want to make it real easy to manage your computers and the internet. Download a network manage ment program. I will help you connect you computers to the internet and much more. Network Magic Pro or Network Magic Essentials $30-$50.
I hope i have given you information that has helped you.
Thank you for the chance to help as well...
Randy
FixYa Support Expert
Nov 05, 2009 | Linksys WRT160N Wireless Router
Getting new labtop
The desktop should have an eathernet port on the back if it does you will need to get an eathernet cable from your loca computer supply store. This cble will be pluged into that port and into one of the eaternet plugs on the router. To conect the laptop there should be a wirless icon on the lowere left side of your screen on the taskbar it may need to be expanded by pushing the arow. You will the right click on that icon and say view wirless networks. It should pop up a list of networks click on the one you own and say conect. It might ask for a WEP password which should be located on the botom of the router or the side. I hope this helps you and look forward on helping you again.
Jan 28, 2009 | 2wire (1000-400108-001) Router
Cant get my vista labtop to print through router
Did you share the printer PSC 1410 in the XP Desktop computer??
Thanks
Riz
Jan 14, 2009 | HP PSC 1410v All-in-One Printer
Wireless router netgear
Is it possible to download the drivers for Netgear wireless router & Voice adapter WGR613VAL
Nov 02, 2008 | NetGear WGR614 Wireless Router
Problem connecting to internet from PC to laptop
mY lAB TOP WAS CONNECTED THROUGHdlINK WIRELESS ROUTER VIA bROAD BAND mtnl mODEM. iT WAS WORKING BUT nOW IT HAS STOPPED CONNECTION THROUGH YOUR dLINK wIRELESS.
pLEASE SUJJEST
Aug 10, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Wireless connection showing acquiring signal - wireless not working
your should install the router once more , entry the username and passord provided by ISP. then your router will work properly.
May 25, 2008 | D-Link DI 514 Wireless Router (DI-514)
I have a linksys for my computer and labtop my daughter needs a network key to get on her laptop where do i find this number.
I am going to assume that you have a Linksys wireless router connected to your computer.
The network key is set in the router by using it's set-up page. Usually, you type in a 26 character code or a text string that is used to form the key.
After setting up the router, you turn on the laptop, scan for available networks, and select yours. Then you enter the network key, which will be exactly same as that you entered into the router setup.
If you are having trouble connecting from the laptop, I suggest you first try setting up the wireless router to use no encryption, just to make sure the laptop can find the network. Once this has been established, activate the security features.
FW
Apr 30, 2008 | Computers & Internet
Setup for wireless internet
go start/control panel /wireless assistant configure it there !
make shure to askyour husband if is cryption for router is wep or wap it makes a difference there but first configure it in the control panel!
Jan 14, 2008 | HP Pavilion dv6000z Notebook
Linksys RangePlus WRT100 Wireless Router Logo
117 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
