Question about Motorola Computers & Internet
Voltage regulator Motorola Power Supply APN 6003 A. Probably a CB base power supply. I wish to replace the voltage regulator but cannot identify its type and so am unable to tell which pin is which to enable the use of an alternative. Can you help?
  • 2 more comments
  • formalcolm Sep 27, 2009
    Have been unable to find a circuit diagram.
    Just hoped someone may know so could work out the pin allocation on the original to facilitate finding a replacement.
    This power supply has been altered to variable output
    using TO-220 type regulator whose markings are only
    185 213
    M9633
    I have been unable to identify this component to work out the pin functions as I would like to replace it with an LM388.
    Can anyone identify?
  • formalcolm Feb 06, 2010
    I would also appreciate a copy of the circuit diagram if it is possible to obtain same.
    Tim,
    thank you for your respose.
    My problem is sorted as per testimonial in response to Terry2.
    Mine is set up as a variable power supply 0-24V and does give stable voltages according to the Voltmeter and Ammmeter I have mounted on it but the label on the unit only says 8Amp at 13.8V so I have stayed within this current.
    Used mainly for electrolytic de-rusting but also as a power supply for a 12V refrigerator on occasions.
    Have added a fan onto the big heat sink on the rear but not sure this is necessary.
    Would be nice to have circuit diagram in case of future problems.
Tterry2. Have just found two of these APN6003 power supplies and want to convert one to a varable supply. Would the schematic you found be in an emailable form?
Thanks,
Anton
Posted on Feb 06, 2010
  • barbs09 Feb 09, 2010
    Thanks for you reply tterry2. I see what you mean. I might scrap the circuit board and use a LM317 regulator to control the voltage using the existing bridge rectifier, cap and by-pass transistors. It seems like a good transformer though I haven't yet worked out all the taps.
    Thanks,
    Anton
Are you still trying to fix the APN6003 power supply? I have the schematic. The 9633 is a NPN transistor, not a 3 terminal regulator. Cheers Tim
Posted on Jan 11, 2010
Testimonial: "Spot on thanks. My error in thinking it was a regulator. Mate found the problem was a dry joint in any case but thank you for going to the trouble. "
  • Tim Terry Feb 06, 2010
    Hi Barbs09
    I have a few of these also and had a look at converting the existing control board to variable however it doesnt really lend itself to modification. A much better approach is to simply use a third party regulator board assembly as a driver for the power transistors and power transformer,diode bridge, caps, etc. The original board didnt do a very good job of regulating the output voltage in any case. While it is capable of high current (about 12 amps peak) the voltage vary by more than a volt or so between 0 and 12 amps. The newer variable chip regulators do a far better job and you can buy a pre-assemble unit for less than $20 in Australia from Jaycar Electronics. The circuit I have is on paper and is A3 size! I havent bothered scanning it as I cant see the point in fixing these regulators as the design is too old and inefficient. Anyway I can probably scan it if you really want it. Cheers Tim
  • Tim Terry Feb 09, 2010
    OK I will scan in the schematic for you so you better send me your email address so I can email a PDF to you. Cheers Tim
  • Motorola Master
  • 32,281 Answers
One of the most common type is the 3 pin - 1 amp voltage regulators in a TO-220 package, they are the 78xx positive regulators and the 79xx negative regulators. The xx denoted the voltage output of the regulator.
I don't know what type of regulator is used in the APN 6003, if you can obtain a circuit diagram it might help you.
Posted on Sep 27, 2009
My APEX tv model no.pf2720........does not want to
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
If the power supply regulator section work properly, check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked above.
Oct 20, 2014 | Televison & Video
Power problems power stays on cant transmit or recieve
the power switch is fused shut you need to replace it and also the 5v logic supply regulator has failed perhaps this prob means there is no supply too the PLL and logic
this can all be caused by poor quality cheep power switched employed in every cb ive ever serviced rubbish and cruddy so check for all voltages and when and where you need them work from this
then youll quickly find the issue
Feb 19, 2014 | Connex 3300 240-Channels Base CB Radio
Cobra 148 gtl cb no recive, the power supply put 20+volts inti it, what could be the problom.
Your power supply is providing 20 volts? THAT is the problem. This radio should be connected to a power supply capable of providing anywhere between 12 ~ 13.8 VDC. Twenty volts is WAY too much. You may have cause significant damage to the radio if it was connected to that voltage for any period of time.
Jan 12, 2013 | Cobra 148 GTL 120-Channels Base CB Radio
Cb is buzzing when i hooked it up in the house
If a cobra 29 as indicated here what are you using for power for it? If a base radio as indicated it also has a 12 volt connection--if no problem via the 12 volt connection the fault is in the built in power supply the radio has.
All "Base" radios have 12 volt connection and their own internal power supply to operate off wall voltage.
Apr 23, 2012 | Cobra 29 WX NW ST 40-Channels Base CB...
RCI 2990 WON'T TURN ON IT BLINK AN GO OFF
you have hooked it up backwards. You blew the polarity protection diode. It needs to be replaced.
Nov 07, 2010 | Ranger Communications RCI-6900F-25 CB...
Fujitsu siemens scaleo 600 desktop just keeps shutting down any ideas
1) Bad Power Supply. Power Supply has a weak voltage power rail.
Electrolytic Capacitors are breaking down inside the Power Supply.
http://en.wikipedia.org/wiki/Switched-mode_power_supply
The capacitors build up a charge long enough to work briefly, then break down.
2) Electrolytic Capacitors on the motherboard are breaking down. Specifically the one's used in the motherboard Voltage Regulator Circuit.
A) http://www.hardwaresecrets.com/article/616
B) Visually identifying bad capacitors,
http://www.capacitorlab.com/visible-failures/index.htm
C) Video showing what happens with bad capacitors (Electrolytic) in the motherboard Voltage Regulator Circuit (Starts at 0:04)
http://www.youtube.com/watch?v=KN6_-8fYHo0
Await your further diagnoses.
May 23, 2010 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
Was talking on cb and power supply went to beeping and will not quit. Unplugged it and plugged it back in and still does it. I have a Galaxy DX98VHP hooked up to it in a scale house. Took cb off and it...
THE BEEPS INDICATE THAT THE OVERVOLTAGE PROTECTION IS ACTIVATED,DO NOT HOOK UP ANY THING TO THAT POWER SUPPLY!!!OR THE FULL UNREGULATED VOLTAGE (20-30 VOLTS)WILL PASS FROM THE SHORTED REGULATOR TRANSISTORS TRHU YOUR GALAXY AND FRY IT.GET IT TESTED BY A PRO,USUALLY THE REPLACEMENT PARTS FOR POWER SUPPLY ARE DIRT CHEAP.
GOOD LUCK.
Sep 11, 2009 | Pyramid (PS36KX) 600-Watt Power Supply
Galaxy 88hl stuck on 24.178
Hello radiogeek,
it sounds like you have a bad voltage regulator since you are indicating that the voltage adjusted by L17 is random. Check all of your voltages from the power supply (regulator side), and make sure they are stable. You will find that you may have a bad voltage regulation circuit or a bad capacitor in the unit power supply.
Thank you,
Shuttle83
Nov 26, 2007 | Galaxy Radios DX- 88HL Base CB Radio
POWER SUPPLY UNIT
Hi, you can almost bet anything that your voltage regulator is at fault. It sounds as if this needs time to build enough resistence to reach the 240 volts required by your computer's PSU.
Change this unit and you should cure your problem.
Question, Why do you need to use a voltage regulator?
Are you running on home generator power?
If you run on mains regulated power then replace the voltage regulator with a power surge protection board.
Regards mistyman
Nov 06, 2007 | Computers & Internet
Computers & Internet Logo
450 people viewed this question
Top Motorola Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Motorola Computer and Internet Expert? Answer questions, earn points and help others
