Question about Gigabyte GA-EP45-UD3L Motherboard
During initial configuration and build of the system, when the system tries to boot it recognizes the IDE hard drive but places it on channel 4. That's as far as it gets, it will not boot into the operating system. I only have the IDE hard drive connected to the motherboard, the graphics card, and 4G of ram. I am, however, able to get into the BIOS and change the settings if I want to.
    Scholar:
  • 138 Answers
Try changing the settings on the BIOS, like drive configuration and boot sequence/priority. also check the jumper on the OS HDD and make sure that it is on Master.
Posted on Sep 27, 2009
Messed up an IDE partition now BIOS won't recognize drive, can this be fixed or is there a workaround?
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your operating system and computer Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter Change the first boot device to your hard drive.
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ? Hope this helps.
Dec 09, 2012 | Computers & Internet
This is what mine says when I turn on Intel UNDI, PXE-2 . 1 (BUILD 082) Copyright (C) 1997-2000 Intel Corporation For Atheros PCIE Ethernet Controller v1.0.0.5(01/22/09) Check cable connection..
You hard drive is missing from the system. Just does not recognize it.
Remove the hard drive and reseat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Oct 25, 2012 | Acer Aspire One Netbook 8.9" Notebook
Bootmgr is mising/cant install win 7 on seagate HDD configuration problem
There are a number of possible causes for BOOTMGR errors, including the most common "BOOTMGR is missing" error message.
The most common reasons for BOOTMGR errors include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors an outdated BIOS and damaged or loose IDE cables
Anothe reason you might see BOOTMGR errors is if your PC is trying to boott from a hard drive or flash drive that is not properly configured to be booted from. In other words, it's trying to boot from a non-bootable source. This also would apply to media on an optical drive or floppy drive that you're trying to boot from.
make sure there are no disks in cd floppy usb drives
Test all leads that attach to your hard drive including electrical extensions IDE,SATA
the leads from your ((MOTHERBOARD TO YOUR HARD DRIVE)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty
computers need data and power to travel through every working device and to continue its cycle and to have an end so any faulty leads will end up with a computer error
also make sure you have set it boot from you hard drive in BIOS
hope this helps
May 05, 2012 | Seagate Barracuda 7200.10 320 GB SATA Hard...
Bought a toshiba 80 gig har drive but don't know how to configure it. Can you help me?
if you mean to configure is load an operating system onto this hard drive
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you should go back and change the first boot device to your hard drive)
if you need more help with this post a reply
hope this helps
Aug 21, 2011 | Toshiba Computers & Internet
What are the 2 pins in the back for? master slave configurations? If so what jumper setting makes it a slave?
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
? single or master :::::
master with slave ::'::
???????????????? slave? :::':
note the plastic jumper is ' located at the rear of the hard drive next to the IDE/SATA lead/s
hope this helps
dont forget to vote
Feb 06, 2011 | Hitachi Deskstar 7K160 HDS721616PLA380 160...
ASUS K8S-MX Motherboard, but when I connect IDE
How were the partitions created on the SATA? Are they RAID configured from the other system? Does the new motherboard have the same support for your HD as the other system? Check the setup in the BIOS screen on both systems to make them identical as much as you can. According to Tom's Hardware: "In the SATA port configuration place you have up to four "mode" choices: IDE (or PATA) Emulation, native SATA, AHCI, or RAID." Check this section. Circe@pctechsonline.com
Dec 13, 2009 | ASUS K8S-MX Motherboard
Motherboard is not recognizing my hard drive during boot process
It's probably the jumper settings on the hard drive. You can try cable select but I usually prefer just setting it as a master. Let me know if that works.
Feb 21, 2009 | Abit TH7 Motherboard
Hard Drive not found after installing software.
  1. Boot to the bios with the HDD connected
  2. Turn on all the lock lights on keyboard (SCROLL< CAPS<NUM)
  3. Press ALT+E (Wait for Beep)
  4. Press ALT+F (Wait for Beep)
  5. Press ALT+B to reboot
  6. IDE redetect should initialize on boot.
  7. HDDs should now be seen
Sep 29, 2008 | Computers & Internet
My pc will not load up with windows xp eventually got into the bios page & found the hard drive didnt show up as been identified
Read this whole post you might want to try the last paragraph first.
Take your hard drive out of your computer. In another system configure that hard drive as a master using the jumpers on the back of the drive the configuration should be on the drive itself although it is sometimes obscured.
Set your drive as a slave, again with the jumpers. Install your hard drive and boot the system up.
If the other system does not boot up or if it boots up and cannot detect your hard drive or your hard drive appears empty it is bad. You have to replace it.
If you are successful in seeing with folders, remove the cmos battery from your system for 30 seconds then reinstall and boot it up. This will place your bios to factory defaults and it may detect it.
Mar 07, 2008 | Computers & Internet
How to format SATA drive
Hi, the setting will be in the BIOS menu. switch on and hit F2 or whatever it is for your motherboard (it should say on screen). then go to the HDD settings and enable SATA
Feb 20, 2008 | ASUS P4V8X-X Motherboard
Gigabyte GA-EP45-UD3L Motherboard Logo
122 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
