Question about Acer Aspire One PC Notebook
Have acer aspire netbook. what cable do I need to hook up to LCD?
  • Acer Master
  • 32,281 Answers
Do you want to connect an external LCD screen to your Acer laptop?
The Acer will have a blue 15pin Dsub female video connector. The standard 15pin monitor video cable will connect to the Acer's video port.
Posted on Sep 27, 2009
How do i fix white screen on my kav60 acer aspire one
The KAV60 is also the AOD250.
Netbook OFF, monitor OFF, connect an external monitor to the netbook's VGA port.
[You can use a VGA monitor. Looks like a small TV.
This is an example of a VGA port,
VGA connector Wikipedia the free encyclopedia
Note* VGA port doesn't have to be blue in color ]
Turn the monitor on. Turn the netbook on.
If there is no image shown on the external VGA monitor, press and hold down on the Fn key, and at the same time tap once on the Display Toggle-Over key.
(The F5 key is the Display Toggle-Over key)
No image on external VGA monitor?
Hold the Fn key down once more, and tap again on the F5 key.
Still no?
Problem is internal in netbook. Probably graphics chipset soldered to the motherboard.
Replace motherboard.
Image shows on external monitor?
Problem is with Video Cable or laptop LCD screen.
MOST of the time it's the Video Cable.
The Video Cable connects to the motherboard, in an area under the Keyboard. It then routes up under the left Hinge, and into the Display Panel.
Inside the Display Panel it then connects to the LCD screen.
With frequent opening and closing of the netbook, the Video Cable can be pulled on. This can cause damage to the Video Cable.
(Stretched/broken wires inside the sheath of the cable)
And/or it can cause the connection at the motherboard to be loose, and/or at the LCD screen.
Example of Acer Aspire One video cable,
For ACER Aspire One D250 LCD Screen Cable DC02000SB10 KAV60 New
You can remove the Video Cable, and check it's continuity with a multimeter, or if the cost is reasonable to you simply replace it.
8 to 10 dollar video cable is not the problem? Then problem is the LCD screen itself.
My money is on a loose video cable connection, or damaged video cable.
For additional questions or to have me clarify/simplify anything in my solution, please post in a Comment.
Regards,
joecoolvette
Jan 15, 2015 | Acer Computers & Internet
How do i swap outscreens form one acer aspire to another i have a old one and want to replace the screen on my other which got stepped on
Swapping out is not that tough.
What you do need to know however, is if the LCD screen from the older Aspire One netbook, will work in the 'other' one.
A newer model of Aspire One may Not have the same specifications of it's LCD screen, as one in per se, an older Aspire One.
The screen size may be comparable, the finish also. (Glossy or Matte)
But the voltage requirements, signal requirements, and other specs may be different.
This means also that the Video Cable will be different.
What to do?
You're going to have to remove the LCD screen out of the older Aspire One, and out of the 'other' Aspire One, and look at the information on the back of the LCD screens.
Look at the manufacturer, and model number.
Also of course, it will only take a few seconds to see if the Video Cables are compatible.
If they aren't, it isn't worth going any further.
[ In looking from a brief search, it seems all Aspire One laptop/mini's use a 40-pin video cable connector,
http://www.screenaid.com/acer-laptop-lcd-screens-aspire-one-c-40_14691.html
Looks good so far ]
If the older Aspire One LCD screen video cable, will not plug into the 'other' Aspire One motherboard, you can't use it. Can't use the older Aspire One LCD screen.
IF, the video cables appear to be exactly the same, then I would recommend looking up the specs for both LCD screens, on the internet.
Or post in a Comment on here, and I'll look it up.
(Manufacturer name, and model number's on back of both LCD screens)
Also a Primer;
An LCD screen cannot produce light. It needs an additional light source.
A Backlight is the additional light source.
A Backlight is a CCFL.
Cold Cathode Fluorescent lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
[ Note*
However your model may use LED lights for a Backlight, instead of Fluorescent lighting ]
A Inverter (screen Inverter) is used to convert the power from the laptop, for the LCD screen, and Backlight.
The LCD screen AND Inverter are a MATCHED unit.
This also needs to be looked up on the internet, to see if they are compatible, from the older Aspire One's LCD screen, to the 'other' Aspire One's screen Inverter.
There are MANY models of the Acer Aspire One.
I will post links to info I have on disassembly, to include replacing the LCD screen.
1) http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-acer
Where it states Aspire One, NAV50, click on the blue - One
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name (One) it may take up to 30 seconds before the first page comes up.
2) http://www.insidemylaptop.com/remove-screen-from-acer-aspire-one-netbook/
3) http://www.youtube.com/watch?v=CRw03PpRJfs
For additional questions please post in a Comment
Regards,
joecoolvette
Dec 04, 2011 | Acer Aspire One PC Notebook
Hello, ive plugged my charger into my acer aspire one netbook, but no chargin light comes on. when i press the power button it comes up green but the screen does not come on. ive hooked it up to an lcd but...
try this okay take out battery for five mins then replug the power cord in sometimes the sensor dont recgonize but if that dont work its the battery charger end that coulbe be messed up
Apr 11, 2011 | Acer Aspire One Netbook 8.9" Notebook
Screen going pink/red unless nearly closed
This is due to some loose contact of your LCD Cable connection or LCD Panel cable malfunction. Reinsert LCD panel cable in proper way and check else you need to replace the LCD Panel Cable.
Feb 13, 2011 | Acer Aspire One D150-1587 Netbook
Lcd problem green line aspire one zg5
either the onbaord graphics card is faulty, or your lcd screen is faulty.
try to plug a vga cable to it and send signal to the monitor/tv screen, is that works fine then its your lcd. if it doesnt then its the on board graohics card
Jul 09, 2010 | Acer Aspire One Netbook 8.9" Notebook
How do i connect acer apire one to lg lcd tv?
In order to connect your netbook to lcd tv your need a VGA or a HDMI cable( if your laptop has a hdmi port). Once you connect the netbook with the lcd tv you nned to use you tv remote to choose the input to pc or pc1 or HDMI depending the lcd tv. if you any futher questions please feel to ask.
Jul 08, 2010 | Acer Aspire One PC Notebook
Turns on (fans spinning, HD clicking), blank screen, no sounds
hi this issue is with ribbon cable it is connect between the mother board and your LCD screen. the cable required change. if you can change it OK other wise take it to nearest service center.
Jun 15, 2010 | Acer Aspire One Netbook 8.9" Notebook
I am using netbook AOD250. I need to know how I can link to LCD TV to see big screening? I tried to press Fn+F6 or Fn+F7.....but it did not work.Please show me how I shall do.
USE LCD TV TUNER CARD FOR NETBOOK
and also try VGA cables
find out more at
www.geekwithlaptop.com/how-to-connect-laptop-to-tv
like this........?
vote me.........
Apr 02, 2010 | Acer Aspire One AOD250-1326 Netbook
Im trying to hook up my acer aspire one to tv via vga cable but cant seem to get it right.....any one know what to do?
after you hook it up try holding the fn key and pressing f5... this should work... hope it helps...
Feb 16, 2010 | Acer Aspire One Netbook 8.9" Notebook
How to clear cmos in a netbook Acer Aspire One model KAV10 ?
you will need to disassemble the netbook to expose the system board. Look for a small cable with a "cmos" tag. remove the cable for about 15 minutes. reinstall the cable and reassemble the netbook
Sep 23, 2009 | Computers & Internet
Acer Aspire One  PC Notebook Logo
134 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
