Question about JVC PD-42WV74 42 in. Plasma EDTV
Dansai d21s tv has been code loked and has no remote control
0 characters
1 Points
Total Control Universal Remote. URC 4140. What is the 4 digit code to operate the above TV
Search Results
    [PDF]Total Control URC-4140 - Universal Remote Control Codes
    UNIVERSAL. Remote control. URC - 4140 ... Your TOTAL CONTROL can operate four devices: a Television, ... The TV, VCR/DVD, SAT and AUX keys select the device.... 4. Enter your four-digit code using the number keys. The red light will blink twice.... To set up your other devices, follow the same instructions above, only.
    Codes and links for a number of universal remote controls, including Sony, RCA, ... GE Remote Codes, General instructions for GE Universal 3 and 4 digit remote controls. ... This manual may work for a number of Philips-Magnavox remotes. ... Total Control URC-4140, PDF Instruction Manual (remote also known as Crest .
Jan 13, 2016 | Sanyo 42 in. LCD TV
How do I use a gamechanger remote to control LG TV?
How do I program ESPN game changer remote control - Fixya
Nov 21, 2010 - how do I program ESPN game changer remote control - RemoteControls question. ... You can also use the "Power Scan method": Turn TV off. ..... I need code for an lg bh100 dvd player .... I need the code for an emerson hd flat screentv using a universal Game Changer Remote control espn edition.
Game Changer Remote Programing Codes -
We Provide 20 for you about game changer remote programing codes- page 1. ... OEM remote control,OEM quality standard remote control for TV or STB 3. ... ZTH3607Use: universal Place of original: Guangdong China (. ... Samsung Tv Remote ControlCodes List · Remote Control Codes For Lg Tv Lcd · Universal Remote ...
Dec 18, 2015 | LG Flat Panel Televisions
Need a universal remote control code for Hisense tv
Four digit universal remote codes for Hisense TV are:
0073 0182 0216
Five digit universal remote code for Hisense tV with RCA RCR312W remote control is:
Dec 12, 2011 | Hisense LHDN32V66AUS 32 in. LCD TV
Hi i have MAXENT TV 50" plasma im loking for dish network remonte code to program on it please help
We show no codes listed for Maxent televisions. The best method for programming this remote is called a Power Scan, the steps are below:
Power Scan
1.) Hold down the clear "TV" button on the remote for four seconds, then press 500 pound ( #)
2.) Hold down the clear "TV" button on the remote for four seconds, press the big power button once.
3.) Press the channel up button once per second until the TV turns off then press pound (#).
Daniel Busa
DISH Network
Customer Service
May 08, 2011 | Maxent MX-50X1 50 in. Plasma Television
My TV panal has ben loked. How can i remove this??? TV name: IGO classic 20"
Sep 09, 2010 | Flat Panel Televisions
Akai lct2715 directv remote code
I can help you with your Akai LCD TV & DirecTV remote control.
This is a list of all the Akai LCD TV control codes for DIrecTV remote controls:
11675, 11676, 11688, 11689, 11692, 11693, & 11935.
Complete instructions on entering DirecTV remote control codes are here.
I hope that helps.
DirecTV Remote Control Code List Download
DirecTV Remote Control Manual Download
DirecTV Remote Control Code Entry
DirecTV Remote Control Code Search
DirecTV Remote Control Onscreen Setup
Apr 28, 2010 | Akai LCT2715 27 in. LCD Television
Need codes for remote control access to go with Comcast hd adapter remote. Only 2 listed with remote from Comcast: #'s11723, 12066 Comcast remote will not control TV
If you look at the instruction under 'search for your codes' it will tell you how to scan all the code until you find the one that will work. Down load the manual here for your remote:
If your home entertainment device does
not respond to the remote control after
trying all of the codes listed for your
brand, or if your brand is not listed at all,
try searching for your code.
For example, after trying all of the
codes for your TV, you still cannot get
the remote control to operate your TV,
1. Turn on your TV.
2. On the remote control, press TV
once. Then press and hold Setup
until the TV key blinks twice, then
release Setup.
3. Enter 9 - 9 - 1. The TV key will
blink twice.
4. Aim the remote control at the the
TV and slowly alternate between
pressing Power and TV.
Stop when the TV turns off. A
working code has been found.
NOTE: In the search mode, the
remote control will send IR codes
from its library to the selected device,
starting with the most popular code
5. Press Setup once to lock in the
code.The TV key will blink twice.
Nov 02, 2009 | TruTech PVS31170S1W 17 in. LCD Television
JVC PD-42WV74 42 in. Plasma EDTV Logo
Top JVC Flat Panel Televisions Experts
Are you a JVC Flat Panel Television Expert? Answer questions, earn points and help others
