Question about Kenmore Elite 45986 Front Load Washer
Im getting spots on my clothes when they come out of the wash and they wont wash out. We dont have oily clothes and use the right about of detergent and softner. What would cause the oil looking spots about the size of a quarter
  • 909 Answers
Those spots are the results of undissolved soaps built up in the machine over a period of time. Very possibly to much soap is being used on each wash as well. It creates a thick film around the inner drum that eventually breaks away and deposits itself on the clothes in small quantities. To remove, that could be costly, so the next best thing to do would be to run at least 2 hot washes a day without clothes until soap eventually dissolves.It will take a period of time.until particles clear.
Posted on Sep 27, 2009
LG Tromm WM2233HW- Problem with oily residue on clothes
Use warm water and powdered detergent. Leave the door open in between cycles and it will be clean as a whistle in a week... Powdered detergent is HE also, don't believe the hype, stop wasting your money on useless chemicals to rinse away the garbage chemical soaps you are being ripped-off by... Hopefully, the liquid detergent hasn't corroded the washtub and drive shaft so badly it is oozing slime!
Jul 26, 2016 | LG Washing Machines
Leaving detergent spots. the machine fills up with water washes drains leaves detergent spots on clothes
If you dissolve the detergent in a bucket of water before adding it to the clothes you wont get this problem.
Nov 14, 2011 | Crosley CAWC529JQ Top Load Washer
The problem with my top loder panasonic washing machine is clothes dont come out clean.the liquid detergevt that i use does not always dissolve during wash and asa result clothes stiil soapyz.there are...
If you have the user's manual for this machine, check to see that you are using the recommended detergent and the correct quantity of detergent. Some machines will actually fail mechanically from using the wrong type of detergent (such as using standard detergent in a high-efdficiency washer). The pH (softness/hardness) of your water also determines how thoroughly the detergent dissolves and rinses from clothes.
Panasonic (
Q2. Why are there black stains on clothes after washing?
A2.May be your washing machine is dirty due to the residual accumulated through times and need to be overhauled. The possibility is that, a build up caused by interaction of fabric softener and detergent which can flake off from washing machine tub and stains the clothes. Try to dilute and dissolve the softener before putting it into the machine to reduce such black stains.
Spotting can also be a reaction between detergent and fabric softener, a leaking washing machine transmission, or excessive deposits of detergent or fabric softener in the tub flaking off during the wash cycle.
Good luck from Detroit, MI, USA.
Mar 01, 2011 | Washing Machines
Washer depositing oily stains on clothing HELP
Best way is the old fashioned way. Purchase some soda chrystals and pop them in ur drw. The same amount as you would normally use in detergent powder. Then put the washer on the hottest setting and wash the machine out. Do not put any clothes in the washer at the same time though. This will clean the washer it may take a couple of attempts to clean but doing this once a month will keep on top of it.
Hope this helps
Mar 28, 2010 | Whirlpool Washing Machines
Greasy looking spots on clothing after washing/drying.
Without seeing the spots, this is a bit speculative, but here goes,......
I'm guessing that the spots are only found on the front side, primarily of shirts, or blouses, etc. These are from grease splatters from cooking, which many times only show up after washing and drying.
The soap releases some dirt, which is attracted to the non-removed grease spot, allowing it to show up. Re-wash the clothing, pre-spotting those areas with a citrus pre-spotter.
Aug 31, 2009 | LG WM0642H
My maytag neptune is not getting clothes clean
SPOT COULD BE DETERGENT OR SOFTNER IF YOU USE IT- TRY DISOLVING DETERGENT IN WARM WATER BEFORE ADDING IT TO THE MACHINE- THIS WILL TELL YOU IF IT IS THE FAULT.
INSUFFIENT WATER WILL ALSO CAUSE THIS PROBLEM. SO WILL OVERLOADING
Jul 08, 2009 | Washing Machines
Clothes come out oily after wash
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
You said,you have a Eurotech front loader. Lately you have observed that your cotton materials come out with oily spots after wash. What can one use to address this problem.
In most front loaders when this happens it is usually either of two things.
1.Front loaders must have HE detergent for their use and if you do not use HE detergent you must cut your detergent and bleach in half.
Because to much detergent destroys your seal and eventually your bearings! And any other rubber seals like the rubber door seal in the front opening.
These degrade and get into the wash and depending on the color of the rubber (Black or gray) are found to stain your clothing or leave a residue in those colors.!
Those washers with Grey rubber like Maytag's have gray stains and or residues!
I have people asking me about this problem every day!
Call the manufacturer and ask if they have any cleaner that you can run once with out clothes to put an end to this!
And then use HE detergent and or half the dose of bleach form now on!
I hope this brings some lihgt to your problem. Please let me know what the Eurotech proplr tell you to use to clean it out of your washer!
Please remember to leave a rating before you go!
Thank you
Sep 29, 2008 | EuroTech EWC177 Front Load Washer / Dryer
6 years old hoover washer dryer. Not all, but some light colored tee shirts coming out with what appears to be oily spots. Tried bleach and dishwater tablet as suggested by another forum, but to no avail....
Hi there monobloc,
I've gone through this too. Dishwashing liquid soap, specifically with grease cutting properties. It does take a few cycles to clean it all out though.
Mike
Sep 01, 2008 | Hoover Washing Machines
Can you use Oxyclean along with detergent in front loaders?
I use 2 Tablespoons of Liquid Detergent and a 1/2 to 3/4 scoop of Oxyclean and I have had good results in my Front Loader. Clothes come out very clean and there is no residue on the inside of my washer.
Jul 26, 2008 | Frigidaire ATF6000ES Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
189 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
