Question about Logitech Cordless Desktop EX110
Negative terminal under right button corrodes and critical battery notice pops up
  • 52 Answers
Use steel wool and wd 40 to clean terminal and to keep it clean, just rub a small bit of universal grease on it and replace battery. It should be fine.
Posted on Sep 27, 2009
I am trying to replace the battery for a '97 Suzuki Sidekick. The battery terminals were so corroded, I had to cut the wire and put on some universal terminals. There are two wires for each terminal-
This happens in the shop all the time. It is not necessary to remove the alarm if you have the remote for the alarm. Simply hook the battery up and press the button to turn the alarm off.
Nov 23, 2011 | 1997 Suzuki Sidekick
Tip
How to jump start a vehicle safely
You have a dead battery and need a jump start. There is the right way and the wrong way to accomplish a jump start safely. Because of the potentially severe hazards due to improper use of jumper cables it must be done correctly. Auto batteries contain Sulphuric Acid which can blind you, or at the very least burn your skin. Also auto batteries vent off Hydrogen Gas which is highly explosive even from the slightest spark. Because of this danger it is critical to attach the jumper cables in a precise sequence. 1. Park the vehicle with the GOOD battery close to the vehicle with the BAD battery but do not let the vehicle touch each other. Make sure the cables are not routed so as to touch any moving parts, such as a fan blade. 2. Attach the jumper cable Positive + terminal to the GOOD battery Positive + terminal. 3. Attach the other end of the jumper cable Positive + terminal to the BAD battery Positive + terminal. 4. Attach the Negative - jumper cable terminal to the GOOD battery Negative - terminal. 5. Attach the last jumper cable Negative - terminal to a heavy metal ground part of the engine and NOT to the dead battery Negative - terminal. Reason being this last connection will cause a spark, and you do not want a spark next to the battery where it could ignite the Hydrogen. 6. If the engine of the donor vehicle with the good battery was not left running, start the engine and let it run for 2-3 minutes to put a charge in the bad battery. 7. Start the vehicle with the BAD battery and then remove the jumper cables from the batteries in the exact opposite order you installed them.
on Jun 19, 2010 | Honda Accord Cars & Trucks
2001 taurus random stalling. try to restart get click,click click. after several trys starts fine with no noticable slowdown of starter rpm.
Try cleaning and retightening the connections at your battery terminals. Corrosion will cause a bad connection, especially on the negative side. Also make sure the battery cable isn't corroded where it attatches to the clamp itself. Sometimes those will cause a weak connection....Mike
Jul 18, 2011 | 2001 Ford Taurus
1982 pontiac firebird wont turn over, push on clutch turn key only one click.
This is a sign of inadequate power to the starter. This can be from a tired battery or corroded cable terminals at the battery, the input terminal of the starter or a corroded connection between the negative battery terminal or chassis to engine.
Mar 24, 2011 | 1983 Pontiac Firebird
Negative and positive termanals not marked on speaker for instqllation does it matter?
It matters. Get a 9-volt battery and touch it to the terminals. When the positive side of the 9-volt is connected to the positive speaker terminal, the cone will pop out. If it pops in, then the positive side of the battery is touching the negative speaker terminal.
NOTE: A subwoofer should be strong enough to handle this. If you try this with a small speaker you can damage it!
Nov 08, 2010 | Pyle (PLBW124) Car Subwoofer
How to change corroded earth cable on VW POLO
The negative cable from battery must go to body/earth
If you connect to engine you will have no decent earth for electrics as engine has rubber mounts
Is your corroded terminal causing problems,if not pour boiling water over,let cool,remove and clean.apply terminal grease
Mar 07, 2010 | 1999 Volkswagen Passat
883 sportster, got the seat off, see the positive
No, you don't have to take the oil tank off you just need the right tools. I use a long Phillips screwdriver if the bolt has the provisions for it's use. If not, I a 1/4" drive extension with a 10mm socket on it and a rachet. Works for me. Always disconnect the negative side first. Then connect your battery tender wire to the positive terminal. Reconnect the negative side last. This my keep you from arcing the battery to the oil tank and maybe popping a hole in the tank.
Jan 11, 2010 | 2007 Harley Davidson XL 883 Sportster
When trying to start it makes a a winding noise maybe like a relay switch. when you turn on the key on the driver side under hood you can hear a clicking/winding noise and the starter doesn't even turnover...
First check your battery, if it is OK, then it can be corroded terminals at the battery itself or where the heavy cables terminate; at the starter input terminal (+ cable) and where the negative is attached to either the block or chassis. Both ends of these cables should be cleaned now and then and either dielectric grease or even petroleum jelly can provide some protection against renewed corrosion. NOTE: ALWAYS disconnect the negative battery terminal first! If a tool slips and ends up between the + terminal and any grounded point, it may melt the tool. If the negative is first to be disconnected, it doesn't matter if you slip on this one.
Nov 29, 2009 | 1997 Nissan Pathfinder
What is the negative battery cable bolted to and do I have to remove the battery to replace the cable?
The negative terminal on the battery is the one with the minus, usually the positive is red.
Disconnect the negative cable from the battery for safety. Then follow the cable to where it attaches to either the engine block or the body. They unbolt it and replace it.
You shouldn't have to remove the battery for this. Just don't mess with the positive terminal. You will have to reset the radio stations etc since battery is disconnected.
If the connection at the negative side is corroded, just cut it and reconnect it with a new battery terminal. A parts store can hook you up with that.
Nov 07, 2009 | 2000 Nissan Quest
Internal battery terminal corroded and fell off
Old batteries leak and the battery terminals corrode. Replace the terminals and clean the area thoroughly.
Jul 27, 2017 | Canon Optics
Logitech Cordless Desktop EX110 Logo
32 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
