Iam a technician i have this plasma there are random colors some place on the screen some lights and fuzzy colors do u know wich board is bad?
  • 5,138 Answers
What is your Brand and Model#?
Posted on Sep 29, 2009
  • 555 Answers
Sounds like noise is causing the issue. Could you provide brand and model number?
My samsung plasma PN60E550 lost resolution and screen is fuzzy and has incorrect colors.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Sep 26, 2016 | Samsung PN60E550 60 1080p 3D Plasma HDTV
I have a 65" lg plasma tv and I recently replaced s few capacitors that were bad and the tv worked beautifully, yesteddy morning I was watching and suddenly the tv went dim and fuzzy like snow but I still...
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
After replacement of the power board, Va&VS voltages are to be set according to the silk screen; can be located at the display panel, and it is a must for plasma displays.
Nov 06, 2014 | Televison & Video
Panasonic TH-50PX60U 50 in. Plasma: No blinking light but screen is nothing but color vertical lines. Which board is the likely culprit?
Sounds like COF [Chip On Film] fault. Contact any service technician. To get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD & Plasma screens are given with illustrations. You can get an idea about the fault to an extent.
Sep 13, 2014 | Panasonic TH-50PX60U 50 in. Plasma HDTV
LG 42 Plasma has a black Fuzzy Screen when 1st turned on
No, if ANY of the fuses were bad, the television wouldn't operate at all. I suspect that a technician will have to possibly make adjustments to the Y-sus and Z-sus panels to see if that helps. Possibly the y-sus panel is going bad or the plasma panel is going bad itself. Either way you need to have a technician look at the TV for you. Please take a few moments to rate my answer. Thank you.
Nov 18, 2009 | LG RU-42PX10 42 in. HD-Ready Plasma...
42 sony wega plama veritcal line
The PDP ( plasma display panel) is defect.You can look for badly soldered SMD resistors on the COF panels wich are located at the bottom of the screen.
Beware,the flatcables wich the resistors are located on are verry fragile!
Nov 02, 2009 | Sony WEGA KZ-42TS1 42 in. Plasma...
Hp-r5012
How long is a piece of string?
There are 2 boards called sustain boards inside the set. Either one of them or both could be the culprit. Unless you have electronic skill, the right tools and know how to retune the set, I would siuggest this is not a DIY job. Some willsay it is just a matter of unplugging the boards and replacing them, howver that is a short lived fix in a majority of the cases i read on here.
Yes it does work for a while, then other problems arise.. conergence drops out, power fails and a myriad of other things happen that would normally be measured and checked by a good repair technician. It ends up costing 2-3 times more than if it was done professionally. The decision is yours, but i can only advise you NOT to.
Thanks for using FIXYA
Sep 27, 2009 | Philips 42PF7220A 42 in. Plasma Television
Colored spots on dlp tv screen
coloue spots on screen. how do you fix with screwdriver?
Jul 22, 2008 | Panasonic PT-52LCX65 44" HDTV
No pic
SOUNDS LIKE YOU HAVE A BAD Z-SUS BOARD...LOOKING FROM REAR OF SET WITH BACK COVER OFF..ITS ON RIGHT SIDE..CALL ANDREWS ELECTRONICS IN CALIFORNIA WITH MODEL #..THEY WILL GIVE YOU A PRICE AND PART #...JOE ACE
May 15, 2008 | Samsung SPN4235 42 in. Plasma HDTV
My "42" inch sansui plasma monitor
You don't have any magnet anywhere near the TV do you ?
If not it sounds like something magnetic is interferring with the picture.
If not get the warranty out :D
Dec 16, 2007 | Sansui HDPDP4200 42 in. HD-Ready Plasma...
Televison & Video Logo
Top Televison & Video Experts
