First found that freezer door not closed correctly and then became iced up. defrosted and sinced noticed that freezer unit not cooling and the red and green lights are on. The compressor is running but i cannot feel any cooling.
Bulmer...it takes about two days to fully defrost these units unless you take the freezer section cover off and use a heat source. If you do...be sure to protect yourself against water and electricity mixing....not healthy. See below for another note.
clean the condenser coils below the unit.
check for the amount of gas in the unit. It must be off for half an hour. Remove the back fiber panel. The big thing is the compressor. Clean off the largest pipe coming out of it. Plug the unit in...watch out for the fan! The pipe should frost up and then clear off or stay wet after about 5 minutes. It should not be frosty. If it is, you need refrigerant.
Note: If you do remove the inside freezer panel and defrost, you can see how much refrigerant you have in your unit. Start the unit. Wait 5 minutes and observe the coils. They should be evenly frosted end to end. If approximately so, you're good. If not, you're low on gas.
green and red light staying on, small switch giving option of 0-or economy, but making no difference either way lights still staying on.
The tempature display for the fridge and freezer are blank. The other day everything began to defrost. That could be due to the door being cracked a bit but I didn't notice that it was all I noticed was that my ice was half melted. Seems to be cooling fine now but the display in inop. I do hear beeping when I press the cooler amd warmer buttons.
freezer cooling unit not icing
