My Sony SCN RZ30 camera worked perfectly for about two years and I could access it from the internet. Recently it suddenly stopped being accessible from the internet. Now when I power it up it looks like it goes through an initialization procedure, the power light comes on and I can see a picture from it when I attach the camera to a TV using the video connection. However when I attach it to the network through a cable I know works the light on the camera labeled network does not come on and I can't get to the camera either through the internet or my local internal network. Is my network hardware in the camera bad--can it be replaced?
Comments:
Sep 27, 2009
- I actually tried all the options you mention. I am pretty sure the problem is in the camera itself. If it is, are there ways to get the camera fixed?
It is most probably a network connection problem between the camera and your network. Chances are, the camera cannot gain internet connection.
If the network led light on the camera does not light at all, then you can try to trouble shoot the problem by doing the following:
1. Try to plug the network cable to a different port of the switch or router. 2. Try to change the UTP or network cable of the camera. 3. Check on the network settings of the camera. The IP address might have changed. If it came with an installation cd, you can re-install it again.
yes there is a internal chip that gets faulty.which actually detects to which source the camera is connected.if that chip becomes weak or faulty.it stops detecting the sources to which it is connected.but the possibility of getting it repaired is very rare.if the chip becomes completely faulty ,then new replacement chip is not available.any local web-cam,camera electronics repair shop if they have same camera they can get the second hand chip replaced in the camera.but if there is the problem of chip getting weak then it can be re-soldered and camera will become proper.so the local camera repair electronics repair shop has to check for this possibilities.but if the chip is got faulty then getting it replaced with second hand chip is not advisable .because there is guarantee as how much this chip will last.
thanks.this will help.please do rate the solution.thank you for using fixya.keep updated.
Popular Solutions for Sony SNC-RZ30N Network Camera
can not send mail through isp for sncrz30 There is no option to add user and pass that the isp...
(More)
can not send mail through isp for sncrz30 There is no option to add user and pass that the isp requires so if you want to send an image automatically it fails can not contact server Later models have a radio button Are we stuck with this?
Actually it's a Sony SNC-RZ25P. Anyway it does not seem to be able to send e-mails through the...
(More)
Actually it's a Sony SNC-RZ25P. Anyway it does not seem to be able to send e-mails through the computer it's connected to, although I am able to create an E-mail account using the same smtp server settings that succeeds in sending an e-mail on that computer. Perhaps someting with the network settings on the camera? I haven't entered DNS addresses.
System log shows, "SMTP Server was disconected". Trying to send to either Gmail server or...
(More)
System log shows, "SMTP Server was disconected". Trying to send to either Gmail server or GoDaddy. Neither seem to work. Is there something on my PC that needs to be enabled to make this work?
