Question about Tomtom ONE GPS Receiver
Tomtom 3rd edition
Every time unit is turned off and then on screen is blank and unit needs to be reset
  • 24 more comments
  • Anonymous Dec 18, 2007
    Everytime I restart the unit it just goes to a white screen. I have to reset it if I want it to work. Whats the problem?
  • Anonymous Dec 19, 2007
    the tomtom is new but will not turn on it only was used one day only the green light comes on when pluged in
  • daveylog Dec 19, 2007
    We just bought a new TomTom One and we keep having to "reset" it to get a screen. The screen is just white if we don't hit reset. You can hear the voice talking through the white screen but no images. Please help.
  • Anonymous Dec 20, 2007
    When turning the unit on, screen is white, after reset it works properly. Then it will happen again with the next cycle and the only way to get it to work is to reset it. Any ideas?
  • patella Dec 20, 2007
    I also am having a problem with startup screen being white when I start it up. Once I hit the reset button the unit comes on perfectly. Looking for advice on how to correct without having to hit reset everytime I shut down. Thanks
    I just talked to Tomtom, there seems to be no fix you have to send it in and get a new one in return. They will pay for shipping and said it would take 1-2 weeks after they receive it to get a new unit back to you.
  • Tom991 Dec 21, 2007
  • Anonymous Dec 21, 2007
    word.
  • Smylie Dec 21, 2007
    I have to reset 3rd edition each time to remove grey screen
  • keithrow Dec 22, 2007
    when gps is turned on it has a white screen, it has to be reset. it is just a big pain!!!!!!!
  • Anonymous Dec 22, 2007
    Same White screen, you have to reset it to get it to work, but once turned off agian another white screen, Bad Bad tom tom
    I found that the Tom Tom one r3rd edition worked fine until I hooked it to my computer, and E machine, via the USB cable. Then when I turned it on all I got was the white screen until I reset it. It has something to do with the computer hook up. I then tried it on my Dell, and I was able to access the computer but I still have to reset before each time I start the unit up.
  • Anonymous Dec 24, 2007
    Same thing here, I contacted TomTom support right away(quickest way by phone) and they will tell you to send back the device and they will send you a new one. It doesn't seem like you can fix it on your own.
  • jpp113 Dec 25, 2007
    I also havethe same problem. White screen at start-up. Works when I hit the reset button.
  • Anonymous Dec 25, 2007
    Turn it off and white blank screen
    i bought two TomTom Ones for Christmas gifts. They both do the same thing - boots up fine the first time, then requires you to reset for each subsequent time you turn it on - otherwise all you get is a white screen. Obviously they have some serious problems with this model.
    I have the same blank screen when using the usb computer cable..
    I just got a brand new TomTom ONE 3rd Ed. and when I turn it on, all I get is a white screen. I have to reset every time I turn it off to get it to work.
  • RAGuest Dec 26, 2007
    New TomTom 3rd edition, and everytime I turn it on white screen, must restart it. It has the serial number that matches Y1348******.
  • stevehere Dec 26, 2007
    Always powers up with white screen. Only fix seems to be to reset.
  • fas8253 Dec 26, 2007
    Same thing. Works fine,but whenyou shut it off and turn it back on, white screen.
  • salom Dec 27, 2007
    I just purchased the Tom Tom One in Vancouver - the store recommended it as the "best product on market". Although the manager did warn me that the Tom Tom won't tell me what streets to turn on- he negected to inform me that the model is plagued with the "white screen problem" - so now I'm stuck with the same problem as so many others are & have to return the brand new Tom Tom for something that works. I guess I should have know when I turned it upside down and it said "Made in China"... I'll have to send this toy back with all the others this christmas.
  • stbrown Dec 27, 2007
    I turn unit on and get nothing but a white screen.
  • GoodyMA Dec 27, 2007
    Brand new Tomtom One 3rd Edition needs to be reset everytime to prevent white screen. So much for quality control.
  • Anonymous Dec 27, 2007
    Same problem . White screen after unit is turned off .Why didnt I see this comment when I researched tomtom1 on line? Bad bad tom tom! Apparently send the unit back when you have a few weeks of not needing it.
  • thedude01 Jul 30, 2008
    on my tomtom 3rd edition had whitescreen at begining and end tried the fix as discribed and it brought back origanal shutdown screen but still got white screen at startup and cant put any images on or i loose end screen as well
I had the same problem. I called TomTom and they sent out a new unit, Fedex. I had it two days later. They also sent a return authorization and label to return the bad unit.
GREAT customer service!
Posted on Jan 24, 2008
Quit buying ANYTHING made in China People
Posted on Dec 27, 2007
Per this forum: http://www.tomtomforums.com/showthread.php?t=5291&page=7
This is impacting 3 batches of units. The units can be identified via its serial number:
Impacted serial numbers: any serial number that contains 46,47 or 48
example: Y1348**********
Call TomTom and send it back, or look for replacement units, from the store of purchase, that do not include the impacted serial numbers
Posted on Dec 25, 2007
TomTom One 3rd Edtions with serial numbers that include any of the following numbers 45, 46, 47, or 48 are all defective and have the "white screen problem."
They've known about the problem but just kept selling the bad units.
Go here for more info: http://www.tomtomforums.com/ and look under TomTom One . . .
I think it has to do with hooking up your unit via the usb cable to the computer. I got one from Radio Shack and it worked fine for a day, drove with it and shut it on and off a couple of times. Then I hooked it up to my emachine computer, and all I got was a white screen. Took it back got another one, drove with it, turned it on and off a couple of times, worked fine. Then I hooked it up to my computer, and again the same white screen until I reset it. I noticed all these posts are in the last few days, so I would say it is a bad batch of units. I purchased one for my wife 3 weeks ago and no such problem.
Posted on Dec 22, 2007
3 Suggested Answers
SOURCE: Blank Screen
I was given one a week and a half before Christmas....white screen.... swapped it for one with the same problem and tried to go thru TomTom Support for a replacement. For Four days I talked to them and after waiting for a shipping label that they said I must have I gave up and took it back for a refund. I asked numerous times for them to help with an advanced replacement and was told it was against policy....good for you if you were able to get them to help you. Maybe they have changed their policy.....Thing is, I like the TomTom but the way they handled this widespread manufacturing problem left a bad taste in my mouth.
Posted on Jan 02, 2008
E61N
  • 515 Answers
SOURCE: tomtom 3rd edition
http://www.tomtom.com/support/index.php?Language=4&query=reset+button&FID=7134
Posted on Apr 30, 2008
Frozen screen on a tomtom 3rd edition(1gb)
Try holding down the power button until the unit shuts off and resets.
Apr 02, 2010 | Tomtom ONE 3rd Edition GPS
Tomtom one 3rd edition screen will not respond
Hi cltolen,
on the bottom of the unit you should see a tiny hole, just big enough to fit a straightened paperclip in to. There is a tiny reset button inside this hole.
Try pusing it with the paperclip then turn the unit back on.
Also make sure there is plenty of charge in the battery.
Good luck
Jan 31, 2010 | Tomtom ONE 3rd Edition GPS
Broken tomtom one 3rd edition
Try resetting the unit. Little black button labeled reset on bottom.
Jul 27, 2009 | Tomtom One Europe v2 GPS Receiver
Tom tom one 3rd ed only turn on one time now it will not turn on
Hello, Unplug your Tomtom device, batteries should be fully charged. The tricky thing to Tomtom devices is the ROM put into the device. It needs to be reset once in awhile. The soft reset is like formatting a hard drive but leaving the system files alone. At the bottom of the device, there is a reset button. You'll need to use the end of a paperclip to reset the unit. After it's reset, reinstall the Tomtom application only by using the Tomtom Home application. Let it reset itself and come back to the original screen, then go to menu and set your preferences. Also if it's connected to Tomtom home and if you backed up your data to your computer, reinstall your maps. The only time your Tomtom device gets bogged down and won't finish a reinstall is when all 1 GB of memory is used up. Hope this helps.
Jan 11, 2009 | Tomtom ONE 3rd Edition GPS
Clock
tap the screen for menu
tap change preferences
tap through 4 page screens and select "set Clock"
~ after you select the display style, a screen will appear to set the time.
luck!
Jun 01, 2008 | Tomtom ONE 3rd Edition GPS
Blank Screen
Contact TomTom. I had the same problem. Emailed customer support and they are sending me out a new unit. Not even asking me to send my unit to them first! how often does that happen....
Dec 31, 2007 | Tomtom ONE GPS Receiver
Tom Tom One
Is this a TomTom One 3rd Edition? If it is and if the blank screen that is coming up is completely white, a fix has been posted at http://www.tomtom.com/support/index.php?FID=8578&Lid=4
Before you install the update, be sure that you have the model and problem described. I hope this helps.
Dec 27, 2007 | GPS
Blank Screen in my TomTom ONE 3rd Edition
Got it for Xmas. Same thing blank screen. Called TomTom and they sent a Fedex return label free of charge.
Dec 27, 2007 | GPS
Tomtom ONE GPS Receiver Logo
1,448 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
