Question about Steinberg Cubase SX3
I am not getting an audio in signal in my mixer.
    Sergeant:
    Champion:
  • 289 Answers
Maybe some cords are loose, jiggle them all
Posted on Sep 27, 2009
  • Sean Blundy Sep 28, 2009
    well couldn't you of left me a reply on if it worked but no, you had to put a bad rating
Behringer connect
Try taking direct feeds from your 8 mic channels by connecting leads from the insert jacks to the inputs of the recorder. In order to not interrupt the signal path on the mixer channel push the jack all the way in and then pull out gently until you feel it click. Then you should get a direct signal going to the Tascam and still have control over the level via the fader.
Apr 01, 2014 | Behringer XENYX X2222USB Mixer
I can't get the 2tk input signal to come out through the monitor outs.
The routing is designed that way.
Connect the 2TK to your last line inputs and Voilaaa !
Peace
Feb 05, 2014 | Soundcraft EFX8 8Ch Multipurpose Compact...
I've connect my sampler to the mixer. In the RCA "send" and it won't play through my speakers. I can only hear it through the headphones. What could be the problem? I'm using Numark...
You would NOT connect an audio signal to the "send" jacks... those are OUTPUTS... In doing so you are driving signal backward enough to get to the headphones. Sends and returns are NORMALLY used on a mixer for external effects. You should either be using a LINE input jack or one for "tape input".
Sep 10, 2011 | Roland Sp404sx Portable Sampler Wdsp...
Why do i have echo when i play music on my phonic powerpod 820 mixer
Visit this link to download the manual if you don't have it already. https://phonic.box.net/shared/crqxhlhmmz
This mixer has a multi-effects processor onboard, but the key is understanding the audio signal chain. There is a chance that you have your input audio going through an undesired effect, but without knowing your setup (input source, connections, mixer settings), it would be difficult to pinpoint the problem.
Apr 04, 2011 | Phonic Powerpod 820 Mixer
Problem with new cdj mixer and decks
no is output level probably is 1.0v need 0,7v output, you need level atenuartor, you may find on audio stores
Jan 29, 2010 | Pioneer CDJ-200 CD Player
I cant make on microphone go thru my amp mixer
It's obvious that there is a misunderstanding. Your FCA202 is designed to get line level inputs (not microphone level) and convert the signal to digital format for the computer to "undestand", it's working like an audio card. So in your case all you need is a microphone preamplifier to pass the signal from your mic to FCA202, or an audio mixer to do that.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"????????? ???????"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Nov 23, 2009 | Behringer F-CONTROL AUDIO FCA202 External...
How to use yamaha mg102c with m audio usb
You must connect:
the mixer output to the "line|optical" input of the Transit
the mixer input to the line (in case of an analog signal) or to the optical (in case of a digital - optical signal)
The USB connector on the other side is going to be connected at the USB port of the pc.
Just keep in mind that the signal flow goes as the arrows on the Transit.
Thanks and regards
Stelios
Sep 05, 2009 | M-Audio Transit USB Sound Card
Signal Light Problems Yamaha P2500
Stereo amplifier = two channel..A and B.
1. Make sure that your stereo audio mixer has an output from LEFT going to amp channel A and output RIGHT going to channel B.
2. Check that the "Pan" control on your audio mixer is set to the 12:00 position.
3. Inputs to mixer...make sure the music/microphone input channels "Pan" controls are also set for 12:00 as well.
Jun 11, 2009 | Yamaha P-2500 Amplifier
Setting up my bands new pa!!!
You can work forwards from the mic to the speakers, or backwards from the speakers back to the mic.
The mixer and the amp both should have lights to indicate when there is signal present -- if you don't have lights at the mixer, then you won't have any sound downstream at the speakers. In this case, the problem is with the mixer or the sound source (mic or instrument)
If you *do* have lights at the amp, then the signal is getting that far, and the problem must be with the amp or the speakers.
Jun 02, 2009 | Marathon DJ-2000 Amplifier
Open Questions:
See all Steinberg Cubase SX3 Questions
Computers & Internet Logo
112 people viewed this question
Top Steinberg Computers & Internet Experts
Raghavendra Nagaraj
Raghavendra Nagaraj
Donald Currie III
Level 1 Expert
 Grubhead
Grubhead
Are you a Steinberg Computer and Internet Expert? Answer questions, earn points and help others
