Question about Refrigerators
Kenmore Elite stops cooling - Relay keeps cycling
We woke up this morning to find our frozen foods defrosting in our refrigerator. (Kenmore Elite model 106.50509990 black side-by-side)
Vacuuming out the coils under the unit was of no help. Every few minutes the relay (attached to the side of the compressor) clicks (on?) and then clicks again (off?) about 5 seconds later. The top of the compressor feels somewhat hot. From what I can see there is no ice built up behind the back panel of the freezer. What really seems funny is that the refrigerator side still seems to be cool, but the freezer side is rather warm. The repair company is backed up and cannot come out until Thursday (3 days). Can anyone please help. Thanks.
  • 1 more comment
  • k6_user Dec 18, 2007
    Yep, that did the trick!!!
    Thanks very much peyton32034, you truely are a "Guru"
    Thanks,
    Drew
  • jackerack Feb 24, 2008
    I had the same problem I smacked the compressor with my hand a few times and it worked for 3 days and quit again. I smacked it again and the relay plug on the compressor shorted out and started smoking. I unpluged imidiatly, pulled the wires and pluged in direct compressor started, I unpluged to see if it would keepstarting by itself but the therd time it froze up again. Do you think I need a new compressor ?
  • BornToLoose Apr 23, 2008
    I have the exact same problem, and I am nearly sure the faulty part is the "relay" as peyton32034 suggested. When I checked near the compressor for the relay, there was no cover for it because it melted. However I don't know what is the name of this "relay" so I can't go search for. My compressor is a "zem r134a 90aa" in Bosch refrigerator.
    Any idea how can I call/describe that "relay" part when I'll buy?
I had the same problem with my Kenmore refrigerator and the repairman said it was the relay sensor on the compressor. He said it will be easy to tell if the relay is out because you will hear things rattle inside when you shake it. He pulled th old relay off and I could hear the rattle inside like he said. He then showed me the new one and there were no sounds when I shook it. He put the new one on and it fixed our problem. I wish I had known this prior to calling the repairman because he charged me $275 for the repair. Looks like you can find the part on-line for around $50.
Posted on Jul 17, 2009
  • 410 Answers
The relay on the compressor is most likely the culprit part# 8201786 you can buy it at the local sears parts and repair center it is very easy to replace it. your refrig compartment will start warming up soon. to prevent damage to your compressor probably a good idea to unplug the refrig until you get the part replaced..
Posted on Dec 18, 2007
3 Suggested Answers
peyton32034
  • 410 Answers
SOURCE: Kenmore Elite refrigerator stops cooling - Relay keeps cycling
the relay on the compressor is most likely the culprit part# 8201786 you can buy it at the local sears parts and repair center it is very easy to replace it. your refrig compartment will start warming up soon. to prevent damage to your compressor probably a good idea to unplug the refrig until you get the part replaced..
hotuna
  • 288 Answers
The compressor is locked up. Basically it is stuck. You can pick up at the local appliance parts store a hard start relay, Home Depot ,Lowes, or or those guys wont have it. Its not too expensive and is worth trying because your only other option is you need to replace the compressor. The part is called a kick start or hard start, the guy at the parts store will know what you are talking about. It is simple to connect and has the wiring directions on it. Sometimes this is all it takes. I have been able to get a stuck compressor to go by placing a short 2x4 on it and whack it with a hammer a few times. This is only a temporary fix though, as it will eventually lock up again, but emergency situation this saved the food. If the fridge has a fan back there make sure it works too, it may have been the original cause. Good luck.
Posted on Dec 26, 2007
My Kenmore freezer model # 970-257320 is no longer keeping food frozen. Suggestions?
IF the unit is not self defrosting and there is ice, you may have ice blocking the evaporator coils. If the unit is self defrosting and is not completing a defrost cycle then the defrost timer is bad.
Apr 30, 2015 | Kenmore Refrigerators
Frigidaire FRS26LF8CS3 Side by Side, Freezer ice/cream melting, lower bin food side freezing
(There is a defrost heater on the evaporator in that area.If
you have a VOM you could check it with the power plug pulled out of the wall socket)
if you access the area turn the defrost timer on (clockwise)it should get warm in that area and you shoud hear a popping sound
If you want to tackle the job for yourself all the manuals are here
http://www.frigidaire.com/support/ResultsPage.asp?strModel=FRS26LF8CS3&User=&Search=Search
Nov 27, 2007 | Refrigerators
My kenmore elite side by side refrigerator isn't cooling properly
I need your model number I cannot pull up views without the model number. The number most times looks like 321.654987 Thank You, Sea Breeze
12_9_2012_3_01_59_pm.jpgKenmore
Dec 08, 2012 | Kenmore Elite Side By Side Refrigerator -...
The freezer side is cold & food is frozen, but the refrigerator side isn't keeping food cold. Its warm!!
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 28, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Have a Kenmore Model 59672912200. Not cooling. All food defrosted or cool. Refrigerator keeps coming on and off.
2 possibilities....faulty start relay (mounted on compressor),or bad compressor...try relay first,good luck
Mar 01, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Sears model 564.8780180
Try a new defrost timer..your mullion heaters are not on...
Aug 18, 2009 | Kenmore 53082 / 53084 Side by Side...
Fresh side not cooling
I will assume until you can confirm the model number is near Sears KENMORE ELITE, Model No. 10650594000 But I will need you to double check because Sears always uses a number different than the MFG.
For the moment I need you to remove some things from the freezer and remove the back panel covering the evaporator coils. Look for the coils to be frozen over. If so it could be the adaptive defrost control found inside the fresh food compartment part number 4388932
Or a problem with defrost thermostat or the defrost element. I am here to help, Just let me know, Sea Breeze
appliancepartsse@yahoo.com
http://servicepartstec.blogspot.com/
May 18, 2009 | Kenmore 57029 Side by Side Refrigerator
Refrigerators Logo
959 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
