Question about IBM ThinkPad R40 2681
My monitor display everythink like magnafied, what can i do to back to normal
  • IBM Master
  • 32,281 Answers
Change the screen resolution. Go to Control Panel - Display - Settings and change the Screen Resolution to 1024X768
If you still have problems, get back to me.
Posted on Sep 27, 2009
My colors its no good everythink shows more green its green everywhere
If your computer's graphics card is working ok and the monitor does the same thing connected to another computer and the lead from the computer to the monitor is tight, there are no damaged pins in the connector, the most likely problem is that your monitor is failing and it may be cheaper to consider getting a new one.
Absence of red and blue colours, which, with the green give you your picture, indicate a failing component in the monitor.
Jul 25, 2011 | HP L1702 17" LCD Monitor
I've installed Cossacks(the Art of War) in Windows 7 Professional.HP-Pavilion Slimline s5710F. The game come up with double vision still can't play everythink runs together.
Hello
Check the games video reqirements on the box or folder it came with.Sounds like your resoulution is off on your pc.
Go to control panel,personalize,display settings,Set the slider all the way to the right.Hit apply then reboot.
If this does not help check that the video options in the game itsself are set to you monitors settings.You may also need to update your video device drivers.
Mar 21, 2011 | Video Game Consoles & Games
If we power on the monitor the led blink and off imidiatly.all components in power supply is very good what is the problem
sravan74, You must also inspect with magnafying glass or low power microscope (10 to 20x) the solder joints of all the components soldered to the board!!! Look for dull, frosty looking connections and very fine "circular hairline fractures" around the leads of all "through-hole" and "surface-mounted" components. Report to me what you find. 12fixlouie
Aug 11, 2010 | Samsung 510N 15" Flat Panel LCD Monitor
Monitor says "Out of Range"
This normally happens when display resolution is changed to higher resolution and cannot be compatible/displayed by monitor. Either plug in another monitor and lower down resolution or Press F8 and go to advanced boot option and start your computer in safe mode and try changing display resolution. If it still doesn't works and you have the drivers for you display adapter (video card) then uninstall display adapter from device manager by booting in safe mode. Once you get to normal boot mode reinstall drivers for display adapter.
Jun 05, 2010 | Sceptre X20g-Naga III 20.1" LCD Monitor
Have 21 inch monitor dell st2210,mi problem is everythink desapere from the screen and later come back,lock picture is in the center of the monitor al the time i have 1 year waranty i call dell speak to...
Connect the monitor to some different computer, e.g., a laptop, to verify that the monitor is working.
If not, take it back to DELL/STAPLES, and get them to check it out, or to exercise the "warranty" to get it repaired/replaced.
May 14, 2010 | Dell ST2210 21" Monitor
Hello i just installed my chimei 19" lcd to my hard drive and i have connected it all up right it all loads up but when my screen comes on the little button on screen goes from green to red and says no...
Most probably your monitor has two inputs, one digital and one analog. Using the monitor's on screen menu select the other input and you should see your picture.
Dec 18, 2009 | Acer AL1916W 19" LCD Monitor
Monitor display is rotated 45 degrees. Can't get it back to normal.
right clik on the desktop and select graphic options then choose rotation. set to normal mode. fine ???
May 03, 2009 | HP Compaq Presario SR1110NX PC Desktop
Hannspree 19" HF199H LCD - Display is LARGE on monitor!
Try Control Panel - Appearance or Display- You can change how your 2nd display looks there.. Sounds like you have it set in Clone mode...(both displays show the same things)...See if you can reset the 2nd display resolution while keeping the laptop in its normal resolution. Not all machines can do this...but most recent ones should be able to.
Mar 27, 2009 | Hannspree 19" Widescreen LCD Flat Panel...
Need the polarity of the adapter for polyview v17e moniter
i'm guessing you don't have the original adaptor to test it... sometimes polarity is printed onto the case where the adaptor plugs in... get out your magnafying glass to see it tho.
Jan 02, 2009 | Polyview V17E 17" LCD Flat Panel Monitor
IBM ThinkPad R40 2681 Logo
52 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
