Projection T.V. will not operate?
I was watching my Hitatchi Ultravision Model #55UX58B when there was a slight but audible pop sound after which the T.V. went off. It would not come back on after several attempts to turn it back on via remote and manually with the off-on button on the set? I subsequently removed the back and unplugged the set. After a short time, when I plugged it back in, there were several green LED lights that came on, then another, after which they all went off. There was a slight audio sound that seemed to present at the same time whigh also went off.
    Genius:
  • 1,153 Answers
You will need to check E994, E996, D722, Q777, I901 some or one of these may get your set back going. If not you will need to record what LED's come on first and goes off first. It matters, because it tells techs what is wrong with set.
Posted on Dec 17, 2007
  • 119 Answers
It sounds like it is a mechanical problem (i think the ray tube broke)
it looks like the tv needs to be professionally repaired or replaced
ssry
  • Dick van Zalinge Dec 17, 2007
    ehh
    i mean the projection bulb
I have a rear projection Hitachi tv. Model no. 55ux58b. Today it made a popping sound and turned off. I unplugged it, waited a few hours and plugged it back in. When I did, I could see through back of the...
On this model there is a common failure with some capacitors and fuses. Its a simple fix if you know which parts to use/avoid and how to do the repair. You can get complete instrucitons and parts for your model from www.TvRepairKits.com . Their kits include step by step color instruction guide as well as the correct parts to fix this issue
Aug 19, 2010 | Hitachi 55UX58B 55" Rear Projection...
Made a very very low pop noise shut off - green
On this model there is a common failure with some capacitors and fuses. Its a simple fix if you know which parts to use/avoid and how to do the repair. You can get complete instrucitons and parts for your model from www.TvRepairKits.com . Their kits include step by step color instruction guide as well as the correct parts to fix this issue.
Apr 02, 2010 | Hitachi 55UX58B 55" Rear Projection...
Sony rear proj; kdf 55
If there is no picture but sound is audible then replacing the projection lamp will do otherwise, the TV requires to be diagnosed for any other hardware damages.
Aug 27, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Hitachi Ultravision Projection Tv problem
Hitachi TV also Model # 46UX7K, Serial # W1H002013. I was hoping I can get help with this one too. The picture is dark and has lost most of it's color. I don't know if the color is off because it is so dark. Is there parts that I can buy from you to fix this problem.
Aug 09, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Set will not operate?
your equipment is burned by an electricity discharge.. there is a tiny posibility that there is some sort of fuse there that you can change so it works.
other than that, if you want to fix it, you will need to take pictures so we could see what has been busted...
Dec 17, 2007 | Televison & Video
Hitachi model 55ux58b
how many times does the light blink?
Dec 10, 2007 | Hitachi 55UX58B 55" Rear Projection...
Hitatchi Ultravision LCD Widescreen acts like it doesn't want to power up
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 10, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Hitatchi Ultravision rear projection **NO POWER ***
Usually, when there is no sound, it is because something is not set right in the menu. The fact that the set has shut off completely is quite common in that set. There is a little blue capacitor next to the horizontal output transistor that burns up and blows the small main B+ fuse. Those parts should be replaced by a qualified tech experienced in the Hitachi projection sets who will also check the settings in the menu to get the sound back.
Aug 14, 2007 | Hitachi 50UX57B 50" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
