Question about Polaroid Portable DVD Player PDM-0722
All discs won't play and reads out "bad disc"
  • 49 Answers
Try cleaning the lazer of the device..
are they copies that the device cant read
I.E burn to fast harder to read burn at 2x easier to read.
Posted on Sep 27, 2009
4 Suggested Answers
SOURCE: Bad Disc
First determine where the problem lies. This can be done by analyzing what is happening. Is the disc spinning. Is it spinning erratically? If the disc is not spinning, the spin motor is probably defective. But sometimes you can be fooled, if the laser does not detect information of the disc, it will not issue a start spin motor command. If you can get the unit to work with the door open by defeating the switches,(Do not under any circumstances look directly into the laser)If you see the laser then the spin motor is bad, In either case the unit is is probably cheaper to replace than to repair. Scrivitron
Posted on Jun 20, 2007
SOURCE: bad disc ?
i need a change region and not have the code
Posted on Jan 03, 2008
BobbyR1234
  • 173 Answers
SOURCE: It wont play DVD's anymore
Hello Keilabb,
I am sorry to hear you are having a problem with your dvd player, but hopefully the following advice will help you correct the problem. The following are some common reasons why dvd players fail to read a disc or give you some type of error code such as "bad disc", "no disc", "disc failure", etc.
1. The disc is scratched or dirty- If discs have scratches, pits, or are dirty (finger prints are the most common cause) then the laser that reads the data on the discs will be unable to properly read the data. This commonly happens with older discs, but can happen if you rent from a movie store. If you hold the disc up to the light and tilt it back and forth you will be able to see any defects. If this is happening to ALL your discs then it may be your Optical Lens. The following link to my tips and tricks will provide you with instructions on how to clean your discs and give you other suggestions to keep them in good working order.
2. The Optical Lens is dirty- If the optical lens over time will accumulate dust and dirty on them. This component is where the laser comes through to read the disc data. It will present with the same errors that I mentioned above and usually will happen with every disc you try either old or new. The following link will take you to my tips and tricks section and give you details on how to clean it manually and offer other suggestions to help keep your dvd player operating in good working order. The following example picture will give you an idea of what the optical lens looks like:
3. The Spindle Motor has malfunctioned- The spindle and motor are the components that spin the disc. The disc must spin in order for the laser to read the data on the disc. If you listen closely when you insert the disc and close the tray, you should be able to hear the disc spin up. If you do not hear anything, or you hear the disc start and stop over and over and sometimes a squealing type noise, then the spindle motor is most likely at fault. The following link to my tips and tricks will give you more details on the most common mechanical failures of dvd players with pictures so that you will be able to see what these and many other components look like. It also provides you with other information such as average part and labor cost. I never like to suggest people try and fix an in depth problem that do not feel comfortable or have experience working with electronics or sensitive devices, because it if done incorrectly can cause further damage to the device and personal injury.
4. The Laser assembly has malfunctioned- This is basically the laser and it's components. This failure is not as common as the others, but it does happen. If the laser is not firing properly it will not read the disc data. You will also find this in the link provided in number 3.
I believe the problem in your case is most likely either 1 or 2, so try those solutions first. I am sorry for the long post, but I like to provide as much information as possible so that everyone I try to help are fully informed of the possible causes and help them find a solution to their problem. I hope that helps solve the issue you are having and please let me know if you need further assistance and I will be more than happy to help in any way I can.
Remember to ensure your safety when working inside any electrical device due to shock hazards (even when electronic devices are unplugged, they can still deliver a shock because Capacitors hold an electrical charge for some time even when power has been removed). When dealing with lasers, never look directly into them because they can cause eye damage. I wish you all the best
If you would not mind, please rate my help. I would greatly appreciate it. Thank You
Posted on Apr 27, 2010
Why my portable dvd playing won't play when i put a dvd dics in?
If it takes and accepts the disc but will not play it is either a mechanical issue (table not spinning the disc) or if not reading disc it is likely a dirty or bad optical pickup in the unit---
Nov 03, 2012 | Televison & Video
My wii won't play any games, I just get an error message
Well it might be that the disc drive is bad then or the reading laser is weak too.
Sep 16, 2012 | Nintendo Wii Console
Sony GDP s301 won't play any discs
see the cause and remedies:
Does not play disc
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
Finally the OPU, optical pickup unit contain too the lasser beam, NOT are reading the TOC of disk,+Syscon can be defective. You must go to the repair shop TV for fix it. this a complex equipment.
see tje block diagram.
God bless you
Jul 15, 2012 | Sony BDP-S300 Blu-Ray Disc Player
Tv won't read disc that have been played in it before
If you get a cannot read disc etc either you have a dirty or a bad optical pickup unit in the player--it reads the disc etc.
If bad cheaper to buy a new unit.
Jun 14, 2012 | Disney DTD1363-CAR 13" TV/DVD
My dvd player won't play dvd
likely if cannot read disc, or no disc or error, that unit has either dirty or bad optical pickup.
May 14, 2012 | Televison & Video
Won't PLAY ANY DISC DVD PHILIPS model- dvp3126/98
Dirty or bad optical pickup in the player----bad: cheaper to buy another than replace the part.
Apr 17, 2012 | Televison & Video
I have a Rosen entertainment DVD system and it keeps displaying Damaged Disc every time I put a disc in the player. It won't play any discs.
It has either a dirty or bad optical pickup unit (the part that reads the disc) and usually parts are not sold (only a complete DVD section if even available)
If not dirty may be cheaper just to replace the player itself.
Apr 16, 2012 | Televison & Video
Samsung htz310 reads NO DISC
probebly a bad laser. sometimes they will play music but not dvds or even the other way around. from what iv read this is happening to people in just a few weeks.
Nov 19, 2011 | Televison & Video
Won't read d d keeps saying bad disk
Hello, welcome to Fixya!
Was this player playing previously? And how long have you been using this player? I suspect the lens of the player. Once the lens of the player becomes weak, it won't play discs any longer.
The first thing my mind goes to, is the lens. The lens id responsible for reading/loading data on discs. So if the lens is unable to read the disc, there is no way the player is going to play the disc.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or probably, a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
Good luck.
Oct 05, 2011 | Curtis DVD1041 Player
Televison & Video Logo
136 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
