Rinnai energysaver 1001ft won't turn on. Was okay when last switched off. Cleaned filters and green light comes on for a short time but no red light to ignite starter for gas. After less than 1minute green power light switches off automatically.
Wet your finger first- then plug the item in, the filters should run in reverse. Make sure that the filter is in right. This was made in China and it is read left to right not right to left. The translation got it backwards. Fix this and the flow will make all well.
Posted on Sep 27, 2009
My rinnai energysaver 1001ft will not turn on.It has power to it but it will not power up when switched on.no lights no go.HELP;;
Hello Mark Obrien,
I searched the internet trying to get a HIT from your
rinnai+energysaver+1001ft
and all combinations there-of...
I also went on-line to a MAJOR RETAILER site & poured over their inventory of systems and parts (see below)...
Alpine Home Air Products Contractor grade furnaces heaters air...
Nothing... so:
Assuming you are talking about a heater here
If you are seeing no "lights"...
perhaps checking the SECONDARY side of your
POWER TRANSFORMER would be the best advice...
If that has the required (typically 24 volt output)
continue on to your main control board...
(looking for the Typical FUSE (usually 5 AMP)...
If the fuse is OPERATED... replace it...
f it operates again... IT is time to consider purchasing that
SPARE MAINBOARD you always wanted...
Like a YORK furnace... (verify your OWN NUMBERS)
031 01267 001A OEM Upgraded York Furnace Control Circuit Board by BDP... (PC (Main Control Board)
ALSO CHECK HERE
https://www.supply.com/rinnai-furnaces/b2098
Fuse kit
Amazon com Bussmann NO 44 ATC Blade Fuse Tester Puller Kit Home Improvement
Hope this helps...
Carnac the Magnificent
Jun 25, 2017 | Rinnai Heating & Cooling
I have a rinnai 1001ft heater but i need the flue is there enyone that has one please
You should be able to get the flue kit from any Rinnai resellers.
There are many different flueing options existing for Rinnai Energysaver depending on where you wish to install it (by a licensed gas fitter only of course).
Depending on what flue kit you need for your own situation you could be looking anywhere between $150 to $800 (AUD).
Go on their website for a list of resellers.
Mar 19, 2013 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
We have a RINNAI ENERGYSAVER 1001FT, if power or gas has been turned off, it takes several attempts to restart it.
If the gas was tunred OFF, yes it would take several attempts for the pilot to light. Because, there is air in the line from the gas line shutoff valve to the heater. Once that's purged, the heater should light. The electrical power shouldn't affect it. Unless, the heater hasn't been serviced in the last year. Unfortunately, they are not maintenance free.
Jul 06, 2011 | Heating & Cooling
Rinnai energy saver 1001ft try to on unit power on light shows,fan starts,times out,fan on again then shuts down. no flame indicator showing. problem? regards peter
There are a couple of things that can cause ignition problems:
The exterior direct vent termination may be clogged.
The gas line shutoff is not turned ON or is only partially open.
The filter needs cleaning. Be sure to turn the Master ON/OFF Switch to OFF before removing the filter. Leave it Off until the filter is cleaned and replaced.
All the above problems you can troubleshoot and solve yourself. The ones below, require an authorized Rinnai Service Technician to solve.
Spark ignition failure.
Faulty solenoids.
Faulty Flame Rod.
Hope this helped you to troubleshoot and solve the problem.
Jun 02, 2011 | Rinnai Heating & Cooling
When heater first turned on light is green then turns red
Yes this is OK. The green light is showing you that you have power. When the light goes red it means that the burner is alight.
Cheers
May 03, 2010 | Rinnai EnergySaver 556 Air Conditioner
Rinnai Energysaver 1001FT, ignites, blows 5mins then shuts down.
Sounds like it is reaching high limit...either the filters on the back are plugged, or the manifold pressure isn't adjusted properly. IF the exhaust were plugged on the unit, it wouldn't fire at all, since it has a pressure switch to verify vent flow. The slightest blockage, the unit will lock out to prevent damage to the unit.
Jul 07, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
I am needing an instruction manual for rinnai energysaver 556/FTR as have purchased and moved into property recently and am having trouble operating the heater and am concerned with a red filter light that...
www.rinnai.co.nz
navigate to tradesmart, space heating, energysavers.
Red filter light means the filter is blocked.
its located directly on the back of the heater and the wall spacer, from the control panel, its about 4 inches back.
Pull it up, clean reinstall
Apr 27, 2009 | Heating & Cooling
Rinnai Energysaver 1004F on indicator light is red (usally green)
If its not producing heat, yep! If it is, it indicates that there is an error code stored in memory.
Feb 18, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
No spark to ignite
vacuumed out area behind filter--it works fine now.
Dec 18, 2008 | Rinnai EnergySaver 556 Air Conditioner
Heating & Cooling Logo
283 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
