Question about Dishwashers
Replace broken door springs F&P dw918td - Dishwashers
  • 909 Answers
To replace the door springs, you need to remove both the side covers. This can be done by first removing the lid and then working your way around both panels until they come off. You will then see on either side a cord that is attached to a single spring.routed on a small bend. Very unlikely the spring is broken but possibly the cord has or it has pulled loose from its position. Rectify then reassemble.
Posted on Sep 27, 2009
I took my microwave apart to fix the broke spring in the door & put everything back exactly the way it was &it wo nt do anything ??????
Bad luck. Are you sure you mounted everything everythinh exactly the way it was? No pieces missing or left over?
Best procedure is to that a photo of each step.
My adivec: Do it agaim carefulley. I no luck, look for a repair service
Maybe you can fine a video tutorial for your Microvwve in youtube?
Something like this
Broken microwave door
Samsung Microwave Door Latch Spring Repair when your door won latch closed
Over The Range Microwave Oven Door Repair Help
Repair Replace bad Door Switch Mechanisms on Whirlpool Microwave
and there are come more
Oct 28, 2015 | In Microwave Ovens
How do i fix a broken spring on a dishwasher door
You will need to pull the dishwasher out about 12" to 18" to be able to get to the springs & rope links. Many dishwashers use a "rope link" to connect between the spring and the door hinge; and in others, the door springs connect directly to the door hinges. Once you pull the dishwasher out, you will easily see what broke and what you need to fixe it.
Jan 20, 2015 | Frigidaire Dishwashers
Door opens about 16" then stops will go down but only opens 16"
Probably a broken torsion spring, if you help lift the door as it is opening, it may open all the way. With the door down and you inside, look at the torsion spring above the door opening on the long rod to left or right of centre. One on each side of centre with a double garage door. If either spring is in two pieces, then you will need to get them replaced or replace them your self.
http://www.google.ca/url?sa=t&rct=j&q=&esrc=s&source=web&cd=4&cad=rja&uact=8&ved=0CDEQtwIwAw&url=http%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DbAdvAyrQL4o&ei=MqeXVNunNNOoyATyh4CoAw&usg=AFQjCNHbiDPLQd0Z0uE_Jhitvyna6y9RtA&sig2=H1ItDdkb2K_bhZFpekxHuw
Dec 03, 2014 | Building Materials
Door well close but not open
This could be a broken torsion spring. See link below to see what a broken one looks like.
Replacing Broken Torsion Spring on Single Spring Garage Door
Oct 05, 2014 | Building Materials
How do you replace the handle
follow this steps and fix it. see the pictures attached. God bless you2f4dab72-f574-4367-8631-e2d40f813792.gif
Open Lever
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
Help me find my model number
Door Spring
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button
If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Jun 18, 2013 | KitchenAid KHMS147 Microwave Oven
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
The primary door in a 2 door install has "locked
There's a good chance that if the motor runs and drive chain is not moving, the nylon gears inside the opener housing have stripped. This nearly always happens after one or both springs near the door tracks have broken. The spring provides the counter balance to the weight of the garage door - without them both, the full weight of the door is carried by the motor - which it is not designed to do. You can easily tell if the spring(s) have broken if the door is very heavy to open & close by hand - or is heavier and / or goes up & down unevenly. If you have broken springs, you'll need to reconnect / replace them before you can can expect the opener to work more than a handful of times before the gears strip again.
Pull the plug / power down the opener and set up a ladder under the opener. Remove the screws to gain access to the interior of the opener. If you see a bunch of white plastic / nylon "filings" that is exactly what happened. You can get / order the replacement parts at any Sears store or Sears Online. A kit is probably the best way to go - it contains these parts:
If you need more than these parts (they're often the only ones that need replacing) due to additional damage, you might consider this more comprehensive kit instead:
It's not a big job, but can be a little labor intensive (take pictures as you disassemble the mechanism to help with reassembly later). It can get a little troublesome getting it set up correctly, but is certainly not beyond the scope of abilities of a person that normally uses the tools required to do the job. Desire, a couple hours (or more if springs are broken) and a little bit of mechanical aptitude is all that is required.
I hope this helps and good luck. Please rate my reply, thanks!
Apr 20, 2011 | Sears Craftsman LiftMaster Chamberlain...
Door spring has come off or broken & door falls down if not clicked shut
THE SPRINGS ARE ATTACHED AT THE BOTTOM OR THE DOOR. LOOK UP THE PART ON THE INTERNET APPLIANCE PARTS AND SOME OF THE SITES HAVE A PARTS BREAKDOWN FROM WHICH TO ORDER SPRINGS
Mar 08, 2010 | Baumatic 23 in. BDW4SS Built-in Dishwasher
Door spring broken
the door links are broken need to get new ones and replace
Nov 04, 2009 | Kenmore Elite 45986 Front Load Washer
Need door assembly diagram to replace door latch & spring on Panasonic microwave model nn-t964sf
While I don't have that model's diagram, normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
You can order Panasonic parts here.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 23, 2008 | Microwave Ovens
Dishwashers Logo
235 people viewed this question
Top Dishwashers Experts
