Question about Motorola For MT2000 HT1000 HT6000 GP900 JT1000 GP1200 MOBIUS MTX8000 MTX9000 MTS2000 7.5v 1300mAh NiCd Intrin... 2-Way Radio
Problem Recieving I have tried everything I know to repair this, I have Motorola Programming Software and am a novice at using it to tune the radio I know how to set up and program frequencies and other functions but when I program a Frequency and slap the TPL code into it when I unplug the radio and test it with the repeater, the received audio comes in out in out very rapidly, so much that it makes it hard to understand any transmissions however 2 other repeaters I have set up to this radio have a Receive "DPL" and those work fine and receive normal but whenever I use a TPL it has the problem, to clarify its as if something in the transmission is causing the TPL to burst through in very short periods, literally I hear 3-4 bursts per second through, I guess you'd call it, the "pl squelch gate" if you guys can help that would be awesome, thank you
    Problem Solver:
  • 5 Answers
First try programming the Receiver for Carrier only Squelch,,ie no PL /TPL, then check if it will receive the repeater OK.
If the audio still cuts in and out then (assuming no fault exist) either you mis-programmed the Frequency slightly, or the TPL choice was incorrect.
There is also a possibility of a Bandwidth mis-programming.
Repeaters may have 12.5 KHz or 25KHz channel bandwidth. Basically if you set your radio to 12.5 KHZ and it receives a transmission from a 25Khz Repeater because of the higher repeater TX Deviation the audio on your radios RX will cut in and out and may sound distorted and very loud as well. Your radios TX would sound OK though, but would have lower audio level when heard on the repeater RX. Does your TX work OK through the TPL repeater?
Posted on Jan 11, 2008
  • WB6YSL Sep 14, 2010
    Scnermn2004 (or anyone else), I have the exact same problem with my HT1000. I quadruple-checked everything petedcurtis recommended buts still have the same problem (can't use TPS for receive). Have you fond a solution to this?
2 Suggested Answers
Neto
  • 123 Answers
SOURCE: Having Trouble Receiving Through"TPL"
Are you sure that you are using the exact RX Frequency? is the radio in 25Khz if this radio is working on 12.5Khz with the IF filters changed to work in narrow band (12.5) could happend this.
Do you know if the repeater is on parameters mostly of the cases when an over modulation is received this will cut the PL modulation for short periods.
If the radio transmit over modulated could "erease" the PL modulation for short periods.
I think this radios should be checked all the Tune parameters to make sure is ajusted properly.
Good luck
Posted on Dec 18, 2007
I have 2 VISAR HANDIE-TALKIE FM RADIOS MODEL: HD5RDD9AA4AN + DON'T KNOW HOW TO PROGRAM THEM TO THE SAME CHANNELS
This is a discontinued radio from Motorola. programming requires a cable to connect to a computer, there is no direct programming available.
While this is not really an answer, the programming software is specific to Motorola and you need to buy both the software and the cables from Motorola.
you would be better served, to determine what frequencies you want and then pay a certified Motorola dealer who has the software to do the work for you.
Dec 05, 2016 | Radio Communications
How to resolve CODEPLUG ERR on Motorola PTX760
Your radio needs to be reprogrammed or repaired. This type of error can occur for no reason, or during an interruption in programming. Check your programming/test set-up. Do not try to reprogram using the same codeplug (saved version of programming) as previously used, as it may be corrupt. If you cannot get the error to clear with a fresh programming, the radio will need to go to Motorola to have the error cleared.
Best regards.
Apr 12, 2013 | Laird EXL42MX * Motorola PTX760 Motorola...
Motorola astro moblie programming !!!!!
"No longer supported" means they don't repair them at their repair depot anymore. However, software for most models is still available. All Motorola software is by subscription, and they choose who can obtain a subscription. You must be a Channel Partner (dealer) or meet their criteria for obtaining it.
Most 800 MHz radios are trunking radios, and require a tower system to operate. Many towers in this bandsplit have been shutdown or retired due to changes in the licensing/availability of 800 MHz frequencies.
If you are planning on operating the radios with a tower system, see the owner of the system for programming. If you are wanting to use the radios in simplex (radio-to-radio), you could get them programmed at a full-line Motorola dealer. You will need to provide your FCC assigned frequencies.
The model number you mention is incomplete, and I could not determine which of the softwares you might need.
Best regards.
Feb 07, 2013 | Motorola Astro Spectra 800mhz Mobile...
I want enter new frequencies into my motorola gp339,dont know how to do it.i was given the radio with no booklet ect...im a firefighter and want to put fire (FESA wa) Frequencies in my Radio..
Programming the radio requires a special cable and programming software. The cables aren't difficult to find, but you can't legitimately get the software unless you buy it from Motorola. They're pretty quick to go after sites that distribute their software. The versions of programming software available on the Web are sometimes buggy or older versions, and often the radios won't accept programming from older versions of software than they were originally set up with.
The easiest way to get your radio programmed is to check with an authorized Motorola dealer or service center. They'll have the necessary equipment to do the job right and will probably give you some kind of warranty on the work as well.
Feb 25, 2010 | Radio Communications
Progamming software for kenwood tk-270g
kpg56d is the software you will need for that radio.
Also here is a link to the service manual
http://download.qrz.ru/pub/hamradio/schemes/kenwood/TK-260G_ser_man.pdf
Aug 18, 2009 | Computers & Internet
Hello Guys..how to channelize my 2way Radio Motorola Radius Model
The GM300 is dealer programmable using Motorola proprietary software, a programming cable and radio interface box (rib). (Or on some models a ribless cable). I will continue to look for a user guide pdf. If I locate one I will post it.
May 01, 2009 | Radio Communications
Motorola gp-68 low battery beeps comes on too soon
I'm not sure that you can manually reset the low voltage threshold on your radio. Most of Motorola radio use programming software to turn on/off low battery beep and many other features. Everything is done by software.
radcom907
Mar 10, 2009 | Radio Communications
Good luck
Dec 17, 2007 | Motorola HT1000, MTS2000, MTX8000/9000...
Radio Communications Logo
1,459 people viewed this question
Top Motorola Radio Communications Experts
Steve
Steve Allison
Steve Allison
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
