Question about Dryers
Circuit Breaker is tripping when tumble dryer is plugged in. Have removed back and top of tumble dryer nd cleaner=d all excess lint. No obvious sign of shorting or poorconnections. Dryer is 17 years old, but otherwise functioning very well. No apparent damage or misuse or problems inside or outside of dryer.
  • Bruce Canfield
    Bruce Canfield May 11, 2010
    Hello. A circuit breaker tripping is many times caused by poor venting/air circulation, which leads to overheating, which leads to the tripped breaker. You cleaned all the lint out of the back of the dryer, but have you checked the venting all the way to where it exhausts outside? And have you checked to ensure that the blower is working properly? You may have already done these things, but you can let me know and I will attempt to assist you. Thanks.
Circuit Breaker is tripping when our tumble dryer, creda 522vw, is turned on. Have removed back and top of tumble dryer and cleaner all excess lint, checked connections and exhaust. Any ideas please
Posted on Oct 03, 2009
  • 51 Answers
If its a electric dryer check heating element for short to heater box
Posted on Sep 27, 2009
My white knight tumble dryer wont start
Nothing works or drum fails to turn (tumble dryers)
Ensure that the power supply to the dryer is switched on, the timer is set to the desired drying time and the door is correctly closed. If you have a condenser model, also check that the bottle is empty and is fully pushed into the machine.
http://www.whiteknightrange.co.uk/whiteknight/faq.html
The first thing to establish when troubleshooting the clothes dryer is whether the dryer will start or not. If it won't, start by checking the outlet and the circuit breaker. Is the dryer plugged in or has it tripped the circuit breaker? If the breaker has been tripped, flip it back on and try the dryer again. The drum should turn without a problem.
If both plug and breaker are fine, you'll need to inspect the door switch as you continue to troubleshoot the tumble dryer. When you close the door on the dryer, a plastic peg should click and operate the switch which allows the dryer to work. The peg might be bent or broken, in which case it won't connect with the switch. You can try to straighten the peg, but if it's broken, you'll need to replace it. If the peg is fine, the switch has probably failed and will need to be replaced.
http://www.doityourself.com/stry/troubleshooting-a-clothes-dryer-drum-doesnt-tumble#b#ixzz3FOOQgtAT
Oct 06, 2014 | White Knight Press Genuine Tumble Dryer...
When washing Machine goes into spin cycle, , it starts making a grinding noise and never goes to full momentum and starts to slow down, after the grinding noise. The clothes aren't fully dry as they...
Sometimes, a Whirlpool dryer may not function as you'd like.Although specific details vary by model, the company offers several generalguidelines to troubleshooting your Whirlpool dryer and getting it back intoworking order.
Verify that thedryer is connected to its power source if it won't turn on. Whirlpool alsosuggests checking your home's circuit breaker, as the high power needs of thedryer may have tripped the circuit. If the circuit has been tripped, reset itby flipping it back into the "On" position. Push the door of the dryer. Whirlpool designed its appliances to not turn onif the dryer isn't secured and notes that the dryer door may not be fullyclosed even if it appears shut. Push firmly at the top and bottom of the door,as some Whirlpool models have two latches. Press the "Start" button again. Whirlpool reports that some modelsrequire you to press and hold the button for five seconds to fully start themachine. Depending on the model, the button may be labeled "Hold toStart," "Start" or "Push to Start." Check that the dryer's settings knob is set to an actual drying mode and notsimply "Air" or "Tumble." On most Whirlpool models, themanufacturer states that the settings knob should be set to"Accudry," "Timed Dry" or "Automatic Dry." Clean the lint trap, typically located at the top of the dryer and removedby pulling its plastic handle. Over time, lint and dust builds up here. Thethicker the trapped layer of lint, the slower your dryer performance. Whirlpoolrecommends removing built up lint after every dryer load. Remove some of the wet clothes inside the dryer if it's taking an unusuallylong time to dry your clothes. Whirlpool warns that placing too much clothinginside the dryer reduces hot air circulation, which also reduces dryingcapabilities. Recommended dryer load s vary, with compact Whirlpool modelsholding approximately 3.4 cubic feet while extra large Whirlpool dryers holdingmore than 7 cubic feet.
Jun 07, 2011 | Washing Machines
Whirlpool gas dryer WGD5540SQ it is getting power, drum does not turn, just hums when I push start button. I checked for blown circuit breaker, i' ve cleaned lint tray and checked vent to outside. I've...
there is a reset button on the motor more then likely it tripped, there are actually two one resets the other trips, but here is a website it will help with the dissemblance of the dryer, Tim:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Oct 19, 2010 | Whirlpool WED5520SQ Gas Dryer
LG DLG2532 dryer not heating up, lint trap clean, good air flow out exhasut vent, all controls seam to be working i.e. lights on buttons and chimes good, seams like its not getting gas but valve is turned...
Hi, Make sure you check these to fix the problem.
  • Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
  • Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
  • A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Apr 16, 2010 | LG DLE2532W Electric Dryer
Dryer won't heat up but tumbles. What could be
you could have a bad heating element, a tripped circuit breaker, a blown fuse in the dryer or a bad timer. you can check the element and fuses/ thermostats with an ohm meter for continuity.
Sep 17, 2009 | Dryers
DLE2532W electric dryer: BLOWN CIRCUIT BREAKER
I would check the wire at the breaker for a poor connection causing arcing and excessive heating causing the breaker to trip....with the breaker off, loosen the binding screw on the wire and check the wire for any signs of arcing. reattach the wire and tighten binding screw snugly.
another though, ensure there are no other devices connected to the wire that is heating.
Feb 23, 2009 | LG DLE2532W Electric Dryer
Tumble dryer trip breaker after 10 seconds in clockwise motion
If you removed the heater and didn't get it in right, it could trip a breaker. If it doesn't get proper airflow through the heater, it will not be able to heat properly.
Feb 20, 2009 | Dryers
Heavy loads (e.g., jeans, etc) is tripping the circuit breaker
WOW, 10yrs was a good investment of your money. Anyhow large amp loads may be contributed to the motor or fatigued heating elements. Also the breaker can wear out if its ran loaded for extended periods. Here are a few things you can try. Check to ensure that the barrel sleeve rings are in good condition so that there would be less drag on the motor and fix the obvious. Then change your breaker out and change the electrical outlet. if your not comfortable with changing these two items DON'T DO IT.
TIP OF THE DAY--To reduce the suction draft and drying time your drier and save some cash, remove the lint catcher and take it to the sink. Run water into it, if there is excessive pooling of the water (water not running straight through) then fabric softener is fouling the lint screen. Use a small brush and dish detergent to clean it and then shake off all the water and dry the screen. Remember this tip on future driers and you will make the dryer blower motor last much longer. :?) DRRXR
Feb 01, 2009 | Dryers
Dryers Logo
512 people viewed this question
Top Dryers Experts
