Question about Marantz Audio Players & Recorders
My marantz 74sr66/02b right rear surround speaker wont work ground or power and the ground on my left rear speaker
techman
  • 3130 Answers
SOURCE: no surround sound
So your saying that you have no rear channel. Some recivers use a single stereo output ic for both sides on the rear speakers. you could have a defect with this IC . Anther thing Im sure you check3ed the obvious ie : the switch is on suround sound? If there is a front to rear fader is it in the middle? Good Luck
Posted on Jun 04, 2006
  • 6 Answers
SOURCE: Surround Sound Center Speaker/Sound Card issue
You need to use a digital interface cable between the sound card and the speakers to get all of the 6 channels to work properly.
Posted on Sep 24, 2006
SOURCE: connecting 2 stereo amplifiers using one as a preamp and the other as a booster
I would take from the tape out of the pioneer and feed into the aux input of the marantz you will then have to adjust the volume levels on each amp as required
Posted on Oct 29, 2007
SOURCE: No sound in rear speakers
I figured this one out, although I might still send it back for an exchange. It turned out that the right rear speaker works just fine, however the jack seems to be flawed. When fully plugged in, the rear speaker input only picks up the left channel. If you pull it out just a little, say 1/8-1/4 the way out it will pick up both channels. Not a good solution but it works for the time being.
Posted on Oct 01, 2008
  • 290 Answers
SOURCE: needing wiring diagram for 1991 dodge dynasty le
here is what I found:
http://www.the12volt.com/installbay/stereodetail/715.html
Posted on Mar 26, 2009
Surround left and surround back channel (speakers) not working.Changed wiring and speaker,problem still exist.
It could be they have been switched off accidently. Check the speaker settings.
Apr 11, 2016 | Marantz SR5007
Subwoofer
go to audio set up and configure the system for 5.1 or higher sound output.then only all the speakers ll work
Jan 03, 2008 | Yamaha RX-V640 6.1 Channels Receiver
I have had my Marantz Sr5000 for some time now and I just noticed the rear speakers have stopped working. Everything else seems to be working fine. When I run the test tone I get a tone from everything but...
First of all if you have not made any connection changes in the system prior to loosing the sound try these steps.
Go into the system menu and in speaker configuration see if somebody has given the rear ( surround ) speakers as none. If not just exchange the front and back speakers to confirm if its a speaker failure . If not you will need professional help to fix a damaged surround amplifier.
Mar 08, 2011 | Marantz SR-5000
I've bought an adapter thing, but I don't understand how to wire these wires.
  • Yellow - To the car battery of continuous +12VDC
  • Red - To ACC Power, +12VDC
  • Black - Ground, to bare metal or clean part of the car
  • Dark Blue - Motor Relay control lead for Antenna
  • Dark Blue / White Strip - Amp Relay Control lead
  • White - Front/Left Positive Speaker
  • White / Black Strip - Front/Left Ground Speaker
  • Gray - Front/Right Positive Speaker
  • Gray / Black Strip - Front/Right Ground Speaker
  • Green - Rear/Left Ground Speaker
  • Green / Black Strip - Rear/Left Ground Speaker
  • Violet - Rear/Right Positive Speaker
  • Violet / Black Strip - Rear/Right Ground Speaker
Nov 11, 2010 | Panasonic CQ-DP133U CD Player
I need pinout assignments for a Philips 5.1 Home Theater Speaker system (PWR2006-37)? It has a DB-15 style input connector that hooks to the output of a Philips dvd / amp / control unit. this was...
Pin assignment is as follows (not sure of levels required- preamplification / attenuation may be necessary:
1: Control 0/5V.
2: Unused
3: Unused
4. Center speaker in
5. Ground
6. Ground
7. Subwoofer in
8. Ground
9. Unused
10. Ground
11. Left Front speaker in
12. Right Front speaker in
13. Ground
14. Right surround (rear) in
15. Left surround (rear) in
Jul 10, 2010 | Philips DVP642 DVD Player
Which is the power to the speakers on a marantz 2226 B
There should be 2 sets of connects on the rear panel
A and B
Connect A red and blk ( right) to one speaker and A red and blk (left) to the other speaker
Make sure your speakers are between 6 and 8 ohms
Jul 02, 2010 | Marantz MA-9S1 2-Channel Amplifier
Need a wiring diagram for a sony cdx-gt08 it is going into a 2000 saturn sl2 I have the new wiring harness but need to know what wires go where
yellow to yellow main power wire
red to red key wire
black to black ground
speaker wires are green purple for rear speakers and white and grey for front speakers solid wire color is power and black lines is ground
orange is dimmer switch you wont need it
blue wire is for power anntenna your car shouldn't have it and blue with white stripe is remote wire if you have an amp it will shut off your amp when hooked up any other wire unnessary for your car some head units need a anntenna adapter to work good luck. remember ground before anything and disconnect the battery so you don't blow the fuse
Mar 13, 2010 | Sony XPLOD CDX-GT200 CD Player
Need wire colors power,ground,speakers/clarion arx6670zterryrose
yellow battery
red accessory
black ground
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
pls rate people arnt rating hope this helps
Oct 12, 2009 | Clarion ARX6670Z Cassette Player
How to install kenwood kdc-x493 with kac-8104d in 1996 honda civic?
very simple on the back of the deck you will have a wire harness
Yellow = constant power supply
Red = Switch power supply
Black = Ground
White = left front speaker +
White /Black stripe = Left Front speaker -
Grey = right front speaker +
Grey /Black Stripe = right front speaker -
Green = left rear speaker +
Green w/ black stripe = left rear speaker -
Purple = right rear speaker +
purple w/ black stripe = right rear speaker -
wires for the honda are,
Constant 12V+ Blue/White Switched 12V+ Yellow/Red Ground Black Left Front (+) Blue Left Front (-) Gray/Black Right Front (+) Red/Green Right Front (-) Brown/Black Rear Speakers 6" x 9" Rear Deck Left Rear (+) Blue/Yellow Left Rear (-) Gray/White Right Rear (+) Red/Yellow Right Rear (-) Brown/White
Jul 25, 2009 | Kenwood KDC-X492 Car CD/ MP3 Player
Center, and rear surround speakers
Sounds like the rear volume is just turned down. Cant be the amp if the front and subs are working
Aug 28, 2008 | Bose Acoustimass 15 System
111 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
