Question about Video Cameras
I dropped my canon camcorder on vacation and now you have to manually remove the tape and when you put another tape in it will not play? we finished taping the rest of our trip watched that tape and then when we tried to remove the tape it wouldn't come out. We got it out but now you can't put another tape in?
    Brigadier General:
  • 4,090 Answers
I would suspect the cartridge container mechanism is bent or distorted. Doubtful if you will evenr get it back as it should be. It can be replaced though but you need to get a quote. Travel insurance would have covered this as does the home insurance policy if the excess does not exceed the value of replacement
Please rate the help++++Thyanks for using FIXYA
Posted on Sep 27, 2009
Testimonial: "THANKS FOR YOUR HELP"
Canon zr700 won't play tape
That is the pinch roller. If it does not press the tape against the capstan, then the tape will not pass the read/write heads. Replace it.
Jun 25, 2017 | Canon ZR700 Mini DV Digital Camcorder
LP/SP mode
Seems your Canon doesn't support LP mode playback. Please see its user manual and check its specifications for LP mode playback.
Aug 17, 2008 | Canon ES8400V Camcorder
I have an 8mm high digital camcorder tape which got tangled in the camcorder. when i wound the tape back in the case and returned it to the camcorder it would only play a high pitched sound with no...
I've had to fix this problem several times. You need to open the 8mm cassette, and manually rewind to where the tape got twisted around. Then untwist it, and manually wind the tape back on the reels. and then put the cassette back together. If the tape isn't torn you should be fine. There might be creases in the tape- but they will only give you a slight picture glitch or drop out. You need to run a head cleaning tape through your camcorder before you try taping again. It might hose up the next tape if you don't.
Jul 24, 2008 | Cameras
Cant put tape in camcorder
Then remove the tape and check it in another camcorder.....
............. Very simple.
If the tape works fine in another camcorder then throw this camcorder. Let me know the location where you will through it.
May 07, 2008 | Canon Elura 100 Mini DV Digital Camcorder
No picture when playing the tape back
Clean the drum assumbly with a head cleaning cassette and try
Mar 16, 2008 | Canon ZR80 Mini DV Digital Camcorder
Remove tape error message
  1. Condensation is detected – If condensation is detected by the camcorder, the “Remove the Cassette” warning may occur.
  2. Component failure – If an electrical or mechanical component in the camcorder fails, the safety mode may activate to prevent any further damage to the camcorder.
  3. Sand or grit damage – The camcorder’s tape drive mechanism consists of many tiny gears. Sand or grit can cause a gear to jam and stop turning. This will cause the camcorder's safety mode to activate.
  4. Impact damage – If a camcorder is accidentally dropped or bumped against a hard surface, it is possible that a misalignment of the tape drive mechanism may occur.
  5. Liquid damage – If either the camcorder or the tape is exposed to water or any other liquid, a variety of malfunctions may result. Please avoid this situation.
  6. Improper videotape insertion – If a tape is forced into the cassette compartment, or if the cassette compartment is pressed down while the tape is loading, damage may occur to the tape drive mechanism. Please refer to the User's Manual.
  7. Damaged or defective tape – If a tape becomes damaged, please discontinue its use.
Operational Recovery Steps
Depending on the conditions that caused this message to appear, it is possible that the camcorder operation may recover. Please follow these steps:
  1. Eject the videotape
    Insert a new or known good videotape. If the message does not persist, it is possible that the tape was damaged. If the camcorder still displays the message with a new tape, please proceed to step 2.
  2. If condensation had been detected causing the Remove the Cassette warning, remove the cassette, and allow at least one hour for the moisture to dry.
Nov 19, 2007 | Canon Elura 100 Mini DV Digital Camcorder
Canon ZR100 Mini DV Digital Camcorder Problem
I have a Canon4.gif ZR 10 And it does say remove cassette often and recently it eat the tape and destroyed our recordings.
Does this have something to do was the round small battery1.gif in the front part of the camcorder?
Is this a consumer complaint I feel uncomfortable because we have alot of Cassettes recorded and we are afraid to play them because it might chew them up.
There is a mini cassette player2.gif that can play the cassetes ????
Need Help!!!! What am I going to do ??? PNicioli@sbcglobal.net
Sep 24, 2007 | Canon ZR100 Mini DV Digital Camcorder
No Picture, sound or anything during playback...
cleaning cassette may help - if the picture comes back but soon goes blue screen ? your heads need thorough cleaning or replacement ;
Jul 30, 2007 | Canon ZR100 Mini DV Digital Camcorder
Cannot insert tape into canon MV800. Always ejects
Hi Everyone,
our MV800 was doing the the same so i "accidentally" dropped it (i got a bit frustrated and it was out of warranty) and now it works fine. please note it dropped about half a meter on carpeted floor while it was off.
Hope this helps
Mar 09, 2007 | Canon MV800 Mini DV Digital Camcorder
Video Cameras Logo
63 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
