Question about Coby DVD815 System
Is there a way for my tv to play through my coby dvd815 home theatre system and not just the dvd player?
  • 49 Answers
There is if u just want stereo..
or u can get a 2 jack splitter like the ones aeroplanes have and plug front back in to that ie check this link
JACK SPLITTER
AND INSERT IT IN TO THE EARPHONE SOCKER :-)
Posted on Sep 27, 2009
Toshiba tv has no sound but does with DVD player on, how do I regain sound for tv shows
is the dvd player a home theatre system?if yes,does the tv play sound via the dvd home theatre speakers when it is on?if yes then maybe you should double-check your audio port connections between the two for correct configurations
Jan 04, 2016 | Toshiba Televison & Video
The audio will not play through the tv from the home theatre unit
because you do not have the dvd player hooked up to the tv, if you want it to play through the tv then you need to have the dvd player connected to the tv.
Mar 21, 2009 | Samsung HT-Z310T Theater System
Ghosting of picture from a Panasonic home cinema system
There must be a fault in the screening of the internal wiring to the scart outlet in the home theatre system. I simply changed the way the player was connected to the TV and the interference disappeared:-
1.) I used the RCA video outlet instead of the scart lead. Picture quality was not compromised. FYI the Panasonic Plasma TV I have has only RGB video input sockets at the back, so I used a scart to RCA adaptor to overcome this problem of connecting old technology to new.
2.) The surround sound when playing DVDs is generated directly from the home theatre system so there was no need to connect the audio from the home theatre system to the TV
3.) I used a pair of RCA leads to connect the "audio out" from the TV to the "audio in"on the home theatre system to provide the option of TV sound through the home theatre system.
Mar 18, 2009 | Panasonic Televison & Video
How do I hook up coby 5.1 300watt to my rca flat screen
audio out on the TV to audio in on the "home theatre system"
Feb 27, 2009 | Coby 5.1 Channel Home Theater Speaker...
I have a coby dvd player which is connected to my home theatre sound system. However, i canot increase the volume to a satisfatory level past #20. the theatre sound system is at max volume.
I work for Coby technical support. Our customer service phone number is 1-800-727-3592.
Unfortunately, there is no way to increase the output of the Coby dvd player within the player itself. It may be that the player isn't outputting very well through the audio coaxial output which i presume your using. If this is the case, there is no fix for that type of issue. You would want to replace the player.
If you feel this solution doesn't deserve a good rating, please let me know why so that I may better assist you. If there is anything more I can do to help, I will!
Jan 16, 2009 | Coby DVD-224 DVD Player
Sony Model DAV ? SB 500W Home Theatre System
Please check at rear of TV for Digital Optical IN port as home theater should have optical out port at rear. If you got any optical in port in TV, just connect optical wire between TV and home theater.
2nd option is check Line Out pins at rear of home theater system, if found, hook red-white RCA cable there and put it to same input in TV where you hooked Video (composite or component) cable.
Let me know the results to help you more.
Jan 07, 2009 | Sony DAV-SB500W System
Panasonic 50? Plazma TV TH 50PZ 800A + Sony Model DAV ? SB 500W
that is possible
the home theater has so many in puts on your dvd and out puts.
there is a way
1 you can buy a vedio/audio converted to rf signals, this will mean both signals entering tv using rf.
2 get your vedio out from dvd and audio out, feed that to a converter, vedio in and audio in okey
T v and home theatre sony bravia
As most home theatre systems offer no analogue audio input and only use the audio coming from the dvd being played the short answer is no.
If your home theatre system has a digital input and the tv has the corresponding output then yes you could me able to connect the two. Otherwise you could try to get hold of a analogue to digital converter and convert the tv's audio out to digital.
Jan 11, 2008 | Audio Players & Recorders
Disc drive not opening
maybe the belt inside your DVD has loosen up already!
Nov 15, 2007 | Coby DVD815 System
No picture from dvd, but sound
What type of output are you using? Try using the component video output on the DVD player. (that's the one with three colors) This worked for me when the composit and s-video outputs stoped working.
Oct 12, 2007 | Coby DVD815 System
Coby DVD815 System Logo
77 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
