Question about Kodak Easyshare M753 Digital Camera
Camera body does not turn on when fully charged batteries are in.
    President:
  • 2,761 Answers
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your camera may have a problem that requires professional repair.
Posted on Sep 27, 2009
The camera won't turn on and I know the battery is fully charged
Fully charged? or reached the correct voltage, without any charge? did you measure the voltage with a multi meter? and was it above the voltage printed on the battery? if it was exact the voltage or even one or 2 tenths of a volt lower, the battery is not good anymore. Then did you check the battery was inserted correct? and are the contacts clean and shiny? no debris in the battery housing? Just to mention some things you could check.
When you close the battery door, does it click? when closing (or opening) the battery door a switch is engaged (disengaged) to tel the logic, if the door is still closed. It will try to protect your memory card by blocking any memory access as soon as the door is opened. (It will not even start the camera as long as the door is open.)
Mar 05, 2015 | Olympus OM-D E-M1 Digital Compact System...
Can not run netbook off battery even though battery shows fully charged' When charger is removed netboook will not turn on
Make sure the battery is fully inserted and clicks in to the netbook body. Your battery may also be showing that it's charged but is actually dead. Try a new battery and see if it solves your problem.
Jul 04, 2013 | Wolvol Mini NOTEBOOK COMPUTER Laptop...
I need to READ the battery charger instructions for a Minolta Dimage G500?
I suggest you charge the battery overnight and in the morning if the LED does not change color then the Red LED on the charger only indicates that there is mains power to the charge adapter.
Jul 11, 2012 | Konica Minolta DiMAGE G500 Digital Camera
Canon DSLR will not turn on
Hi there,There are a few things we can try/check here!
1.Turn the camera OFF. Remove the battery and clean the contacts (shiney metal strips) on the battery.2. Remove the lens and clean the lens contacts.3. If you have a body cap, put it on the camera (no lens, just to keep dust out right now).4. Reinstall the fully charged battery and turn on the camera.
It should start up. If so, turn it back off and reinstall the lens.
Also, be sure to check all the doors/hinges on the body. These are found on the battery and the memory card. They have electrical contacts on them that need be to be fully closed.
If possible, try a different battery (a friends, or take it to your friendly neighbourhood camera shop).
Hope it turns back on!
May 07, 2012 | Canon EOS Digital Rebel XTI Digital Camera
It turns on then off almost instantly, the batery is fully charged.
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success.
Jan 18, 2011 | Kodak Cameras
When I turn my camera on, the screen is black and makes beeping sound? Also lens is stuck
Jan 17, 2011 | Cameras
Can not turn on after insert a new charged battery.
Please make sure that you're using fully charged battery
Remove the battery, press and hold the power button for 5 seconds and then reinsert the battery..
Try using a different battery to check whether the issue is with the battery..
You may also check the battery poles using a multimeter to confirm this if you do not have access to a different battery..
If the issue persists, service may be required.
Thanks for understanding.
Jan 06, 2011 | Nikon D300 Body Only Digital Camera
My battery is fully charged but when i turn the camera on it shuts right back off
SOunds like your battery is bad. try discharing it :
  1. Place the battery in your camera until it itself turns off. In this situation, the battery is fully discharged.
  2. Take out your battery and slide it into your battery charger.
  3. Connect your charger with power to fully charge the battery. It is normal for a new battery that battery indicator shows 100% capacity in 10 to 15 minutes. Please keep charging until there is no time left for charging.
  4. Fully charged and fully discharged or "cycled" as much as five times to condition them into performing at full capacity.
Try it and see if it works? If the batteries are not rechargeable then the problem is in the cameras power supply and you need to take it in or replace it.
Jun 13, 2010 | Sanyo VPC-T1060 Digital Camera
Canon sd1000 camera won't turn on. battery is fully charged.
Make sure or Check out following thing :-
  • Direction of your battery might be wrong, Check out and put it again.
  • Clean your battery terminal with soft cloth. (Might be it will filled with dirt or dust )
  • Check whether Memory Card/Battery Cover is properly closed.
  • Load new or fully charged battery.
  • Turn ON the camera, again firmly.
Else, Your device need service (repair)
Rating the solution is highly appreciated....Good Luck
Mar 05, 2010 | Canon PowerShot SD1000 Digital Camera
Kodak Easyshare M753 Digital Camera Logo
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
