Question about Cooktops
Replace dcs gas cooktop re-ignition module
How to replace dcs gas cooktop re-ignition module?
  • 2 more comments
  • topbud Sep 24, 2008
    Two hobs bought with the same problems the ignition of two burners is not working. how to fix it ?
    It is clearly a manufacturing fault should I rally more people on the net and go to watch dog. Or is there a fix.
    I am not impressed by the product and response from the shop now close is poor I have been let down !
  • upallnight Jan 14, 2009
    Need to replace the ignitor for the wok burner. Does anyone know where you can purchase a replacement ignitor? Do you have to remove the glass cooktop in order to replace the ignitor?
  • pacoflyer Jan 22, 2009
    One of the 5 igniters on my 30" DCS cook top won't fire. The LED on the dial for that burner also won"t illuminate. How do I remove the igniter to repalce it ?
  • amyrb May 15, 2009
    My DCS has had several problems, this just the latest... 3 of the 5 burners just click and don't light, problem started all at the same time. I usually find cleaning things fixes most problems, but I don't know how to open it up to get to the electrical bits. Frustrating!
    Problem Solver:
  • 7 Answers
Donho1,
most likely the problem is the switch places onto the shaft of the valve. to replace the switch, you would need to remove the burner cap and port rings. you will see a large brass nut that needs to be removed on all 4 or 5 burners. next you would need to remove the nut in the center of the simmer port ring which is also the venturi for the main burner. you must be careful when removing this nut as they have a tendancy to lock onto the jet holder and could be hard to remove (don't strip or break the venturi or holder).....after you remove those nuts, the burners and top can be removed (watch the igniter wires). you can remove the switch by removing the retainer clip that holds the switch onto the valvestem.
Posted on May 28, 2009
DCS CT365SS igniter wires?
no not standard. but you can replace them if you know a good place to buy high temp wires. If not buy the upper wire harness for the range and the igniter wires will be in that.
Jan 06, 2012 | DCS Cooktops
DCS 36 in. CS-366 LP Cooktop ignition
in that burner something is short check it out
Dec 09, 2007 | DCS 36 in. CP-366 Gas Cooktop
Igniter works, but the clicking doesn't stop
The electrode (spark plug) for that burner is not telling the spark module the burner is lit and go ahead and turn off the spark. That electrode and the wiring on it need to be replaced,from that burner back to the spark module. I found this place online that sells that part http://www.expertappliance.com/partfinder-gas-stove-elite.php
Gene
Aug 11, 2011 | DCS 36 in. CP-364GD Gas Cooktop
When turn on by knob, all 6 burners are sparking ( no problem there).Gas goes on, but ignitor dose not shot off. (keeps cliking). Sandy.
Hi sandybaru,
I believe your ignition switches have come in to contact with either water or moisture.
Please read my below Tip on how to fix the problem:
GAS KITCHEN APPLIANCE CLICKING SOUND...
If it does not solve your problem, I'd suggest replacing the ignition switches.
Kind Regards
JEDEMEYER1
* If you found this solution helpful, please rate it
Jul 09, 2011 | DCS CS-366-SS Gas Cooktop
DCS Cooktop CTD-365 one burner won't ignite/no spark or ticking. I cleaned ignitor.
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Aug 11, 2010 | DCS 36 in. CTD365N / CTD365L Gas Cooktop
Problems with DCS cook top ignitors...PARTS?
They are not that hard to replace and you can easily buy the part online...
Here is a tip about how to buy appliance parts online.
How to Buy Appliance Parts Online
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
heatman101
heatman101
Jun 20, 2010 | DCS 36 in. CTD365N / CTD365L Gas Cooktop
The igniters will not stop sparking on my dcs cooktop when I turn the burners on. This happens with all burners.
Because this is happening on all burners, i would say you have a faulty ground to the ignition module.
Dec 19, 2009 | DCS 36 in. CP-366 Gas Cooktop
Where can I get a igniter for the DCS CTD-365n cooktop.
i couls not find this model / reck your model # and need the brand / this will help . sorry mm
Dec 02, 2009 | DCS 36 in. CTD365N / CTD365L Gas Cooktop
Recived spark module for 6 burner gas stove on DCS gas oven/
I want to gas geyser using sparking unit (ckt Diagram)
Feb 28, 2009 | DCS Cooktops
Cooktops Logo
2,300 people viewed this question
Top Cooktops Experts
Marvin
Marvin
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
