first thing i got to ask..did you try using a hair dryer on low heat to dry your hair and tablet after u figured out eletronics and water dont mix? next time try a ziplock bag to keep it dry..ahaah. just kidding. here is a link i use to walk customers thru opening up a tablet..follow it close.. if open it up and use a soft cloth and gently dap any standing water..then let it AIr dry for 24hrs..then if still not working..plug in power for while to warm up..use a hair dryer on low to dry any hard to reach spots..if it still doent power up...use it for a soap holder and buy new one good luck chad man
If you handset is water damages you can leave it to dry out if this dose not work them its time to buy a new one. Watch out when you dry the handset out that you do not over heat it
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
check your print head cos that the main problem. try clean with wet close to remove dry ink. if dont just soak with warm water only part with dry ink ok. dont all print head. u can see all dry ink wove away.
