Question about Acer AL1916W 19" LCD Monitor
Moniter setting I was cleaning my computer by romoving some Aol from control pannel, Then my moniter setting changed From 1280*1024-60HZ to H=90KHz v=60HZ. How do I change my moniter setting
  • Anonymous Aug 14, 2008
    i don't know what i did but now the letters are bigger and aol is saying that some things wont fit the screen,how do i get it back to normal?
    my problem is simular only the fonts are bigger and aol is saying that the dpi is too much how do i get back to factory settings?
    Problem Solver:
  • 6 Answers
1280x1024 @ 60 Hz is a monitor resolution while H=90KHz v=60HZ means
your screen is fine. v=60Hz means you're running at 60 Hz and 90 KHz is just the amount of voltage going to your horizontal lines of the screen. as long as the text size did not change your monitor settings are fine. but if they have changed, do as the other guy said and rightclick on empty space on the desktop - click properties. then click the settings tab and change the resolution slider to one that is most comfortable to you. on vista rightclick on empty desktop space - click personalize - then click display properties. for DPI issues click on the advanced button and select Normal (96) DPI mode and restart your computer.
Posted on Nov 28, 2008
  • 41 Answers
Hi right click on the desktop and go to properties then click on the settings tab and you should find it there
Posted on Dec 17, 2007
Question about my HP desktop model p6-2003 computer blue light on and moniter going to sleep moniter going to sleep
in control panel, select the power Options,, Change the preffered plans to HIGH PERFORMANCE then click on change plan settings, change turn of diaplayto never and put computer to sleep never... Remember to turn on your screen saver and put the pc to sleep manually when not using it.
this is a common problem and caused by corrupted registry entries. The popper fix is to reformat or restore the system.
Dec 29, 2012 | Computers & Internet
Delete my web search toolbar
If you just want to hide it for the moment then just RIGHT-click on the CLEAR area of your toolbars and click WEB SEARCH
If you want to remove it completely from your computer then click the START button on the TASKBAR, click SETTINGS, click CONTROL PANEL, click ADD/REMOVE PROGRAMS, find the web search program and click on it and click CHANGE/ROMOVE
Nov 05, 2011 | Computers & Internet
My Acer P196hqv moniter is always offset by about 50mm when I start my computer, and I have to use the moniter controls to correct it. Very frustrating!
this is because the boot up screen and the welcome screen comprises of many differences they differ in resolution ,colour depth etc so if once the moniter is set for welcome screen it may be irregular for boot window
Mar 24, 2011 | Acer 22" X223w LCD Monitor
I recently purchased a fujitsu siemens laptop but made some errors when setting up user account
hi
i can suggest go to control pannel and in control pannel you will find user account
click on to this option and then you will get the user account that you have created try to make changes from their if you get any kind of problem you can contact me on fixya or you can right me an email on ullekhtandon@gmail.com
Sep 16, 2009 | Computers & Internet
Picture is too big on computer moniter
try to change the Display settings with a higher resolution, example 1024 x 768. It's under control panel - Display and Settings Tab.
Apr 01, 2009 | Dell 2350-DHB7R21 PC Desktop
Monitor user controls display on the screen
Simply change front pannel microswitches(menu,+,-,select)
Check drypoints
replace 5v reg
Oct 09, 2008 | Compaq 7500 17" CRT Monitor
15.6 lcd wide moniter (low light)
It's LCD pannel problem
Remove the LCD pannel and checket flowrocent tubes at top of LCD Screen and Bottom of LCD Pannel. If U Find any burning area at end of F tube, please clean it and solder the flowercent tubes in same possion and connect as same.
Oct 03, 2008 | Acer AL2216WBD LCD Monitor
Mdb8750aws dishwasher dead, no front pannel lights, no functions
I just fixed my washer!!! had power to control board. romoved lower panels openned connection box ( one screw) cut and cleaned wires and reconnected to power line that runs to the plug. Did it twice and finally got a good connection started right up. WAS just about to order a new circuit board. SAVED MYSELF $100.00 !!!!!
Dec 05, 2007 | Maytag 24 in. MDB8750AWS Jetclean II...
Moniter problem
you could try before spending money on it is simply to change the Timing mode in the Windows display settings. Go to "Control Panel > Display", then select the "Settings" tab and click the "Advanced" button. Select the "Monitor" tab and change the screen timing to a different Hertz value in the "Screen refresh rate" menu box. Don't forget to save these settings by clicking "Apply" and "OK" to close all of the Windows settings windows.
Sep 16, 2007 | Computers & Internet
Control pannel
your account/user must be set as guest, you should have it set as an adninistrator, either create yourself a new account or try to change your account type. If you are unable to set an account as administrator you will have to reinstall windows to set admin up.
Sep 06, 2007 | Microsoft Windows XP Professional With...
Acer AL1916W 19" LCD Monitor Logo
331 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
