Question about Dell 1600n All-In-One Laser Printer
Printer 1600 JAM
How do I fix this jam paper in the back of the printer.- Thanks
  • 105 Answers
Assuming you cannot lift the rear door and pull out, you will need to remove the back cover (take out the four screws) and take out the fuser module (it has heat temperature warnings on it so let it cool down before handling). The module has two sets of wires on either side that need to be disconnected. Four screws hold the module in place and need to be removed. The paper usually gets stuck in there. After removing the module, you may need to remove the small rear roller from the module by gently prying it up and out after removing four additional screws on the fuser that hold the metal bracket on the fuser in place. Removing these four screws (two on top, two on side) allows you to slide the bracket up and down and more easily access the small roller that needs to be removed so you can get all the paper out (it will likely be accordion-folded and really compressed in there).
Posted on Mar 27, 2008
Gympac 1600 manual
Device error An internal error occurred in the device. Press (Select) to resume the job. - Door open The printer door is open. The door must be closed before printing can continue. - Engine comm. error The device experienced an internal communication error. This is a warning message only. Job output might be affected. - Invalid driver You are using the incorrect printer driver. Reselect the printer driver appropriate for your device. - Invalid entry Invalid data or response. Correct the entry. - Jam in Cartridge area A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel - Jam in Output bin A paper jam has occurred in the output area. Clear the jam, and then press the (Select) button on the control panel. - Jam in print paper path. A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel. - Jam in tray 2 A paper jam has occurred in Tray 2. Clear the jam, and then press the (Select) button on the control panel. - Jam in tray 3 A paper jam has occurred in Tray 3. Clear the jam, and then press the (Select) button on the control panel - Load paper The HP Color LaserJet 1600 printer is out of paper. Please load specified paper type into the tray indicated. - Load Tray X [TYPE] [SIZE] The printer is processing job, but the tray indicated is empty. Please load specified paper type and size into the tray indicated. - Manual feed The printer is waiting for paper in the tray indicated Load the paper as indicated. - Memory is low The device memory has been almost completely filled. Allow the device to finish the job, or press (Select) to cancel the job. Break the job into smaller jobs that contain fewer pages. - Misprint The printed pages have been incorrectly placed on the paper. To continue, press the (Select) button on the control panel.
Dec 31, 2014 | Office Equipment & Supplies
Jam in tray 2 bt there is not paper jams
There may be paper remnants left over from a prior feed jam. Please click the link below and select printers - jams and feed issues to find more info.
HP Color LaserJet 1600 Printer
Aug 21, 2014 | HP Color LaserJet 1600
Hp Color Laserjet 1600 says Jam in tray 2 bt there is not paper jams
Open the paper feed area and the printer, examine the paper feed path and make sure there isn't a page or piece of paper jammed in the path somewhere.
HP LaserJet 1020 paper jam alert
Here's a video Harshit kumar suggested as a solution to your problem from YouTube:
Fixing a Paper Jam - HP LaserJet 1020 Printer
Apr 17, 2013 | HP LaserJet 1020 Printer
How can i fix my paper jam on my epsom 1600, multi printer
Hi Gary, if you've done all this put off the printer and switch it on again. If it persists then a technician needs to open it.
Jun 28, 2012 | Office Equipment & Supplies
What's the problem "jam in
There is a sensor flag that hangs down where the paper comes out on top, check that as there might be something stuck in there, also, pull the fuser out and look in there closely because it has a small exit sensor flag on it and could also be stuck in the open position( looks like a little black plastic piece that is spring loaded and when moved should snap back when released) give it a shot... GO HERE If this helps you out please remember to mark as FixYa!!! thanks...
Jul 28, 2011 | HP LaserJet 1600 Printer
Several sheets entered the printer at the same time and stuck. can't pull them forward or backward.
Step 1 Clear any loose paper from the paper tray. This will help you locate the jam. You will find it either in front, near the paper tray, or in the rear.
Step 2 To clear a paper jam near the paper tray, grip the paper and pull it firmly but gently from the printer. If you find a stack of papers jammed, grab from the middle of the stack and pull.
Step 3 For a rear jam, remove the back of the printer. When you find a free edge on the paper, grip it firmly and pull it out.
Step 4 Replace the back cover. Press the "Resume" button or turn off the printer, and then turn it back on. Your settings should reset.
Step 5 Try printing another document
Jan 13, 2011 | HP PSC 1600 InkJet Printer
I have a paper jam and it says to open the front cover, put the front cover just shows the ink cartridges and there is no visible paper jam. how do i find the jam and remove it? It's a canon image...
The paper jam could be in three places.
Open the cover of fixing section, its above bypass, and check for jamed paper
Open the transfer cover, these cover has handle and it goes by pulling toward you, and check for jamed paper.
In hight of first paper cassette, on left sideway of copier, beaneath the bypass are small door, open it and check for paper jams. Be sure that you closed them properly because if they arent closed the check printer cover message will arrise.
Hope that helped
Jul 07, 2010 | Canon ImageRunner 1600 Copier
Canon iP 1600 printer won't print. Says that
If it keep saying paper jam Then it maybe just that you may not see any paper in it but it only takes a very small bit of paper that stopping it or I would take a closer look inside, you may have had a paper jam before and it has left a small nit inside. All Best: Pineworks
Feb 01, 2010 | Canon PIXMA iP1600 Printer
Canon pixma ip 1600...can't clear paper jam there is no paper jam but it keeps telling me there is
possible that there is a very small piece of paper near the edge or back that the sensor is picking up ... check again and see if there is something there
Jan 10, 2010 | Canon PIXMA iP1600 Printer
Dell 1600n All-In-One Laser Printer Logo
Top Dell Office Equipment & Supplies Experts
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
