Question about HP Photosmart C5180 All-In-One InkJet Printer
HP c5180. Can't print pink/magenta
Just repaired the encoding strip. Now I can't print pink/magenta. I replaced the pink cartridge because it was low. The ink gauge says everything is okay. I think the print head must be clogged. I did run a clean the print head multiple times and still no luck. Interestingly enough. If I run an printer head alignment, it does print the pink/magenta color. Could I have damaged the electronic strip that connects the control lid to the printer causing this problem? Or is it just a clogged print head from lack of use and how can I fix it?
Ed
  • pyuned Sep 27, 2009
    I don't think that will work. The pink/magenta does print when the "printer head realignment" is run. It doesn't run during the "self test" report or in regular printing
aomcopier
  • 22 Answers
SOURCE: Lexmark 5150 All in One Printer - Encoder Strip
I hope this helps. There is usually a spring that holds the encoder strip on either or both ends. The have a hole that the spring is inserted in. The hole brakes and the encoder strip comes off. If you have all the parts including the spring you can modify the encoder strip by cutting a piece of strong tape to fit over where the strip was broken. I use packing tape. Poke a hole in it and reinstall encoder strip. You should also be able to buy a new strip but I am not sure. I also would go to an electronic store and find a tool to help. Buy a spring hook. It is designed to help push on and pull off springs and they only should cost a couple bucks USA. I hope this helps, Bill
Posted on Apr 01, 2007
jackboy
  • 2985 Answers
SOURCE: Everything printing in PINK
Assuming you have successfully eliminated cartridge/print head problems, the only other thing to try is to delete the printer software and reinstall [Start/Printers and faxes -right click on the printer icon click delete- install new printer -Have the software disk and handy or select from list- select maker, select model,] I suspect the problem is still print head/cartridge however
Posted on May 11, 2007
Cindy Jo
  • 74 Answers
SOURCE: Encoder Strip
What is the question? Where should you put the numerical strip of ownership? Let me know and I will send you in the right direction.
Cynthia Charczenko
Posted on Jan 15, 2008
  • 390 Answers
SOURCE: encoder strip
Is it just loose or out of its slot or is it faulty and you need a new one?
Posted on Feb 12, 2008
  • 133 Answers
SOURCE: hp c5180 won't print black
Try a hard restart, which simply means unplugging the power cord of the printer, and replugging it after one minute has passed. This technique reprograms the electronics to a certain extent.
You can also visit the HP website, which provides solutions to various printer problems. Anyone can access this information. Some solutions are specific to your model and some are applicable to other models. You might have to sift through a few pages of solutions, to get to the ones you want.
Hope these suggestions help you out.
Posted on Jul 04, 2008
My hp priter is printing pink lines in the edges of my paper
Your magenta toner cartridge or magenta print cartridge is leaking ...you should replace it (magenta is the red one).
Mar 23, 2014 | HP LaserJet Office Equipment & Supplies
My hp c8180 printer won't print pink
check magenta cartridge if its showing low replace that
Nov 04, 2013 | HP Photosmart C8180 All-in-One InkJet...
Im using hp deskjet 2660 cartridge says INTRODUCTORY HP TRICOLOR PRINT CARTRIDGE (colors) cyan magenta yellow 60 it's not producing yellow images that i printed are in pink or purple i...
This model printer has only two slots for ink cartridges. One is for a black ink cartrigde and the other is for a tri-color cartridge which contains cyan, magenta and yellow inks.
This tri-color cartridge has run out of yellow ink, you need to replace this tri-color cartridge.
Aug 12, 2011 | Office Equipment & Supplies
Why does the blue colour turn out red on printing plus the yellow is mainly pink?? I am trying to print out invites for my son's 10th birthday & he is not impressed with the pink!!
See if the ink cartridges are installed correctly. It may be that your Magenta and Yellow ink cartridges need to change places. So, try replacing the cartridges, put the Magenta where the Yellow is, and the Yellow where the Magenta is.
Usually the ink cartridge placement follows this order:
Cyan, Magenta, Yelow, Black, so see if the cartridges on your printer match. Also, check to see if there are color markings on the print-head itself, and make sure the markings match the cartridge inks.
If the ink cartridges are aligned properly and the Black is printing out just fine, you may be looking at a software issue, and you'll need to remove the printer from the Devices list (go to Start -> Control Panel -> System), unplug the printer from the PC and restart. Then, install the drivers first, and after that plug in the printer cable to the PC.
If this was helpful and informative please vote with a Thumb Up. Thank you.
Jan 28, 2011 | HP Office Equipment & Supplies
Hi Everytning I print has a very narrow pink line straight down the centre of the page, also every so often the print has a black/yellow/blue/pink thick line running across the page. Thanks
The narrow pink line is coming from your magenta toner/drum cartridge. You may be able to open the from cover and look at the 4 toners. If you look at the magenta (like pink) cartridge, you might see the thin line on the drum surface.
The multicolored band that sometimes shows up on your prints is most likely the transfer belt unit. This is caused by an area of the belt that is not being cleaned very well. This probably tends to show up when you are running mutilple prints of a page.
So it looks like to may need to replace your magenta toner and look at getting a transfer belt unit.
May 13, 2010 | HP Color LaserJet 2600n Printer
Color does not print properly
look for ALIGN CARTRIDGES in the TOOLS MENU
Jun 03, 2009 | HP Photosmart C5180 All-In-One InkJet...
Bogus message to replace print cartridge
To resolve the issue remove al the print cartridges and clean the print heads. Now insert all cartridges and try to align the printer. Click here for instructions to align the printer.
May 21, 2009 | HP Photosmart C5180 All-In-One InkJet...
HP 8500 Laser Printer
Did you pull the strip on the Magenta toner when you loaded it into the unit?
Jun 30, 2008 | HP LaserJet 8500 Color Printer
HP Photosmart C5180 All-In-One InkJet Printer Logo
432 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
