Question about Boating
2004 Skeeter Bass Boat replacing dash panel with upgrade kit.
Installing the upgrade dash kit wiring harness. No directions or diagrams to assist in this problem.
SOURCE: What wiring harness and deck install kit?
My husband and I just installed a Pioneer DEH-2000 MP today in my 2004 Sentra, which we bought at Electronic Express. They didn't have the wiring harness or the install kit we needed, but Best Buy did. Just go there or some other electronics/car audio place and tell them what vehicle you are installing your stereo into. Make sure you do have all the same color wires and numbers of them on your harness(s) as you do for your stereo - they should of course match, and the plugs of the harnesses will match those of your truck. Don't freak out if you don't use all the plugs in your truck though - one may be left because it was proprietary to your stock radio. A couple of good install kit brands are Scosche and Metra - both use factory colors and molding that will match the color and lines of your dash to make it look as integrated as possible.
Hope that helps!
Posted on May 27, 2008
SOURCE: whirlpool duet washing machine door lock error
My front loader has the door locked and I can't open it. I have already turned off the power and that didn't solve the problem. The manual says that if you try to open the door too soon after the cycle completes, then the door locks. How do I open it now? What do I do?
Posted on Jul 03, 2008
jmeyer847
  • 185 Answers
SOURCE: installing after market stereo
Dave,
You will need to go buy a wiring harness adapter from your local Walmart (usually cheapest there) or Local Electronics place (ie Best Buy). The wire harness that goes out from the radio goes into the Adapter and the adapter plugs into the car harnesses. Also these Adapters come with the wiring diagrams for your vehicle. They typically run 10 - 15 bucks depending on where you get them. Thanks for using FixYa!
Sincerely,
JC
Posted on Nov 21, 2008
  • 3 Answers
SOURCE: I have a 90 Horse power Mercury outboard Boat
Sounds like the starter. Check if you have power at the solenoid from the battery with just the power on (key turned on, power switch on.) thats good-- you have power-- if not you have a wiring problem from your battery or main switch.
Otherwise you have a starter problem probably.
Posted on May 17, 2009
ZJLimited
  • 17970 Answers
SOURCE: 2004 ford escape wiring diagram
This is for 2005 Escape, its possible that can helpfull... LINK
Hope this help.
Posted on May 15, 2010
1995 Cajun bass boat. Where can I get a wiring diagram?
cajun manual and parts manufactures
www.bbcboards.net > BBC Boards > Bass Boat Forums > Cajun Boats
Jul 18, 2011 - 13 posts - ‎11 authors
... for cajun boats and also a complete manual in pdf format and wiring schematics. ...bassmannbama is offline ... a wiring diagram too because switches arent working andmy wiring ... My email is : steve1995z@hotmail.com.
Cajun Boats Owner's Manual 1992+ available on pdf
Apr 19, 2012 - 4 posts - ‎4 authors
I scanned in my owner's manual and have it available if anyone is ... Mine is a '95 1950 Fish n Ski, but I believe it would cover bass boats as well. ... Looks like I'll need to learn about electrical and general boat repair.
Nov 19, 2015 | Boating
How do you put normal cd player in 2004 model ford fusion
You will need an adapter kit for the dash panel specific for the Fusion or a multi kit, both availible at an Auto Parts store. You should also buy the wiring harness for the Car as well, this will make life much easier on you! Connect the harness to the stereo, following the schematic/diagram. Pop the dash panel apart and remove the old stereo. Slide the adapter plate over the wires FIRST, then connect the wire harness, put the adapter plate in place and then slide the stereo in place, re-assemble the dash...
Jun 11, 2012 | 2006 Ford Fusion
I have a 2004 Hyundai Elantra and am trying to install a stereo but dont know what the wiring diagram is..any help?
Personally owning this car and installing several Hyundai stereo's, I would purchase a wiring harness kit from car audio shop or electronics retailer. The wire harness has a plug that connects to the cars wiring harness. This wiring harness kit will also list the wires to connect your new aftermarket radio to the harness. I would also recommend using crimped **** connectors to attach the two harnesses together.
Feb 24, 2010 | 2004 Hyundai Elantra
Replace factory radio on 2002 yukon xl
all you gotta do is carfully pry the dash panel off (prying from the far left end is easiest) completely remove panel. then there are 2 clips that hold the factory sterio in place. push on the both clips while pulling the radio out. simply disconnect the wiring harness from the back of the radio. using an adapter avaliable at your local radio shop (scosche p/n gm02, mdarb and gm1483b) wiring harness, dash install kit, and antenna adapter. then simply match the colors on the new radio's harness to the adapter harness, crimping each connection with a "but plug". then simply follow the instructions included with the dash install kit to assemble the kit.connect the antenna adapter to radio, plug in all cables. test to see if everything works properly before the final install. install sterio into dash install kit, re installing kit where origional radio was. then simply put the panel back in its place by firmly pushing on it untill it snaps into place. then enjoy your new radio!
Dec 29, 2008 | 2002 GMC Yukon XL
Installing a 7-pin trailer towing recptical on a 1991 Ford F150.
I believe you can look up the manufacturer of the trailer plug kit and find the wiring diagram there. On alot of the trailer plug kits, they have pics and diagrams in the package. The 7 pin plug (truck side) is available with the pig tail set up that plugs directly into the wiring harness for the lights. Then all you would have to worry about is the 2 wires for the electric brakes.
Nov 29, 2008 | 1991 Ford F150
Stereo Upgrade in 1997 Sentra
hi there. I am not sure about the speakers. But there is a wiring harness available for a aftermarket head unit. I have a '97 sentra the base model XE version. I have just put in an alpine head unit and you defenately hear the difference even on factory speakers. But you will need 2 kits to install an aftermarket head unit in the car. 1. A dash kit. I got mine from canadian tire for about 20 bucks, it comes with instructions on how to put it together and its straight forward, just make sure u get the one for your year and make of car.
2. The wiring harness. there available at mostly every car audio place for about 10 bucks. again make sure u get the one for your year make and model of car. installing this is difficult so unless your good at electronics get it professionally installed. you have to splice the wires into the back of the aftermarket unit, then the plugs plug right into your existing factory car harness.
hope this solves your problem, the dash kit is easy to put together and install into the car, but the wiring harness is a bit difficult, i had my harness installed for about 40 bucks and u save money if u put the dash kit togehter yourself because thats 1 less thing they have to do. good luck.
Nov 29, 2008 | 1997 Nissan Sentra
you should be able to look it up at the place of purchase, stores like wal-mart have books with info for the specific vehicle, online like crutchfield will probably tell you everything you need.
May 26, 2008 | Car Audio & Video
Boating Logo
619 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
