Question about Pentax Optio E30 Digital Camera
Hi, My Pentax Optio E30 has come up with a lock symbol on screen when I push Menu or Mode. Nothing I can do will remove it and it's not mentioned in the manual! Would appreciate advice if you knowhow - thanks soooo much.
If it's like mine just was, it's probably stuck in green mode. If that's the case, just hold the delete button for a bit and it should go away and allow menus again.
Posted on Dec 27, 2009
    Brigadier General:
  • 11,967 Answers
In the setup menu, scroll to "reset" and follow the on-screen instructions.
Posted on Sep 28, 2009
  • sharonmat470 Jun 21, 2011
    I followed both solutions for this question. If I hold the delete button, the green mode will not go away and when I select the reset button it will not reset. What else should or can I do?
I'm trying to set th time and date on my camera but when I hit the menu button the yellow lock appears how can I get rid of this so I can set time and date correctly please
Hi Keith, The link below is the user manual for the Pentax Optio E30 Digital Camera, On page 56 it says
• In Green Mode, you cannot change the information displayed on the LCD monitor by pressing the 4/W button.
• You cannot use the [A Rec. Mode] menu or Capture Mode Palette in Green Mode. If you try to display the [A Rec. Mode] menu or Capture Mode Palette, - (key lock icon) appears.
• If you switched to Q mode from Green Mode, you cannot display the [H Setting] menu by pressing the 3 button. If you try to display the [H Setting] menu, - (key lock icon) appears.
• When the camera is turned off in the Green Mode, it turns on in the Green Mode next time the power switch is pressed.
THIS IS YOUR CAMERAS USER MANUAL.....CHEERS..
http://www.camera-usermanual.com/manuals/pentax/Pentax_Optio_E30.pdf
Mar 27, 2016 | Pentax Optio E30 Digital Camera
I need the instruction of the camera all the mode and menu
http://www.pentax.co.uk/en/Photo_Downloads.html
Scroll half way down and you will find the E30
Hope this resolves your problem
Dec 07, 2010 | Pentax Optio E30 Digital Camera
I can't access my menu, a lock icon appears on the screen for a Pentax Optio M10 Camera
your menu's locked (yellow icon) if it's in green mode. exit the green mode, and you'd get your menu back.
just fyi, since i helped my dad troubleshoot his cam (same model as yours) a while back.
Jul 02, 2009 | Pentax Optio M10 Digital Camera
SD memory prohibits functioning of Pentax E30
I know that usually, you should format the card for the camera that your going to use. Try formating it in the camera and see if that works. Let me know if I can do anything else for you,
Rob
Feb 22, 2009 | Pentax Optio E30 Digital Camera
How??
hi cacrom3,when you slide the battery compartment open the memory card is be side the batterys just push it down and let it go it should pop up so you can grab it.
Dec 10, 2008 | Pentax Optio E30 Digital Camera
Remove green mode
hi their bettyboop021
i have a pentax e30 and my green mode is the delete button
Dec 03, 2008 | Pentax Optio M30 Digital Camera
Pentax Optio M20
Found the following on a website about these cameras...
http://www.digitalcamerainfo.com/content/Pentax-Optio-M20-Digital-Camera-Review/Modes.htm
"The second, and previously mentioned automatic mode, is the Green mode that restricts the camera controls to two flash settings, three AF options, zoom, and a self-timer setting. This mode locks out the menu systems, manual focus, mode menus and other options. It’s definitely easy to use, as all one can really do is point and shoot."
This may be a internal software confusion problem. If it is, the following may help.
Make sure your buttons or dials are not on AUTOMATIC, that appears to set the green mode.
I think I would remove the batteries. Next, if the camera has a small battery (similar to the bios battery in computers) remove that as well. Let the camera sit over night. You will need enough time for the capacitors to discharge. Then put the batteries in again, and try.
Jun 30, 2008 | Pentax Optio M20 Digital Camera
Pentax optio e30 lock icon....
Yeah had me baffeled too. Press the 'menu' button then the 'trash / green' button, one after the other. It unlocked mine.
Feb 21, 2008 | Pentax Optio E30 Digital Camera
Symbol of a lock
I had the same problem - try this. Switch to playback mode by hitting the play button. In playback mode try the menu button (It worked for me). In the settings scroll down to the reset option and reset all camera settings.
Hope this works for you
Dec 11, 2007 | Pentax Optio S5i Digital Camera
Card NO formatted
If u get a lock(A small switch on the left side of the card) on ur card try changing its position.Move it to other side.
Oct 25, 2007 | Pentax Optio E30 Digital Camera
Pentax Optio E30 Digital Camera Logo
612 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
