Question about Tao -IKTV-DVD : DVD Karaoke Entertainment Station with 1 Microphone
I lost my AC adapter input that goes to electric outlet. It is also kind of old, so I don't know if there are other probs too
Printer light comes on and then goes off
Had this happen to me last week. The AC adapter that goes from the printer to the electrical outlet had died. Kodak told me I'd have to order a new one for $65. Luckily I still had the AC unit that went to my old Kodak printer that died a couple of years ago.
May 26, 2014 | Kodak HERO 7.1 PRINTER
What kind of plug adapter does my recorder take?
you will need a 6v or six volt power adapter to use a house hold electrical outlet. You can use it in your vehicle if your adapter can convert 12 volt dc to 6volt dc
May 11, 2014 | General Electric 3-5027a Portable Cassette...
Lost electric for lexmark z611 printer in moving. What kind of electric source do I need
Lexmark InkJet Z611 Printer AC Adapters and Power Supply Unit. Contact sparepartswarehouse.com
Feb 15, 2014 | Lexmark Z611 InkJet Photo Printer
What's your problem? the wii wont turn on
    • 1 Disconnect any accessories, such as GameCube controllers or SD cards.
    • 2 Unplug your Nintendo Wii AC adapter from the wall outlet and from the back of your Nintendo Wii. Leave the adapter disconnected for two minutes. Reconnect the adapter to the console and plug the outlet end straight into a wall outlet, not a surge protector.
    • 3 Remove the AC adapter from the wall outlet again. If the Wii has yet to turn on, the problem may lie within your electrical outlet. Plug a lamp, nightlight or something electrical into the outlet the AC adapter was connected to. If the outlet appears to work, then you'll have to test the AC adapter itself.
    • 4 Run your fingers along the AC adapter cable and visually look for any damage, such as frayed wires or a cracked piece of cable. Also look for the model number "RVL-002" and "Wii" on the adapter. If you don't see the "RVL-002" model number and "Wii" on the adapter, then you are using an unlicensed adapter, which can cause instability and power failure. If the adapter has incurred any damage, you will likely have to buy a new adapter.
    • 5 Spray air to clean out the vents on the back of the Nintendo Wii. If your Wii has been sitting for a long time, then dust and dirt may have built up around the vents, preventing the console from cooling itself. If the console cannot cool itself, it overheats and shuts down.
    • 6 Click "Start," "Internet Explorer" and visit the Nintendo repair page (see Resources) to open a repair claim. If you tried the above steps and your Wii has yet to power on, your system probably needs professional repair.
Oct 05, 2011 | Nintendo Wii Console
How to charge my new battery for laptopLG K1 Express
connect the ac adapter to ac input..then plug the adapter to your electric outlet..
make sure you plug in to the right voltage ,read manuals of your machine for proper care and maintenance
goodluck..
Feb 20, 2011 | Computers & Internet
I need the input voltage for ac adapter for my GE 98903 2.1 Pro Speaker System
The AC adapter input voltage is 120 Volts AC as it plugs into a wall outlet. I suspect you want to know the output voltage of the transformer. If you have the old transformer the output voltage is listed on the transformer top. May be hard to read but it is there. This system is also sold under then brand name Jasco. The Input voltage of the system should also be printed next to the power connection or on the speaker itself.
Nov 11, 2009 | Cars & Trucks
Don't know how to hook them up
What a lovely daughter, how very nice of her,
here goes....straight for Mr. Koss
To Operate with AC Adapter
  1. Open battery compartment located at the back of both speakers and remove wires.
  2. Replace battery covers.
  3. Connect DUAL PLUG CONNECTOR on left speaker to right speaker at connection marked "TO LEFT SPEAKER."
  4. Connect remaining wire with 3.5mm plug to headphone jack on your audio source.
  5. Connect AC adapter (not included) to back of left speaker at connector marked "DC 6V." Plug remaining end of AC adapter into wall outlet. Be sure your AC adapter is built with the center pin as ("-") negative. Connect remaining wire with 3.5mm plug to the headphone jack on your audio source.
  6. Turn ON/OFF switch at back of right speaker to "ON."
  7. Set "INPUT SELECTOR" switch to audio source.
  8. Turn on audio source
  9. Adjust sound in the following ways: Turn volume control to desired level; push Bass Boost button located on right speaker to "ON" for added bass; push Treble Boost button on right speaker to "ON" for added treble
  10. Operating a microphone through your speakers require an additional 3.5mm plug to 3.5mm plug cable (included). Connect cable with 3.5mm straight plug to right speaker at input marked "MIC" on back of speaker. Plug the remaining 3.5mm L--plug into the mic input on audio source. Connect your microphone to the front of your speakers at "MIC" input (microphone not included)
Hope you have all of the skinny you need, good luck,
please leave a rating, thank you kindly
Apr 27, 2009 | Computers & Internet
Is there an adapter for a 4-prong plug to fit a 3-prong 220
they dont sell adapters like that..you have to change the cord and it wont hurt the dryer at all
Jan 29, 2009 | Maytag PYE2300AY Electric Dryer
Plugged US purchased Wii into Europe outlet with an adapter and n
You would need an adapter that not only runs at 120 or 240 volts, but also one that OUTPUTS 120v. The Wii may have some kind of protection in it if you're lucky (most people don't hook up US Wii's to 240v). But if not, you've killed your Wii. Check the adapter, if it has a fuse that's removable you should see a (usually) circular cap kind of thing on the brick you can unscrew and pull the fuse out.
As for what you would need to purchase, it would be something like this: http://www.amazon.co.uk/Step-down-voltage-converter-240V/dp/B000L99ZJ2 would work perfectly. The Wii only draws at maximum 30watts and this unit does 100. Your TV on the other hand would need a higher wattage unit.
Jan 08, 2009 | Nintendo Wii Console
Bad Battery on EMachine M622-UK8X?
Pull the battery and try powering on the laptop. If it comes up without any problems, it is probably time to invest in a new battery if you want to continue using it as a laptop.
Jun 09, 2008 | Computers & Internet
60 people viewed this question
Top Tao Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Tao Audio Player and Recorder Expert? Answer questions, earn points and help others
