Question about Buck Rock & Ice Climbing
How to install Butler Creek Black Easy Rider Stretch Rifle Sling 80073 on my rifle.
  • 8 Answers
SOURCE: RIFLE SCOPE STUCK ON 8x POWER
If the scope's minimum power isn't 8x then it's broken. Call the customer service rep of the company and see how you can return it. Depending on the warranty they may fix it or replace it. I'm not familiar with Balfor as I don't shoot BB guns. You can move the ring around a bit, see if something loosens up, but don't force it.
Posted on Nov 26, 2008
Doktir
  • 55 Answers
SOURCE: leakin air cylinder on my daisey model 3880 bb gun rifle
The o-ring or gasket is worn and can't take more pressure after the 5th or 6th pump, you should be able to get a gasket kit for it from your retailer. Hope that helps!
Posted on Mar 10, 2009
  • 88 Answers
SOURCE: Crossman Sierra Pro Air rifle
If the trigger is adjustable set it more coarse to hook the piston rod. Make sure trigger is loose and will reset to it foremost position. Check trigger spring and pin for ease op operation. Lastly check if piston rod did not turn inside cylinder so hook is turned away from trigger.
Posted on Aug 29, 2009
  • 88 Answers
SOURCE: co2 leaks from chamber on crossman modle400 rifle how do i fix it
Check thare is a rubber o ring missing or broken in the air chamber
  • 2418 Answers
SOURCE: rifle scope fogging
You can try to clear this your self. You will need a good sized clear plastic bag, say kitchen trashed can size. You will need to get your hands on some nitrogen or you can also use carbon dioxide. You will need some good electrical contact grease or Vaseline will also work. Take the focus lens off your scope, let it dry out. Now ck for any o-rings and try to find new if you can, put the grease on the screw threads.Put all the scope parts in the bag and pump up the bag with your nitrogen and tie off the bag but leave room so you can screw the lens back on once it has set for a little bit in the gas. This should let gas stay inside the scope so no moisture can get back inside to fog it up. Try that, sounds crazy but it will work.
Posted on Dec 05, 2009
Needthe rifle sling
    Sling setup for the Marlin Model 60 22 auto - THR
    www.thehighroad.org > ... > Gunsmithing and Repairs
    Dec 31, 2009 - 5 posts - ‎3 authors
    Just bought a model 60 about 3 months ago and I'm very happy with it performance. I notice it did not come with ... You need a standard set of sling swivels like this. ...Check out slings for muzzleloaders or a tube fed lever gun.
  1. Marlin Sling at Amazon‎
    Adwww.amazon.com/Sports‎rating for amazon.com
    Free 2-Day Shipping w/ Amazon Prime Buy Marlin Sling on Amazon
Jan 18, 2016 | Marlin Model 60 .22 Long Rifle 19 Inch...
Instructions to mount scope
PDF]OWNER'S MANUAL - Crosman
www.crosman.com/pdf/manuals/M4-177-515.pdf
Translate this page There are two different rear sight options for the M4-177 depending on which model you purchase.) Option 1- ... the airgun in any way inconsistent with this manual may make your ... Adjust the rings on your scope to match the measurements of the top rail. ... Toattach the sling at both ends push the sewn webbing loop end.
Crosman M4-177 Multi-pump .177 Pellet Air Rifle Table Top ...
? 24:29
https://www.youtube.com/watch?v=s_0grKCOmX0
May 18, 2012 - Uploaded by Replica Airguns
ReplicaAirguns.com - Crosman M4-177 Pellet-BB Multi-pump Air Rifle ... -Single shot - bolt action with manual advance magazine.... I particularly like the removable iron sights and full rail formounting a scope or red dot sight.
Crosman M4-177: Installing and Adjusting the Sights ...
? 8:38
https://www.youtube.com/watch?v=x8XKOmb41QA
Aug 28, 2012 - Uploaded by Crosman
A detailed look at installing and adjusting the sights for the M4-177 and sighting ... Crosman MK-177 Pellet-BB Multi-pump Air Rifle Table Top ...
Crosman M4-177 shooting rev
Dec 20, 2015 | Crosman M4-177 Air Rifle
Daisy repair
My Red Ryder B B gun is jammed-I have shot and shot it still no bb willcome out
Jan 03, 2014 | Daisy Model Red Rider Rifle 1938 BB Guns...
Simmons 3x10x44 mag, need bulter creek size
Use a caliper to measure the size of the bell you want to purchase the cover for. MidwayUsa has charts on their website. The eyepiece chart is here:
Butler Creek Flip Up Rifle Scope Cover Eyepiece Rear
Nov 28, 2013 | MAG Optics
Does the TC Omega have a problem using 150 grains of blackpowder or its' eqivalent?
Hello jps.... No problem at all with 150 grains. In fact, that is the spec. max. amount. The Thompson Center Omega Z5 was designed with simplicity in mind. It is easy to shoot and easy to clean. The breech seals the 209 primer from rain and snow and is easy to open with a simple forward motion of the lever on the trigger guard. The sealed breech plug design also prevents the crushing of Pyrodex pellets. The Z5 can handle a powder load of up to 150 grains for more power or longer range shooting.
Technical Information
Notes:
  • Exposed hammer
  • Sling swivel studs
  • Rubber recoil pad
  • Fiber optic sights
  • Blue chrome-moly steel with a silver weatherguard finish
  • Joe
    Thanks for choosing Fixya!
    document.getElementById("divReviewInfo").className = "reviewInfo";
    Jan 02, 2011 | Thomson Thompson Center Omega Z5 Rifle -...
    Windage and elevation adjustment all over the place
    Sounds like you want to "re-sight" in your rifle. Make sure mounts are okay and tight. Look down barrel and then thru scope and eyeball windage and elevation adjustments so the scope seems to be fairly in line.
    Clean barrel if it needs it.
    For basic sight in, start at 25 yards with a large(3 to 4 feet) cardboard or wood backdrop around target (bullseye). Fire at target. Once done, look through scope and position rifle such that the shot mark you created is dead zero. Hold rifle very steady and you or buddy move windage and elevation adjustments until scope moves dead zero back toward original target (bullseye). Fine tune from there. Air cool rifle between rounds. Once dead eye, fire another round or two to check grouping. Check your ballistics (sometimes on ammo box) to see how height at 25 yards affects your desired dead on target (100 yards, 150 yards, 250 yards etc.). Adjust accordingly. Example: you may need to sight in at an inch high at 25 yards, depending on your dead on target distance..
    Always remove sling from barrel when sighting in.
    Try to sight in at similar temperature as you intended shooting temperatures, if possible.
    If not black powder, avoid cleaning barrel between sight in and hunt/competition unless you note bad buildup inside.
    If you change ammo, understand that that may affect performance. Once a preferred ammo is found, some even try to buy a decent quantity with the same lot number on the boxes if storage allows for such.
    May 02, 2009 | Optics
    Rock & Ice Climbing Logo
    1,628 people viewed this question
    Top Buck Rock & Ice Climbing Experts
    Makenzie Floyd
    Level 1 Expert
    Betty L Kidd
    Betty L Kidd
    ray gallant
    Are you a Buck Rock and Ice Climbing Expert? Answer questions, earn points and help others
