Question about Freezers
No water to ice maker but I get from the water dispenser
I can't get any ice from my ice maker because water isn't getting there but I do get water from my water dispenser.
  • 832 Answers
Check the waterline as well as the valve supplying water to the ice maker.
Posted on Sep 27, 2009
I cant get water to the ice maker
If the solenoid that controls the water intake is not activated either because it is defective or is not receiving the voltage from the ice maker, no water will flow into your ice maker. Make sure that the line is also not clogged - not likely but .............
Jan 25, 2014 | Kenmore 25.0 cu. ft. TRIO Ice & Water...
Won't make ice but will dispense water.
the gear assy in your ice maker is proably bad, it is less expensive to replace ice maker as a complete unit. 10 minute fix
Mar 03, 2013 | Freezers
Ice maker not working on Kenmore Model # 106.54563300 Water comes through water dispenser fine Water came pouring out through ice dispenser door so I flipped bar up to turn it off Removed front box held in...
First the arm has to be in the down position. It sounds like you said theres water in the ice maker. If thats the case then it should have frozed. The ice cannot drop unless the ice maker heater comes on. Then the ice maker scoops the ice and drops into the resoviour thingy. If you have ice in the ice maker tray but no ice in the bucket then the ice maker is defective.
Mar 25, 2010 | Kenmore Freezers
Whirlpool GR2FHTXVQ00 fridge. Water dispenser
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
The valve can leak because of sediment in the water preventing it from closing or low water pressure.
You can thaw out the fill tube and replace the inlet valves.
Oct 13, 2009 | Freezers
Ice maker not getting water
Probably the dual water valve (that opens when the ice maker needs water ) is leaking and the filling tube gets clogh with ice , or the valve doesn't work ,in both cases it has to be replace.
Aug 17, 2009 | Whirlpool Freezers
Ice cube tray isn`t filling with water but I have water on the door dispenser.
Hi, Check the inlet tube that comes through the back wall into the ice maker. See it has froze shut.
If there is ice in the tube, thaw it out and let the ice maker cycle. Plan on changing the inlet valve if the tube is plugged.
If the inlet is not plugged, let the ice maker cycle and listen for or test the valve for 120V. If there is a buzzing sound or you are getting voltage and no water, remove the tube frrom the valve that leads to the ice maker and see if water comes out of the valve.
If no water comes out of the valve, change it.
I hope this helps you.
Please let me know if I can assist you further.
Vic
Jun 05, 2009 | Freezers
No water to ice maker or water dispenser
You're funny. This is a portable 12/120 volt model. It dosn't have a water dispenser or ice maker :-)
Dec 27, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Kenmore Ice Maker
Sounds like a water valve problem to me. Force the ice maker to cycle. (turn it off and let it get cold for at least an hour then turn it back on). Test for voltage on the ice maker side of the valve. The valve is usually in the back near the floor. Just follow the water line. Another solution. switch the wires on the water valve. then try the water dispenser and see if it makes the ice maker fill up. See if when the ice maker cycles water comes out the door. If the ice maker causes water in the door , replace the valve, If door switch causes ice maker to fill up replace ice maker again.
Jun 27, 2008 | Freezers
Water dispenser / ice maker whirlpool fridge frezzer
Check that you haven't turned the ice maker off in the menu.
thanks J
Jan 15, 2008 | Freezers
Freezers Logo
94 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
