Question about GE Profile Harmony DPGT750EC Electric Dryer
Harmony dryer g e harmony dryer dpgt750ecipl it quit drying i tryed to change setting but it dont get the close dry i cleaned the vent what do you suggest?
  • Anonymous May 10, 2008
    dryer heats up but wont blow air i cleaned the lint trap but the motor doesnt seem to be working
  • ped52 May 10, 2008
    dryer heats up but dont blow air the motor doent seem to be working i cleaned the lint out
  • 833 Answers it getting warm at all? First thing to reset the circuit breakers. Find the linked breakers, turn them off and then back on. If this doesn't fix it, you may have either a bad thermostat or a bad heating element. The back of the dryer usually has a diagram of the wiring. With the unit powered down, follow the diagram with a multi tester.
Posted on Dec 18, 2007
What does my Maytag Bravos 300 quite series electric dryer take so long to dry clothes?
Those sensor bars can become faulty and that is probably the problem. Try cleaning them off with a clean rag. Good Luck!
Sep 08, 2014 | Maytag Dryers
Its not drying the clothes and is taking longer to dry. is there a way to reset?
Dryer Repair. In most cases the problem lies in the vent. Your vent may have partially blocked with lint. The first step is to have vent cleaned out by a vent cleaning company or else buy the "whirlybird" drill attachment and do it yourself. Of course, this is assuming you are getting heat inside the drum. Hope this helps,
Sep 29, 2010 | GE Profile Harmony DPGT750EC Electric...
I have a GE Dryer Profile Harmony. It is several years old. The dryer is not blowing air out the back ventilation so not drying. It is making a quiet odd sound as well. When I troubleshooted I shut the...
You vent is plugged very bad. Disconnect the vent tubing and thoroughly clean it out. It will heat and dry like new afterwards guaranteed. These dryers have sensors that shut the burner off if the exhaust is not venting properly. Once its cleared out it will run perfectly again
Apr 09, 2010 | GE Profile Harmony DPGT750EC Electric...
Problem drying
no, what setting do you have the dryer on? is the dryer getting hot? if it is set correctly and is heating as it should then you need to check the vent hose, it is probably restricted with lint. Be sure and clean it from end to end.
Mar 12, 2010 | GE Profile Harmony DPGT750EC Electric...
Takes 2-3 hrs to dry a load. Put new dryer hose on. Vent not clogged. Lint filter cleaned each load.
Dryer turn on makes a humming noise intermitantly and won't dry at all have changed coils. It's not the fuse or vent. Help??
Nov 24, 2009 | GE Profile Harmony DPGT750EC Electric...
Dryer isn't drying
Your dryer has some internal ductwork that can get clogged and prevent the dryer from operating efficiently. In most dryers it takes quite a bit of disassembly to get to the internal ductwork. Take out the lint filter and look into the opening with a flashlight. Clean out as much as possible with a vacuum cleaner. Also check the venting to the outside. Make sure that the vent is not clogged up and that the flap on the exhaust vent on the side of the house is not stuck closed or partially closed. I will assume that the heating element is working and that the dryer is heating up. If not, that would indicate another issue. Sure hope this helped ya and best wishes.
Jul 23, 2009 | Whirlpool LEN2000PW Dryer
GE Harmony Dryer dries fine one time won't quit sensing the next
The thermostatic fuse is getting hot during the run cycle and then staying open until the dryer cools down completely.
You may fix just by cleaning out the entire dryer. Remove the top cover and vacuum out thoroughly. Replace a torn lint screen and make sure your exhaust conduit is not leaking lint everywhere.
If you can't fix by cleaning, you will have to replace the thermostat which is a $5 part byt a $100 repair.
Jun 19, 2009 | GE Profile Harmony DPGT750EC Electric...
GE Harmony electric dryer model DPGT750EC1PL- very little heat - small rattle - takes hours to dry load of laundry... any ideas?
Check the following to address this issue.
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Jun 06, 2009 | GE Profile Harmony DPGT750EC Electric...
Dryer vent is restricted. Look behind dryer to make sure there is no flex duct squished, preventing air flow. Try to avoid flex duct, use as few turns in vent as possible, and keep vent as short as possible. Vent may need cleaning also. This dryer is very good, as it uses an independent variable speed blower motor to help compensate for long and or restricted vents.
Aug 28, 2008 | GE Profile Harmony DPGT750EC Electric...
Long drying time
Check directly behind dryer to see if there is squished flex vent. Also keep vent as short and straight as possible. Avoid flex venting, or use as little of it as possible.
Jul 17, 2008 | GE Profile Harmony DPGT750EC Electric...
GE Profile Harmony DPGT750EC Electric Dryer Logo
137 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
