Question about Whirlpool 30 in. RC8700 Electric Cooktop
I have a Whirlpool Accubake self-cleaning oven,model RBD275PD86. My wife ran the self-cleaner, then after a short time, everything went black,as if it burned out the oven. What needs to be replaced to get back on track?
  • 51 Answers
CHECK THERMAL CUT OUT ON BACK OF UNIT, MOST LIKELY THE PROBLEM YOU CAN BUY A CAN OF ELECTRONICS FREEZE AND SPRAY IT AND THEN TIP WITH BACK END OF NUT DRIVER CHEAP FIX
Posted on Sep 27, 2009
Owners manual amana stove
Try turning off power to stove for a few minutes then re try
Jul 15, 2014 | Amana 30" Self Cleaning Electric Range...
Need booklet on how to use this oven
download instructions from Philips web site or call their
customer service,
Dec 22, 2013 | Whirlpool 30-inch Self-Cleaning...
Whirlpool self-cleaning feature not available
Because the features mention utilize 220 VAC power, I do not advise you attempt any corrections. Very dangerous; unless you are a trained technician. If the unit is in Warranty, get the Whirlpool folks out to you home ASAP.
Dec 19, 2013 | Whirlpool Gold GGE388LX Double Oven...
I have black swirl scratches from using abrasive sponge on front of black oven door
There is this white stuff sold for glass-top stoves. I presume it is good old iron cleaner, a very mild cleaner/polish. Also consider toothpaste.
Dec 01, 2013 | Amana 30" Self Cleaning Electric Range...
Wfg361lvd
If you have a standing pilot (always lit), the adjustment screw is normally located behind the burner control knobs.
Dec 22, 2012 | Whirlpool WFG361LVD - 5.0 Cu Ft,...
How to clean self cleaning oven
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Mar 21, 2011 | Whirlpool 30 in. RC8700 Electric Cooktop
I don't know how to start the self cleaning oven! I don't have a manual and I don't see any buttons that indicate start self cleaning oven!
there should be a button a small button that says self cleaning on the oven mines on the side but just look almost 95% of all ovens have this
Mar 10, 2010 | Whirlpool Cooktops
Whirlpool self cleaning oven Accubake. 2 yr old
Hi
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Most ranges today use 3 different types of door locks...one is a solenoid controlled lock ( you hear a loud buzz noise when setting or unlocking the lock and has a arm that you must move to set the lock )...another is a heat sensitive lock ( has a arm that you must move to lock and un-lock, makes no noises and has a spring that slowly moves to lock the door will the oven is heating up )...Some locks are motorized ( no handle to move, the motor locks the door by it's self when you set the range for self clean )... If the motorized and heat sensitive locks fails to open after the self clean cycle, you must access the lock and move it yourself to open the door. On the free standing ranges, most times you must lift the cook top to access the lock mechanism. On built in ovens, the oven must be pulled out to remove the top access panel to get at the lock mechanism. Some build in ovens can have the control console removed to access the lock system. On the heat sensitive style of lock, there are no electrical parts to operate the lock, usually you will need to replace the lock. On the motorized style of lock, you will have to use a ohm/volt meter to test why the motor will not work. On the solenoid style of lock, the solenoid is often mounted on the back of the range and can be accessed by removing the rear panel, some may be mounted at the front, such as in a built in oven. The failure of the solenoid style of lock is normally caused by a bad lock solenoid. In order to get your door open, you must operate the door latch mechanism manually. Unplug or remove power from the range. Take the rear cover off the range. Locate the door latch assembly and operate it manually and open your door. Then check continuity of the solenoid. Some of the latch assemblies have micro switches to supply power also. You may need to check them. You should be able to get the door open and use your range until you can get a tech to repair if you can not repair yourself.
If you've interrupted the clean cycle or have accidentally set the clean cycle with the oven door open, the latch may have engaged and now the door can't be closed because it will hit the latch. There may be a door activated* switch on the front face of the oven. In this case you may need to manually press that door switch with your finger while at the same time canceling the clean cycle to get the latch to retract so the door can close fully again.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 06, 2009 | Whirlpool 30 in. RC8700 Electric Cooktop
Whirlpool 30 in. RC8700 Electric Cooktop Logo
223 people viewed this question
Top Whirlpool Cooktops Experts
Timllfixit
Lakeland Appliance...
Are you a Whirlpool Cooktop Expert? Answer questions, earn points and help others
