Question about HP Photosmart C3180 All-In-One InkJet Printer
The check paper light appears
What do I do?
    Problem Solver:
  • 11 Answers
Check to see if there is any paper!
Posted on Sep 27, 2009
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
Green and amber lights flash altrenately and the number 6800 appears on the screen
Is it possible that the error is 6B00 instead of 6800? This would indicate that the problem is a paper feed position error. Check for any jammed paper in the printer. If your paper tray is removable, take it out and lift the top of the printer to expose the ink cartridges. Check in every place you can for any stuck paper, even small pieces.
It is also possible that it could be a mechanical error with the actual paper feed mechanisms, which would require service from a professional.
Mar 18, 2011 | Office Equipment & Supplies
What does the button mean :/\/ that is above the! mean?
The button above the ! is paper jam indicator. Does the light appear immediately after powering on the printer. If yes check paper sensors. If it only comes on after trying to print, it could be a paper misfeed.. Check the feed rollers.. you can turn them inside out for better grip on the paper as a diagnostic method.
May 15, 2009 | IBM Infoprint 1412 Laser Printer
What are the troubleshooting in ecg?
Those are some examples of ECG malfunctions and troubleshooting however there are to many more problems that you can find in ECG equipment. If the problem is not on this short list you can contact us. Or another Medical Repair Organization (MROs).
  • Symptom: Machine runs, but the thermal tip stylus does not write or writes very lightly.
  • Possible cause: (1) Too little heat on the stylus tip, (2) insuficient stylus pressureon the paper.
  • Troubleshooting: (1) Using a insulated probe, such as a srewdriver, gently press the stylus onto the paper. (2) Is a dark line appears on the paper, the problem is too little pressure, but if no dark line appears, the problem is not enough heat.
  • Symptom: Smeared trace
  • Possible causes: Worn stylus or incorrectly loaded paper.
  • Trobleshooting: Check paper loading and if proper, check stylus, for wear, pitting, or another irregularities.
Feb 21, 2009 | American Diagnostic Corp ADC 4500-1...
Not working
Pull out the tray with paper.
You should find a moving plastic "tongue" near the middle of width in the area where your paper tray should go. It's a contact based flag for the device to consider how much paper is in the tray. Check if it's not broken or stuck in odd position. Move it back and forth several times, with no force, it goes very easily. When you lift the flag up, see message and blinking led stop appearing. Try to pull paper tray back in, add paper if error appears again. Enjoy!
Sep 15, 2008 | Canon imageCLASS MF5750 All-In-One Laser...
Hp psc 1219
dear szaszy
as per your information your printer paper jam sensor is having problem.Please get it serviced
Apr 04, 2008 | Office Equipment & Supplies
Hp psc 1219
try pressing repeatitivly the red cancel button
Apr 16, 2007 | HP PSC 1210v All-In-One InkJet Printer
HP Photosmart C3180 All-In-One InkJet Printer Logo
73 people viewed this question
Seeker5211
Seeker5211
