Question about Jensen JPS12 Subwoofer
Jensen JPS12 growls at random...
I have a Jensen powered subwoofer(Model JPS12)that has given me a problem since I bought it in December of 2005. I've had it connected to four different A/V tuners and it does the same thing on all of them.
It emits a sound randomly (if it's plugged in) whether any media is playing or not. It actually sounds like a chainsaw or weed eater being revved up and then stops. Extremely irritating.It also happens when nothing at all is plugged into it but is itself plugged in and turned on. It happens when it is connected to the tuner by a single line OR via the speaker terminals. It even does it after I've switched it off after about 5 or 6 seconds, then fades out. There are no flourescent lights in the room or nearby, no antenna/cable wiring or unsheilded cables nearby and I've tried running it through a ground loop device but nothing seems to work. Nothing specifically seems to prompt the erratic sound.
Can anyone tell me what the problem might be? It did the same thing even when new but I was told that the tuner was the problem at the time. That's why I've tried several tuners in even two different homes on opposite sides of town. Finally, there are no power company sub-stations nearby either.
9/26/09 UPDATE!!!! : I'm finding out that others are having the same problem with this sub. Some are suggesting that it's an "auto-sensing sleep mode switch" that is causing the problem. Is there a way to rewire the on/off switch and bypass the sleep mode device?
Thanks!
chrisxx
    Problem Solver:
  • 11 Answers
Get rid of it and get a real sub!
Posted on Sep 27, 2009
2005 Escape engine making growling sound
I believe it is the power take off unit (PTO).......
Can be a bit pricy to replace....
I hope this helps...
Apr 20, 2013 | 2005 Ford Escape
Hi! I have a Jensen XA2150 Amplifier, from the speaker output I have connected a Subwoofer Sony 10 inch 1100W. Tha'ts gave me a nice bass sound, but now it's death! The amplifier have a 25A fuse,...
Have you checked the fuses inside the amp?Unscrew the cover and with the amp sitting on its back,remove the cover.You have 2-4 fuses,old round type,in there.
May 21, 2011 | Jensen XA2150 Car Audio Amplifier
Hi i" ve bought on
This may help. If it's not the exact model you have it will at least get you started as subwoofers are pretty much teh same for connection and operation.
http://www.wharfedale.co.uk/Portals/0/PDF_Data/Manual/DIAMOND9_range.pdf
Others here...
http://www.wharfedale.co.uk/Support/Download/Manuals/tabid/71/Default.aspx
May 06, 2011 | Wharfedale SW150 Subwoofer
Wiring diagram for jp12 subwoofer
your sub woofer has only one input to make it work. plug in your rca cables into the back of the sub woofer and the other end into the audio out or subwoofer out put on the back of your surround system.
also has 2 speaker inputs so you can expand your speaker setup. plug thos in and you can hook up 2 speakers to th output on the back of the sub.
Jan 29, 2011 | Jensen JPS12 Subwoofer
When my battery died my Jensen DVD player "asked" for it's security code. My son tried random numbers until the system locked him out and now it won't accept additional attempts to unlock it. I...
Hi. On most models, you have to leave it disconnected from the power for around 24 hrs, then when you re-connect, you will get a few more attempts. This is to stop people trying codes continuously until they crack it.
Oct 06, 2008 | Jensen Car Audio & Video
Home theatre subwoofer
Sounds like you have a loose signal lead. Check to see if this cab be tightened if not replace the cable as this could be the cause of the problem. Over time the leads/plugs do loosen especially on subs as they vibrate so much. If it's not this then it's probably something internal to which I am reluctant to advise you on looking at yourself unless you are pretty proficient with electronics :P
Nov 08, 2007 | Jensen XS-1010 Car Subwoofer
Jensen Subwoofer JPS-10
This sound is made by the automatic shutdown in the speaker. Jensen repaired my unit under warrantee.
Aug 27, 2007 | Jensen JPS10 Subwoofer
Battery problem
I would recommend increasing your altinator and getting a yellow top battery. Basically what is happening is your using more power than the car can produce.
Dec 20, 2006 | Jensen BP212 Car Subwoofer
Jensen JPS12 Subwoofer Logo
299 people viewed this question
Top Jensen Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Jensen Audio Player and Recorder Expert? Answer questions, earn points and help others
