Question about Dell Inspiron E1705 Notebook
Monitor stopped working
One day, upon bootup, the monitor decided it wanted to have green lines all through the welcome screen. Then, when the login should appear (xp), the screen goes black. I can see light at the bottom of the screen, but that's it. The processor and everything else is still working just fine. The computer will start and the monitor works in SAFE mode just fine.
Dell support had me restore back to a date when it worked, then re-seat the connection between the laptop and the monitor. That worked for about a day, then it went back to the problem again. Simply re-seating the connection doesn't work, I got it to work again for about two days by performing a system restore again and then re-seating. Since then I haven't been able to duplicate the fix.
It seems to me there is something going on with the video drivers, and I'm not that skilled in trobleshooting these. When I start in SAFE mode, a long DOS list of all the drivers comes up before the system starts, and I wonder if that's a clue that something is not right in there.
I don't want to send this unit to Dell, I have heard too many horror stories about lost data.
Any suggestions?
    Novelist:
  • 188 Answers
It sounds like either a failing LCD or failing video card. I would probably take it to a compentent repair shop if it is out of warranty. If it is in warranty then you may have to deal with dell.
You may have on-site service check what warranty you have with the machine, it would be a lot faster than mailing it in.
Just backup your data before you send it in. An external USB hard drive works great for backup.
I would recommend www.absoluteraleigh.com they have a free diagnostic and have been in business a while.
If you would rather deal locally, get a recommendation from a friend that has had a laptop fixed somewhere - skilled and more importantly *honest* laptop repair places can be hard to come by
Posted on Dec 18, 2007
The screen fonts at bootup are of green colour and the greenish is prominent after bootup also
The tube has aged. You can try to overvolt it, this will restore the correct colors for a short period. Use this time to save some money for a new monitor.
Aug 01, 2010 | LG Studioworks 700S 17" CRT Monitor
FPD1530 (Black) 15 in. Flat Panel LCD Monitor: Screen shows, 'Invalid Mode', followed on next lin...
It means your PC video resolution setting is too high for this monitor to display.
You need to set the resolution to 1024 x 768 @60Hz. Bootup in safe mode (hit f8 during bootup) select VGA support, rest the resolution to 1024 x 768 @60Hz, reboot.
http://s807.photobucket.com/home/budm/allalbums
May 17, 2010 | Gateway FPD1530 15" Flat Panel LCD Monitor
Monitor going to sleep upon Bootup.
Open your cpu cabinet.
refix your RAM memory .
Pull cmos cell for 10 minutes so all settigns are defaults.
Also remove PCI cards from PCI slot .
Then check.
Let me know if you need more assistanse.
thanks.
Aug 31, 2009 | HP w1907 LCD Monitor
Green display on boot up Please help
Check to see that there are no machine BIOS settings that could affect the monitor. Normally, the bios controls display until the OS takes over. If your XP screen after bootup looks fine, I don't see how you have a problem with your monitor setup under Windows.
Jul 03, 2009 | Computers & Internet
Gateway monitor FPD1975W won't display
Same problem - unplug both computer and monitor - hold power button for monitor for 15-30 seconds...then power it back on and then power on the computer. Seems from other sites there is a power issue with the monitor - this worked for me.
May 23, 2009 | Gateway FPD1975W 19" LCD Monitor
Stripes appear on monitor at bootup
I decided to change the background of my desktop and it works.
May 14, 2009 | Gateway FPD1760 17" LCD Monitor
Line through laptop screen
Do you see this during bootup, login screen and also after windows boot ? If so, you screen has gone bad electronically. You may have to replace the LCD screen.
I had a similar problem and I had to replace it.
cheers,
Sep 21, 2008 | Compaq Presario Notebook
Vertical green line somthing like an artifact
Your Display cable (inside your monitor) needs to be replaced.
I would look on ebay to try and find the part and then take it to a local tech to replace it for you as I would not recommend anyone take apart a monitor (LCD OR CRT) if you had never done so before.
OR, Buy a new monitor.
Feb 28, 2008 | ViewSonic VA1703wb Monitor
Solid line completly across screen, monitor is brand new
Your comp's video card refresh rate (in Hertz, abbreviated Hz) may not be totally compatible with the monitor. Check the properties of your video card, and change the refresh rate (you may have to look around for it) to 60 Hz. This is a pretty standard refresh rate that works with just about every monitor. If it's already there, I'm afraid someone else will have to try and help!
Hope this helps, and please rate my answer, good OR bad.
Feb 04, 2008 | ViewSonic OptiQuest Monitor
Dell Inspiron E1705 Notebook Logo
94 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
