Question about JVC Televison & Video
JVC Model av 48p777 I adjust contrast knobs inside tv and now its still blinking and it shuts off like it gets too hot
    Brigadier General:
  • 8,619 Answers
Hi
Firstly, check for a blown fuse or circuit breaker or a power outage. There is a fuse on the inside back panel that is suspect which is located near the power entry to the back of TV. Some versions were socketed others soldered. If you have already tried hard reset (unplugging and plugging it back after 5-24hrs) and still the issue is not resolved then this is more likely a power supply failure. Most causes of TV failure are due to bad capacitors on either a system board or the power supply. In this case, it sounds like the power supply. You can test the capacitors with a capacitor tester to determine faulty capacitor. You can also test other components like power supply current with voltmeter or multi-tester. It can also be due to the protection circuit that is detecting excessive power or current drain by one of the sections of the TV. Could be the high voltage; could be the deflection circuits; could be the audio amplifier; could be the main power supply itself. All this is only recommended if you have electrical expertise and know how to solder/re-solder the components.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Sep 27, 2009
I own a JVC tv model AV-48P777. I hear a weird noise when I tried to turn it on then smelled something burning
This model has a light box that can be removed for repairs--all the guts of the set except front keyboard and speakers come with it.
set still can be turned on to see----I would if working on it remove the box and do a very good inspection to see what burnt---could be as simple as a resistor or even a cap.
Let me know what you find.
Mar 18, 2012 | JVC Televison & Video
I have a JVC 32050 and have a slight red shadow (ghosting). is there an adjustment for this?
Try to adjust the color setting in the menu adjust the contrast or the sharpness feel free to send feed back good day and best regards.
Aug 14, 2011 | JVC AV-32050 32" TV
Jvc hd 52g787 my position adjustment in my menu will not highlight so i can adjust picture over to the left. help please
Hello
Just make the picture status button on the remote control and get the display setting to its factory mode.
The VIDEO STATUS button gives you a choice of three TV picture display settings, including a
display of your own preferences.
Standard - Resets the picture display to the factory settings.
Dynamic - Heightens contrast.
Theater - Gives a rich, film-like look to video. (AV-27D303, AV-27D203 and AV-20D303 only)
Sports - When you watch a sports program. (AV-27330, AV-27320 and AV-27S33 only)
Press the VIDEO STATUS button repetedly to get these choices.
Aug 13, 2011 | JVC AV-27750 27" TV
Picture on tv JVC 27" AV-27530 is getting to dark to enjoy. During dark scenes you can't see much. Have tried adjusting controls and settings to no avail. Any solution greatly appreciated.
I have the AV-27S33 model and in the rear to the right of the inputs are two slits and inside these slits are two screws. The top screw is the focus,the bottom the brightness.Your tv is a different model but it may have this same adjustment,if it does try turning the bottom screw to the right to increase the brightness.
Jun 11, 2010 | JVC AV-27530 27" TV
My kids turned my tv off sat to watch a dvd how
If you have the original remote press the input button at the top right. If that doesn't work or you don't have the original remote try channel - or +
Here is a link to the owners manual http://support.jvc.com/consumer/product.jsp?modelId=MODL027812&pathId=78&page=2&archive=true
May 07, 2010 | Televison & Video
MY JVC AV 48p777 wont turn on. It may be the power board????? is there a test i can do to identify the problem?????
Yes unplug the TV for 5 minutes and hold the menu button down while powering it up for 1 minute then release the button and press volume up 6 times followed by down volume key 4 times.
Let me know if it works
Dec 15, 2009 | JVC AV48P777 Television
We had a bad storm and now my JVC AV-48P777 won't turn on. I have tested all of the outlets, but no luck. Help!
There is a fuse on the inside back panel that is suspect. Located near the power entry to the back of TV. Some versions were socketed others soldered.
Jun 10, 2009 | JVC AV48P777 Television
The picture on my JVC TV is too dark
On the inside of the TV, on the flyback transformer there should be two controls. Turn the one that says "screen" very slowly clockwise while looking at the pix. The pix should get brighter as you turn it up- if you go to far you will see lines in the pix or the TV may shutdown.
Aug 30, 2007 | Televison & Video
Televison & Video Logo
62 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
