Question about Goodman Furnace Draft Inducer Blower Fasco # A285
Is the vent suppose to be pvc 2" or metal 2 wall thru roof on fasco blower
  • 456 Answers
This is an old one, I know they make 2" pvc, but I have never seen 2" Galv. Sheetmetal. I'm
guessing you have a High Eff. Furnace, therefore you would use pvc and be able to go
out the roof or out the sidewall
Posted on Sep 01, 2011
I need a Fasco Model 621 Wall Switch For model 656 Vent, Lite, Nite Lite
Fasco has a number of different manufactures representing them.
You need the following:-
Fasco part # OEM part # Manufacturer
D1107 621 Universal Electric
Oct 16, 2017 | Fasco Heating & Cooling
Maytag model #: med5770tq0 won't dry. Please help
Dear Emily.
Several problems.
First, did this dryer ever work properly hooked up as it is?
I mean hooked to the roof event?
If it used to work just fine, then I suspect the vent to the roof is clogged with lint and is not allowing the heat to escape.
If it never did work right,(for example: it is new to us) then I'd venture dryers are not supposed to vent their hot air that far away, they do not have a strong enough blower to push that air that distance.
Then, you might try to find another place to vent the hot air, with a total distance of only 10 feet from the dryer, even if you only vented it while you were actually drying clothers.
I doubt if the last item is for you, but I have sometimes seen where the washing machine did not spin all the water out of the clothes, and then the dryer needed all day to get the clothes dry.
Be blessed.
Apr 17, 2013 | Maytag Dryers
I have a American Standard furnace Freedom 80 Mod# AUD080C936H3 and am looking for a manal or can you tell me how the exauhst is done. Can I use PVC
Hello, The only time pvc is allowed is if the Furnace is 90% or greater in effiecency, the combustion gases are cooler due to the fact that two heat exvhangers are used. One pipe will be you air intake and the other the exhaust and they can be routed through the roof or sidewall. If the Furnace is 80% then you must use double wall vent pipe and have it connected to either a liner in a chimney or routed through a roof but pvc can not be used.
Aug 28, 2011 | American Standard Heating & Cooling
What size venting do I need for the ptg-42-pvn?
3" category III stainless for special venting
Tanklessking shows Category III stainless steel vent kit for this model
3" vent
http://tanklessonline.com/rheem-water-heaters-RTG42.html
ptg-42-pvn has minimum 31,000BTU and max 118,000BTU
Max water temperature 120 degrees F
Spec sheet says: 3" special venting
http://www.palomatankless.com/products/42/specifications.html
Hart and cooley show special vent 3" stainless thru-the-wall vent
http://www.hartandcooley.com/specialgasvent/PDF/851515%20Tankless%20Water%20Heater%20Installation%20Vent%20Kits%20sell%20sheet%20-%20HC%20-%20low%20res.pdf
Hot water sources shows thru-wall or thru-roof
http://www.hotwatersource.com/RTG42PVN-Rheem-Indoor-Natural-Gas-Tankless-Water-Heater/RTG42PVN,default,pd.html
http://waterheatertimer.org/pdf/Tankless-roof-vent-installation.pdf
Aug 17, 2011 | Rheem Paloma PTG-42PVN / RTG2-42PVN...
I have a 3 ft stainless double wall chimney that is going thru a ceiling/roof in my garage. there were no instructions on installation. how is this secured? Pls thx Jer
You can use metal strapping with short self-tapping sheet metal screws also where it penetrates roof a metal collar on inside should be used and a roof collar approved for B-wall vent pipe to keep water from leaking inside on outside on the roof.You can penetrate outside of B-wall vent pipe with short screws to secure the pipe just don't penetrate both pipes.this outside pipe is just a insulator to keep heat from transferring through pipe.
May 01, 2011 | Selkirk METALBESTOS 104082 ROUND GAS VENT...
Loud blower on my new Rheem Power Vent 2 water heater
find out if it does the same noise with the venting disconnected
Nov 01, 2009 | Fasco Bradford White Hot Water Heater...
Noisy water heater blower
There really is no way to do this. If you put a cap you will restrict the air flow which will cause you to have problems with the water heater, same thing if you where to put screen on it. You can try enlarging the pipe to a 3 inch and see if that works. But 15 years in the trade nothing has been made to reduce the noise
Jun 01, 2009 | Fasco Bradford White Hot Water Heater...
Condensation from small blower shorts out circuit board.
Put a plastic bag over the control board that will allow it to breath. you can add sealant to joint but you should clean the old off first. Then use some cork tape after sealant dries. You may also use pvc glue but it will never come out after that, but can be cut w/ saw if that becomes nessary.
Feb 01, 2009 | York Yankees Bedding MLB Comforter
Change the venting from internal to external?
Hello staufferbi,
It is possible to redirect the vent to the outsied but it is not a simple task. First off, you will need to remove the micro from the wall cavity and reposition the blower so that it vents out the top and not the front, then cut a hole in the cabinet above the micro ( lined up to accept the rectangular duct ) These tasks require fairly good carpenmtry skills and may not be suitable for the novice.. In any event, if you do attempt this.. then once you have the duct vented through the cabinet from the top of the microm you will need to attach that to wall vent feedthru. This normally means converting the rectangular duct to 4inch round and using an elbow. Needless to say, it can be done but is fairly involved. I did not mention anything about getting a 4 inch hole thru the outside wall and not thru a wall stud.,. Outside walls are typically bearing walls and although your roof won't cave in if you cut a hole thru a stud, it isn't advisable. Then you have to make sure it is sealed thru the wall cavity and properly cut into your siding. As I said before..it can be done but don't think it is a little job..
Good luck
Rick
Jan 09, 2009 | Microwave Ovens
Goodman Furnace Draft Inducer Blower  Fasco # A285 Logo
62 people viewed this question
Top Goodman Tools & Hardware - Others Experts
john h
Paul Carew
Jeff Hogancamp
Jeff Hogancamp
Are you a Goodman Tool and Hardware - Other Expert? Answer questions, earn points and help others
