Canon PowerShot A640 Digital Camera
Problem for Canon PowerShot A640 Digital Camera
A640 freeezes while taking pictures
By tarana_mmk on Sep 27, 2009
Camera is 2 yrs old & was never dropped or misused. I have been always using Rechargeable NiMh Sony batteries 2500 mAh. Have 2 sets & are 2 yrs old.
Problem: Camera freezes suddenly while taking pictures. On/Off button does not work when camera is frozen. Have to open the battery compartment to power off camera. Then use power On/Off button to turn camera ON.
Happens only while taking pictures with Flash ON.
Problem happens less often with fully charged batteries.
Problem did not occur while taking 50+ pics with Flash OFF.
Picture quality is still excellent.
Sometimes after problem occurs, Exposure seeting gets reset to 0 (I usually keep at -1)
Problem happened first time while using Rechargeable Eneloops. Since then have switched back to my old Sony rechargeables.
Solution #1
posted on Sep 27, 2009
Not Rated)
BillB-SA
Rank: Guru  Canon Cameras & Camcorders  Expert
Rating: 85%, 374 votes
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your camera may have a problem that requires professional repair.
Was this helpful?
Yes
No
Popular Solutions for Canon PowerShot A640 Digital
Questions and Unsolved Problems for Canon PowerShot A640 Digital
Do you recommend Canon PowerShot A640 Digital Camera?
Answer
Answer
the screen on my canon a640 has started to turn blue around the edges, what's the problem and how... (More)
Answer
When I press the left button (on the 4 way directional dial on the right) in shooting mode, my... (More)
Answer
i have a canon a640 and recently got a new computer. i lost the original setup disk that came with... (More)
Answer
powershot a640 is beeping about 5 or 6 times, says on the screen lense error plese reset. whats... (More)
Answer
the front lens cover of the camera is loose and falls in front of the lens... I think I know the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Canon PowerShot A640 Digital...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 400
Experience: I have run a camera store for 25 years & three websites TripodQuickRelease.Com BogenTripodParts.com
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
