Question about YouTube Videos
You tube is stalling every three seconds - YouTube Videos
    Genius:
  • 1,144 Answers
Update your video card
Posted on Sep 27, 2009
Why does my honda hr214 sx lawn mower starts for 30 seconds then stalls
The fuel inlet tube is most likely clogged with fuel varnish or debris. Remover the carb bowl and slide a thin rod or paper clip up through tube and clean out fuel passage. Spray carb clean up through tube to complete cleaning. Repeat this at the end of the season and then remove gas from tank or use fuel stabilizer available at WalMart or any auto parts store.
Jun 17, 2014 | Husqvarna 160 CC Honda OHC Engine 21 in
1988 s15 jimmy starts fine but stalls out
Stalls out when and how? At start up would be security. Do a reset. Turn it on, let it set for 10 minutes off or 30 seconds. Then try to start. relearn is do this three times with out the start up. After three times try to start. 4.3 engines have a problem with distributors also. the gear is junk. Though I haven't seen then to kill the engine, it wouldn't surprise me. Need to know when it stalls..
Apr 08, 2014 | 1988 Chevrolet Blazer
O2 kia rio stalls after three seconds
So, it will start right up with no issues after it stalls? Could be a few things. You may have faulty O2 sensors causing the fuel trim to cause problems, it could be a bad/dirty MAF sensor that just needs a cleaning, or you may have an Idle Air control valve that isn't functioning properly. Some of these things you can do yourself, but you'll need a scanner that can see live data to look at the others.
Mar 06, 2014 | 2002 Kia Rio
Toilet Problems: One has Noisy flush & two others drip at rate of about two drips per second
Do you have a way to check your water pressure each of these problems could be caused by excessive pressure you may need to install pressure adjustment valve if you can't find another way
Jun 10, 2017 | Toto Home
Mtd 139cc ohv engine will start with primer, but stalls within two or three seconds
Ensure oil is full. Engine has a low oil cutoff. 30w oil. Replace carb only about $27.
Jul 11, 2013 | Mtd Garden
Picture went out and red light on the front by power button is blinking. When I turn TV on I can hear sound but no picture,, then TV turns off automatically after a few seconds.
It seems problem with low screen voltage to three picture tubes in this rear projection tv.
If standby light blinks 5 times after three seconds long pause then adjust screen volts of each picture tube to solve this issue.
Screen volt adjustment requires expertise and job of professional so please call local tv repairman to help you.
Thanks.
Feb 27, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
2003 Caravan: My dodge caravan will stall three or four times on...
Sounds like a malfunctioned IAC or mass air flow sensor. If the check engine light is on take it to a local Auto Zone or similar parts house. They normally run a diagnostic check for free. The mass airflow sensor is very easy to change it is a sensor in the neck of the Air intake tube leading out of the intake plenum. Remove the sensor, unplug the electrical connector and replace the new sensor and plug it back in. But I would have a diagnostic run before you do anymore work on it.
May 17, 2010 | 2003 Dodge Caravan
Why car starts but stalls in seconds
Could be the idle air control valve, I have a 1993 Honda Civic Si, they cost about 200 on that to replace.
May 23, 2009 | 2004 Nissan Murano
Please help
I suspect if you have green lines .you have a bad crt. there are three tubes red green and blue i suspect blue tube. tubes cost is around 300.00 to fix.
thanks doctor video
note sometimes you could adjust screen voltage located near the front grill black box . becareful high voltage ony a pro should do.
Jun 14, 2008 | RCA D52W15 TV
YouTube Videos Logo
79 people viewed this question
Top YouTube Computers & Internet Experts
Michael Terence...
Michael Terence...
Mike
Are you a YouTube Computer and Internet Expert? Answer questions, earn points and help others
