The camera now refuses to take pictures while the lfash is on. A small 'cross hair' appears which is either red or green but it will not take the picture. It works fine in normal mode
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera
which can prevent the full power of the batteries from flowing into the
camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with
a dry cloth (heavy corrosion may require cleaning with a wire brush,
steel wool, or sandpaper). Remove any residue that may have fallen
into the battery compartment during cleaning, then wipe both ends of
the batteries and place them back in the camera. This cleaning clears
the problem about 90% of the time. If it doesn't work for you, chances
are that your batteries need to be replaced because they're just too worn to properly power the camera.
And then, of course, there's the possibility that your camera may have
a problem that requires professional repair.
Was this helpful?
Yes
No
Popular Solutions for Kodak EasyShare CX7430 Digital
Photos have been saved to camera memory instead of memory card. How do I retrieve photos for...
(More)
Photos have been saved to camera memory instead of memory card. How do I retrieve photos for printing?
the camera will turn on perfect and you can see the viewfinder ok and then it will go black and...
(More)
the camera will turn on perfect and you can see the viewfinder ok and then it will go black and cannot see to take picture.
