Question about Video Game Consoles & Games
It wont let me open says check your path - Video Game Consoles & Games
  • Sean Blundy May 11, 2010
    On what might I ask?
  • 438 Answers
U have changed the folder to another drive or un installed it accidently......or some of the files is lost...so re install it
Posted on Sep 27, 2009
How do I fix the error of ricoh3350 where it gives me error jamming at the first tray and there is no paper .when Chang the tray it gives the same .
check paper path rather than just the paper tray.
Check duplexer and any other paths the paper takes
There will be levers of some kind to open path of path through the printer .
Mar 11, 2017 | The Office Equipment & Supplies
Changed battery, lights work etc, door's open and close, but will not start engine. what do I do next?
check all the fuses, connections, wires than id go directly to checking for a spark, fuel and than compression.
Aug 06, 2015 | 1996 Jeep Grand Cherokee
Red and green light turn after first run
Its common problem in T Series Plotters:
Cause of malfunction: These plotters having separate sheet path as well as roll path for print media. After initializing plotter its verify the available media(sheet or roll). If sheet path is occupied by the media it wont allow the roll media, means first priority is for sheet.If sheet path paper sensor dusty or malfunction, printer will say "remove paper from sheet path" even no paper in sheet path..
How to shoot this problem:
You need to clean sheet path sensor located at sheet loading area.(black 'U' shaped part) Applying the pressured air at sensor is the best method to clean.. If problem remain you need to remove the sensor & clean or replace it.
Follow the snaps:
Need to open roll feed right side portion
dadb8b23-32b2-4d8a-952b-038117715d5b.jpg f7392b92-295a-4144-8387-b83355c6889e.jpg 6f066468-8698-4d24-94d4-af1703c40407.jpg 6ed46665-db38-4ccc-8522-c52ae9c50dbf.jpg 37e6b4f2-cc2e-438b-849e-9911bd553c7e.jpg
Clean the IR sensor...
Fix it back..
Note: Technical knowledge required to understand the remedy..
Jan 26, 2014 | HEWLETT-PACKARD CP1025 Laser Printer
Crown vic 2000 wont crank ? battery, alternator,starter,starter relay all good ?
The problem is in the wiring harness,yes the battery and starter is good, the harness you repaired is the PRNDL. for the starter to start it need a path when the vehicle is Park or Nuetral,there the path is closed some how by Park and Nuetral the path is open.Thats why there is a no start.when in park or nuetral the path is closed.
Nov 12, 2012 | 2000 Ford Crown Victoria
Car wont start put new ignition switch and same prob I have power on acc but not forward no dash lights or starter. i can manually jump starter and checked fuesablb link what is the issue
check your grounding conductor, connection to earth, check for open path or short.... if your grounding point of contact with earth is not super clean and rust free, then it wont start but you will have power on acessory because it uses a different grounding point (batteries main earth connection).
Also, use a meter to check continuity of conductors to and from starter and it will show a short if the OHM reading says "overload", but disconnect battery first to be safe.
Aug 17, 2012 | 2000 Pontiac Sunfire
Hello my printer wont work, the powerbutton is blinking and i hear a tikking noise. is mij printer broken?? lexmark x5250
It could an alignment problem, a paper jam, or something blocking the paper path. Open the printer cover and remove both the cartridges. While the cover is open, check the cartridge area for any obstructions in the cartridge carrier's path. Check any transparent strip(encoder strip) that has become loose from its position. If there's nothing out of the ordinary, close the cover. Unplug and replug the printer into the power source to reset it. When the printer turns on, reinsert both cartridges and make sure they properly inserted and secured. Close the cover and try to print again.
May 29, 2011 | Lexmark X5250 All-In-One InkJet Printer
Garage door opens an inch then stops. i hit the button again and it closes. then sometimes it wont even respond. can you help me fix this through this chat
Hi and welcome to FixYa, I am Kelly.
This almost sounds like the door safety optics near the bottom of the door is not working or the optics path is blocked with something. Check the path between the 2 sensors for any obstructions. You may or may not see the red optics light path between sensors as some of these are infra red.
If the path is clear start looking at optics wiring near the sensors and all the way to the opener terminal board for any signs of damage. If all of that appears fine... then your probably going to have to replace the up/down limit switch assy.
Before you get too deep into all of the above... if the door senses a jam as in it has to drive with excessive force it will do exactly as it is now. Bent door rollers... something hanging down from the ceiling blocking door movement in the UP direction.
There really are several things that can cause this:
1. Optical sensors
2. Door limit switch
3. Force adjustment assembly
4. Blockages of optics path or door movement path
5. Stripped worm gear in the opener that has caused the door sequence timing to change on the limit switches.
6. Failed motor drive gear assembly.
Even for professionals some of these can be very time consuming to isolate and repair. (you can tie up as much money in repair labor costs as it would cost to replace the opener. Since you did not indicate how old your unit was or the exact garage door opener model number, the response above is very generic. I am not telling you to replace your opener. Only advising you of what can be high repair costs.
If your not that mechanically inclined I would call a garage door installer and ask that if he can not repair your opener what would be the replacment cost. Negotiate a diagnosis / repair cost vs replacement cost over the PHONE. Explain the symptoms and see what they say. (Call more than one before making a commitment!) Expect to hear all of the answers I mentioned above.
Thanks for choosing FixYa,
Kelly
Mar 25, 2011 | Genie Company Genie Excelerator Down Limit...
Writer wont close completely
Open the drive get a flash light check to see if there is anything inside blocking its path.
Nov 03, 2010 | LG Computers & Internet
Plustek wont scan
no the problem is check the path u mentioned in the scanner preferences and settings i mean the folder mentioned to store the scanned images after the scan , scanner is given a path to store these images by default check and change that path to other location on hard drive and everything will be ok if the problem persists then update ur driver from plustek website
Feb 24, 2009 | Alestron OpticSlim M12 Path-Through...
Can't open file.
Check Hemera settings and ensure that the path for the picture files is the right one, where files are stored.
Hemera usually reads the picture files from CD/DVD unit, if your system had renamed the DVD form D:\ to E:\, for example , then Emera wont be able to find files anymore.
Solutions to this problem.
Check file source folder on Hemera settings, and assign the right CD path.
Do a system restore to a date before having the problem.
If still no luck, then Windows may be corrupted, in that case , the standard procedure is reinstalling Windows, then reinstalling Hemera, and the rest of the software.
Jan 02, 2009 | Hemera The Big Box Of Art for PC
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
