When I 'm trying turn on the tv is just doesn't
    President:
  • 1,124 Answers
It is more than liekely the power suply in the tv had failed.. To know for sure it would need to be tested..
Posted on Sep 27, 2009
Luxor tv
There is a short ciruit inside its circuit board. It sounds that the horizontal output transistor has gone leaky.
Jun 06, 2013 | Televison & Video
SRP4004/27
Let's try to sort this out. You have a universal remote control which you want to use with your RCA TV. You turn on the TV, press and release the TV button on your remote, and enter an RCA TV code. You then press the ON-OFF (or POWER) button and the TV turns off. If not, you repeat the process with other codes until you find one that turns the TV off. If you are successful, you should be able to turn on the TV and channel up or down through all available channels in your area. If I am missing something, post a reply
Nov 16, 2012 | Televison & Video
Turn on but remote doesn't work
I would try new batteries first. If that doesn't help then replace the remote with a universal unit that you can program to work with your TV.
Nov 13, 2012 | LG 42LC2D 42 in. LCD HDTV
The volume on my tv will not turn down. when i manually try to turn it down, it continues to go to full volume
Take the batteries out of all remotes that could control your T.V.s volume. Try turning it down. Try pushing the up button on T.V. to see if it's stuck. This T.V. doesn't really have a lot of digital controls, so it's probably a mechanical issue.
Dec 22, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Go to turn on tv and all I get is flashing red light and tv won't turn on. Was working the other day.what do I check?Sharp LC-26GA5U
Try unplugging the TV from the power point and leave unplugged for 5 min.
Or the batteries in the remote may be flat, try replacing the batteries.
If this doesn't work the TV may have a fault.
I hope this helps
MobileJB
Jul 13, 2011 | Sharp LC-26GA5U 26 in. HD-Ready LCD...
When I turn on my set, light turns green, then after 30 seconds turns red won't come on
Sounds like there is a problem with the power supply. Try unplugging the T.V. and hold the power button for 30 seconds. Plug the T.V. back in and see if that helps. If it doesn't try switching to another outlet, and if that doesn't work then you may need to replace the power supply which would probably cost anywhere from 140 to 200 for one.
May 05, 2011 | Fujitsu PlasmaVision P50XHA40US 50 in....
Sanyo television doesn't turn off either by using the remote or by turning it off at the tv.All other fuctions work using the remote or directly on the set.Even using the sleep timer doesn't turn...
Unplug the set and hold the power button for 30 seconds. Plug it back in and see if that fixes it. If it doesn't then it sounds like there is a problem on the board underneath the power button. Something isn't allowing the circuit to be cut.
May 05, 2011 | Televison & Video
Remote doesn' turn n tv or chane channels
try changing the batterys. If its a universal remote reprogram it again.
Oct 04, 2009 | Symphonic ST420FF 20" TV
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Electro Med Services...
