Question about Fujitsu Heating & Cooling
Don't understand timer settings
Fujitsu controller Model: AR-JW19
I think it might be to do with the timer? Will turn the light on the machine and beep,but not open up the vents and pump air. Been able to get it going a couple of times. Set with half moon and clock at 1hr, 9o'clock diagram to blank clock at zero and 9o'clock and vertical line at 6 o'clock? Tried to reset by taking batteries out but duz not work.
SOURCE: Fujitsu Heat Pump - problems
I had the same problem. The heater did not work in heating mode. However it was OK in air-conditioning mode. The operation light and the timer light blink twice and then the operation light blinks for 5 times followed by few seconds non blinking, then the cycle repeats again. I have read on the internet that you better unplug the power cord and then plug it again so that the heater re-sets itself. My only problem was that my heater is directly plugged to the power with no visible plug. So I went to the main distribution board and put off the power for about 20 seconds for the whole home. HOORAY!! The heater worked after that.
Posted on Aug 08, 2008
bobotfel
  • 236 Answers
SOURCE: replace remote control unit model ar-fb2
If your remote control have display but cannot transmit signal to the unit. Confirm first if the remote is really the problem, using your camera or cellphone camera as your eyes point the remote transmitter to your camera and "on" the remote. You should see light emits in your remote control, if no emitted light then the remote control is defective. But if there is a light the defect is in the unit receiver.
Check also if there is a reset or rst button in your remote control and reset it and try.
Check also if there are error codes in the unit, reset the unit by disconnecting the power supply in the unit for 10 sec. and "on" again and try.
The unit can be operate without remote control, use the manual button located in the unit.
If the remote control have no display replacement of remote is recommended.
Posted on Jan 16, 2009
  • 634 Answers
SOURCE: fujitsu air conditioning remote control not
open the remote and carefully look at where the batteries make contact they sometimes bend in and dont make contact just pry them out a little and reinsert batteries and it often will work again
Posted on Jul 07, 2009
  • 10 Answers
SOURCE: can't open the remote controller on Fujitsu Model
Try tighly gripping both sides fo the slide down section to loosen it then slide it down wards.
Posted on Jul 15, 2010
SOURCE: The operation and timer lights on my Fujitsu split
I have same problem like yours to my newly installed Fujitsu multi-split system (the first time use since system installed 1 week ago). I rang the electrician who did the installation; he said it must be the units themselves nothing to do with electricity.
Okay, then I rang Fujitsu and their local service agent. They suggested me to switch off C/B for an hour to reset the units. I followed the instruction but the indoor units still did not respond to remote control...
It simply looks like no power supply to indoor units (they are hard-wired to the outdoor unit). So I used a multi-meter to test the power terminals of indoor units (Danger! If you have no idea about this, don't even try! ): it seemed no power supply even C/B is on. I turned to the isolator which next to the outdoor unit. The isolator was making arcing noise when I switched it on and off. The indoor units suddenly turned on for few minutes then died again.
So I figured out the problem is that crooked isolator. I called the unhappy electrician to replace the isolator. End story....
I hope my experience will help you a little bit.
Posted on Nov 23, 2010
Fujitsu Cassette A/C model AR-SY1. There is a blinking/flashing red light next to a timer like icon. Pressing Filter reset button on remote control does not help.
Those blinks are fault indications. From the number of blinks occur at one time switch on, you can get details about the faulty circuit stage inside the set. If you wish to get more details visit the site linked here. http://electronicshelponline.blogspot.com/
Feb 20, 2017 | Fujitsu Televison & Video
My remote control is working i need replacement is for fujitsu air condition model #AR-RY6 or can i use different model
I find that most remotes from the same manufacture work on different models. Fujitsu is big enough where I think its worth a try.
Oct 15, 2016 | Fujitsu Heating & Cooling
How to turn the Timer off on Fujitsu AC Model AR-RAC3E? I have tried several times but failed. The Timer light flashes three times every several minutes. The AC does not work at all. The Operation
remove front cover-pull from bottom and lift up at top reset button is above lights try that first , other checks remote battery, control wires 1-2-3 from condenser to evaporator board.
Jan 20, 2015 | Fujitsu Heating & Cooling
How to turn off the timer on the Fujitsu AC Model AR-RAC3E?
Hi Rismita,
I hope the following link is helpful for you
Good luck
http://errorcodeairconditioning.blogspot.com.au/2010/10/fujitsu-air-conditioner-error-codes.html
Jan 18, 2015 | Fujitsu Heating & Cooling
Directions for setting Fujitsu wireless remote AR-RED1U
If you type this into Google "Directions for setting Fujitsu wireless remote AR-RED1U", you will get information on how to do what you want to do.
Oct 29, 2013 | Fujitsu Televison & Video
Fujitsu remote control Model AR-DL10. I need to change the batteries. I can pull the slide down to expose the set/ swing/ energy save, but I think I have to pull it further down to get to the batteries. ...
How to get to the batteries in a AR-DL 10 Model Fujitsu Remote Control/ A/C
Pull it down to expose the controls inside.
To pull it down further to expose the batteries: PINCH BOTH SIDES OF THE slider at the top where it is knurled so it will bow out a little bit in the center AT the same time you may need to
slide an object under the slider to help it bow up a litter further.
WHILE DOING THIS: pull the slider further to expose the batteries. There are two plastic stops that the slider must clear to pull it down enough to get the new batteries placed. Before putting it back together: File down the two stops with a nail file so it is easier to do next time. - Who engineered this?
Sep 11, 2010 | Fujitsu (FPCRC04AR) Remote Control
My air conditioning unit will not turn on... the model is AR-SY1 and flashes with a red light on the timer button?
The lights on the front panel will flash in a certain order depending on the fault. Please count the number of flashes & let us know.
Aug 13, 2010 | Fujitsu 24R1 Air Conditioner
Heating & Cooling Logo
448 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
AJMAL KHAN
Donni Steen
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
