SOURCE: LG Vu CU920
i think you type the code in 0000 (zeroes) and there ya go. [: i went to att.com and typed in puk code and then it said type in 0000 so, hope that helped!
SOURCE: LG VU CU920 FLASH LITE
The software on the phone is not up to date same problem i had with it. and you cant download flash to your phone
SOURCE: 8gb micro sd card does not work. lg vu cu920. is there a fix
I HAD THE SAME PROBLEM AND KEPT ON MESSING WITH THE 4G MEMORY CARD AND FOUND OUT THAT I HAD TO FORMAT THE MEMORY CARD ON MY COMPUTER AND NOW IT READS THE CARD..ON THE SIDE OF THE SD ADAPTER HAS A SLIDING PIECE THAT SAVES YOU FROM DELETING THINGS ACCIDENTALLY BUT IF YOU SLIDE IT INTO THE MIDDLE POSITION THEN IT WILL ALLOW YOU TO FORMAT THE MEMORY CARD BUT YOU WILL LOSE WHATEVER THAT IS ON THE MEMORY CARD AND WILL HAVE TO DOWNLOAD IT ALL OVER AGAIN..I HOPE THIS IS CLEAR ENOUGH FOR EVERYBODY TO UNDERSTAND BUT THIS IS HOW I GOT MY MUSIC AND PICS ON THE MEMORY CARD
SOURCE: ring tones for my lg vu cu920
It must be under 300 kb. Lame, I know, but that's the way it works.
If you want a ringtone for a specific contact, then your contacts must be kept on the phone, not the mem card, only. I keep 'em both places, just in case.
SOURCE: unlock code for lg vu cu920
Nope.
Try first calling the manufacturer to get the subsidy code.
If you do not want to call the manufacturer , then try the method on link below, but it does not work on all cu920:
Subsidy unlock instructions for the cu920
