Question about Lexmark X3470 All-In-One InkJet Printer
Cover open my printer wont shut off and says cover open ive tried to wipe it off but nothing im hoping its an easy fix it was working before i change the ink cartrige
MY HP printer can print but does not copy
Same thing just happened to my fairly new 7520 Hp.
I shut my machine first with the shut off button and then unplugged
it for about 5 minutes. Sounds like you tried this and I believe this did not work for me either so I just went into the HP official site and downloaded my printer again. Downloading your printer from their
site is easy and quick instead using the cd. It automatically removed my old printer and installed the printer again. The problem has not returned.
Another problem I just had and because I think one of my new
cartridges (yellow) is somehow damaged. I got a black line down
my pages with a note that my yellow ink is missing. Had black line only when printing and not copying. I reinserted the yellow ink and took a light damp qtip and slightly wiped the machine screen on each ink cartridge.(this screen meets the new opening from each
new cartridge. The black line left.
Hope this helps.
Jan 02, 2015 | HP PhotoSmart Office Equipment & Supplies
Cannon pixma ip2000 message says printer head not installed tried re installing but does not work,can you help. ****
the printer head of the printer is separated from the ink cartridges, after removing the ink you can remove the head, pull the latch upward so the head will pop out then pull it out, wipe the copper connector with a clean cloth be sure not to touch it, check for smudges in the connector wipe it dry then put it back gently on the cradle, on the printer open the cover make sure it initialize then stay in the middle, insert the ink again, hope this work
Aug 03, 2011 | Canon PIXMA iP2000 InkJet Printer
Print carriage access door is open or ink cartridge cover is open. getting this message but nothing is open!! It says to hold down ok button for 5 seconds but nothing is happening. I turned off but it...
Turn off your printer
Open the cover
1 move the cartridge carrrier manually to the center manually with your hands from left torgiht ( 5x )
2 .Remove the cartridges used a clean paper make sure its dry wipe the area where the ink goes out make sure its clean .CLean also the area where you return your cartridges make sure its clean OK .
3 >return it properly close the carrier properly make sure there's a snap sound produced .Move again the cartridge carrier manually from left to right 5x
close thecover
try to turn it back on
in case nothing happens
remove all the parts cartridge ,black box paper power supply
lift the printer up turn it up side down make sure the cover is open when you lift it up and turned it upsidedown
so any foreign material will come out
Shake it for 5x
\return all the parts
try to power it on
Hope it help thanks
May 26, 2011 | HP Officejet Pro L7680 All-In-One Printer
Epson stylus c48
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage.
Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head.
Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now
If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Jul 27, 2010 | Epson Stylus C48 InkJet Printer
Can i print using black ink when im out of color ink it wont let me even though ive changed the settings to print colors as black and white
That's the way Kodak works
It won't allow yu to do anything if any of the lights are flashing or there is a error message
NO RESOLUTION
Get your color ink cartridge replaced by Kodak.
Just say its a new color ink cartridge and printer is saying its empty!!
Hurraay you'll get a free color ink cartridge
Jan 25, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Compatable red cartridge will not work
Hi Col,
The reality is that yours is an all too common story, the problem is with the type of ink. Your printhead in your printer is a very sensitive little peice of electronics and they tend to react badly to the wrong type of ink. I know that the fool who sold you the ink assured you that it will work as well as the genuine article, (I have heard all this before on many many occasions), but the fact is that the ink inside the genuine epson cartridge is covered by an international patent and cannot be used by anyone other than epson.
To cut a long story short, the non genuine inks are diluted in order to pass through the print head. As a result they tend to also dry very quickly and tend to destroy the head. The best solution I can offer you is to go out and buy a genuine cartridge and hope that it fixes the print head. You will have to install it and try to clean the head.
There are some methods you can use to try to speed up the process, but get your replacement cartridge first and try to do a head clean first. This will hopefully fix your problem.
Gremlin11
Dec 13, 2008 | Epson Stylus Multifunction Inkjet Printer/...
HP Deskjet 5550 cartridge carriage stuck
I have had this same problem a few times, not due to changing the cartiges, but following one of my kids yanking on a peice of paper as it was printing. After I tried all the unplugging and clearing and re-starting, the arm was still stuck on the left. I read on some forum (can't remember where) while the printer is off, to gently push/pull on the cartiges until they un-jam or start to move. I flet like I was going to break it, but it has worked every time.
Hope this helps osmeone else!
Jan 25, 2008 | HP DeskJet 5550 InkJet Printer
Yellow ink contaminated
Yes, do you refil your own inks. Colour contamination occurs primarily when users overfill ink holes with any colour, then this colour runs into others and voila, a yukky mess. If cartridges are fairly new, heres the quick easy fix. Remove cartridges that are causing the problem, in your case all! Using a proper cleaning solution (you can get this free in refill kits or buy it sepeartely, i got mine from supermarket, works well) and cotton buds, thoroughly clean down where the cartridges sit. There will be both fresh ink and dried ink, so you will have to repeat over and over until all or most colour is gone from cotton buds. Now, let it dry and air, leaving printer cover open. You now have to bleed the black ink as it sounds like it is overfull. This can happen in refilled cartridges, but even store bought ones can have faults. Sit the black cartridge on wet paper towel, on a clean icecream lid or marg lid, even a plate will do, just one that you don't mind ink on by accident. Let it sit a minute or so, now lift it up, and wipe it gently with a wipe (i use unscented baby wipes-huggies, do not laugh, they work well!) press it firmly on a folded tissue, and it should leave a nice clean neat black vertical little line. If it doeas, place it back in its place in printer. Leave open for now. The colour cartridge should need cleaning too, by doing the same, each time you lift it off wet paper towel, wipe it clean, and press it on a tissue to see clean neat 3 colour line. If not, bleed again until it does. When it does place it back in printer and reset ink levels once cover is shut. Try printing now.
Jul 24, 2007 | Canon BubbleJet i560 InkJet Printer
No printing
There can be a few causes for the ink light to blink. 1 - the cover isn't well shut. open and close it, and check for any obstructions. 2 - you're out of ink. let's assume you have this option covered, but if you want to check, look for the yellow indicator arrow on the cartridge. 3 - the carts don't sit right, or have a bad connection due to dried ink on the contacts. Take a damp cloth and gently wipe the contacts on the printer side till you get most of the ink off. Next, take the carts, and submerge them in hot water(1-2 mm high) so that only the contacts are in the water. Let the water dissolve the ink for a few minutes, take the carts out, give the contact area a few more wipes, wipe them dry, and try inserting them into the printer again. If you want to check with new parts, but rightly don't want to waste the money, try borrowing. Hope this helped
Mar 29, 2006 | HP DeskJet 1120cse InkJet Printer
Ink LED is constantly blinking. Printer does not respond.
The ink LED has 3 causes that make it blink. One is that the top cover of the printer is not well shut. Try opening it and closing it. If you?re lucky you?re home free by now. The second , simple enough, is that you?re out of ink and have to replace the cartridge. This is easy to check ? open the cover and look for the yellow arrow on the ink head. It should point on one of the small images according to the state of the ink. The two left ones indicate an empty cartridge that needs to be replaced. Note: sometimes a cartridge you get with a new printer contains less ink then a newly purchased one. Third cause is that you got the wrong type of cartridge, or that they?re not inserted well. Were they changed just now? In any case the right type is: Black: HP 6615A Series or HP No. 15 Tri-Color: HP C6578 Series or HP No. 78 Hope it works out!
Feb 21, 2006 | HP DeskJet 920c InkJet Printer
Lexmark X3470 All-In-One InkJet Printer Logo
107 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
